Old 10-17-2012, 05:38 PM   #1
superpimp OP
Oddometer: 68
SE starting Problems when cold
Hi guys,
My SE has a been having trouble starting recently when cold.
It's been cold, and fires up but dies afterwards .Choke fully open.
Looks like fuel starvation or something .If i'm lucky and it gets past dying and warms up its fine all day long.
Any ideas?
superpimp is offline   Reply With Quote
Old 10-17-2012, 08:30 PM   #2
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
Could be lots of things but when did you do your valves last. This is usually the reason.
DeepInIt is offline   Reply With Quote
Old 10-17-2012, 10:29 PM   #3
JOKER650
JOKER650's Avatar
Oddometer: 1,595
If I use full "choke" it will not start verry well then die.
3/4 and it starts and runs great but does not need to really be 'on' for long.
Life's short...ride far
Over 2000 plated dirt riders...Digg'n up the dirt every other day, all over BC
http://www.dualsportbc.com/
JOKER650 is offline   Reply With Quote
Old 10-18-2012, 09:17 AM   #4
superpimp OP
Oddometer: 68
Probably right Deep its due for a valve adjustment.I don't think it as ever been done on it.I'm the second owner.
Old 10-18-2012, 09:30 AM   #5
Leeexc
Leeexc's Avatar
Oddometer: 100
I had some problems starting mine from cold then Pyndon showed me to use the choke and hold the throttle on just a bit whilst pressing the start button, had no problems since.
Leeexc is offline   Reply With Quote
Old 10-18-2012, 09:57 AM   #6
BENRON
Crosscut Certified
BENRON's Avatar
Oddometer: 3,658
Mine does the same. Valves are in spec. Just figured it was the nature of the beast.
BENRON is offline   Reply With Quote
Old 10-19-2012, 11:43 PM   #7
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,103
It could just be technique, but this is the way it acts when the fuel pump starts going out. The carbs run dry on startup, then the pump starts working again and every thing goes back to normal.
"Son, you can't do both"
Old 11-02-2012, 02:00 PM   #8
superpimp OP
Oddometer: 68
Mmm it's maybe time for a facet fuel pump replacement. Going to add this to my winter mods i think
Old 11-02-2012, 06:19 PM   #9
triplenickel
triplenickel's Avatar
Oddometer: 2,428
Set your valves, sync your carbs see where you end up.
07 SE
PG007
Old 11-02-2012, 08:07 PM   #10
KTMADV
Hammer Down
KTMADV's Avatar
Oddometer: 177
Check your air screws and your idle. My bike had the same problem and I just adjusted those two things and my bike runs perfect now.
Ceasar Vasquez
KTMADV is offline   Reply With Quote
Times are GMT -7.   It's 11:59 PM.
