Old 10-17-2012, 04:39 PM   #1
pkbinder OP
Kissing Moose
pkbinder's Avatar
Oddometer: 283
I sprung a leak!
I have an 09 800GS. The original owner, a stand-up guy who is a regular on this forum, fixed a leak in the lower case with JB Weld that has lasted almost two years. It started to leak again 2 months ago, so I wire wheeled the paint and some, but not all, of the JB off and replastered it with more JB. I was ecstatic that I stopped the leak. But, alas, the leak is back. Smarter folks than I tell me I should find a welder who can weld aluminum, as apparently that is somewhat of a specialized art. The original leak came about when the bike crashed on its left side. There are two connection points for the crash bars on the lower case. The impact caused a small tear in the case right where the crash bars connect, and thus the leak. Any of youse guys have any thoughts on the matter?
Life is suffering until you realize that life is suffering.
pkbinder is offline   Reply With Quote
Old 10-17-2012, 05:22 PM   #2
GH41
Oddometer: 822
I hope the price you paid was low enough to allow to properly repair of the case. JB weld is something you use to get you home. It is a patch not a repair!!!! GH
GH41 is offline   Reply With Quote
Old 10-17-2012, 06:07 PM   #3
pkbinder OP
Kissing Moose
pkbinder's Avatar
Oddometer: 283
Yes, the price cerainly did reflect the conditon of the bike. Full discosure and all that. But thanks for the advice anyway. pk
Old 10-17-2012, 06:48 PM   #4
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,448
I would buy a new case if the crash guards are still using that for a mount.
If it is too expensive to replace then look into different crash bars that do not mount on that location and just redo the JB weld.
The reason the JB weld is leaking is due to the stress induced by the crash bars and not the JB weld just wearing out.
I use JB weld to repair cracked intake ports on heads and it hold up for life if done right.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 10-17-2012, 09:53 PM   #5
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 600
IF you decide to go the welded route, make sure it is a very reputable shop, like a machine shop of some type. If they know what they are doing, I would trust them. (Like if you show it to them and the look comfortable doing it....) It would be wayyyyy cheaper than a new case.
Ryan
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 10-18-2012, 09:23 PM   #6
sorebutt
Oddometer: 1,917
I've had broken cases welded on other bikes and never had a problem. The weld is usually stronger than the rest of the case.
sorebutt is offline   Reply With Quote
Times are GMT -7.   It's 02:03 AM.
