Old 10-16-2012, 04:49 PM   #1
TastyPants OP
Harasshole
TastyPants's Avatar
Oddometer: 226
New Chain: Recommendations?
Anyone found a decent quality chain at a reasonable price they like?
Also curious about sprockets but I found a few I like already.
TastyPants is offline   Reply With Quote
Old 10-16-2012, 04:54 PM   #2
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
I've been happy with the RK chain I've been running for a while.
Recently had a new 18" rear wheel built by Woodys with Supersprox. I've used these sprockets on my WR with consistently hard use and good results.
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 10-16-2012, 06:52 PM   #3
toro618
toro618's Avatar
Oddometer: 966
Are you using the gold Supersprox for a KTM 990?
toro618 is offline   Reply With Quote
Old 10-17-2012, 11:41 AM   #4
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Yep.
Dan
Old 10-17-2012, 03:54 PM   #5
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,739
Check these guys out, talk about top end products, let the first cost be the last ... good merits in this.
http://sidewindersprockets.com/
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 10-17-2012, 05:24 PM   #6
1994klr250
1994klr250's Avatar
Oddometer: 635
I'm running a RK GB525XSO chain with OEM sprockets right now. I had this set put on in Fairbanks this past summer when my OEM chain was worn at 17k miles. I've been happy with it so far. I just ordered a replacement chain and sprockets from these guys below. I've always had good experiences with DID chains so I went with the DID 525 ZVM-X.
http://www.sprocketcenter.com/c/2654...-gs-08-12.html
2300 miles on a 250 all for a sticker http://www.advrider.com/forums/showthread.php?t=616239
Fall ride on a KLR250 http://www.advrider.com/forums/showthread.php?t=754065
1994 KLR250, 2009 F800GS, 2006 KLX351
1994klr250 is offline   Reply With Quote
Old 10-19-2012, 06:04 AM   #7
MikeMike
MikeMike's Avatar
Oddometer: 4,150
I got over 40,000kms out of the stock chain and replaced it out of preventive maintenance. Clean it regularly and lube it religiously every 700kms or so and you are good to go.
For the new chain I got a Regina endless and did the swingarm drop, I had not access nor chance to pick up a riveting tool locally and it would have cost me well north of $65 to have one shipped in. I have been beating the hell out of the new chain and it is doing fine. Doing the swing arm drop gives you a chance to get some well needed lube into the pivot points and is a plus side of the job. Most people ignore lubing the swing arm because their is no grease nipple. Motorrad are as cheap with grease on the swingarm as they are with the wheel bearings.
If you go the route of a rivet chain you are looking at around $175 for a chain and tool and sprockets, I would imagine.
If I can get 40,000kms out of the Regina I'll be happy, however I will likely sell the bike well before that. It should be possible to get well over 50,000kms out of a good set of sprockets and a quality name brand chain if you do the maintenance. I ride only on 3rd world roads full of tope speed bumps and it is constant acceleration and deceleration and rough surfaces with the odd very high speed stretch of toll highway. It's "no country for old chains".
Old 10-19-2012, 12:59 PM   #8
seasider
Just a rider
seasider's Avatar
Oddometer: 387
Not to redirect this thread but what should be the deciding factor with regard to a riveted chain vs a clip?
Lost time is never found
seasider is offline   Reply With Quote
Old 10-19-2012, 01:20 PM   #9
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Valid question and here is a take on it.
Drag bikes used clip type chains for years, as did large capacity multi cylinder bikes in the late 70's and 80's when the owners had done in the OEM endless chains as fitted to some of the bikes. Can a clip type chain handle the 75hp of the F800GS? Probably.
Availability will be the big thing. If you are fitting an o-ring clip type chain, a chain press that costs about $8 or so is a good idea, it saves having to use the "2 10mm nuts and a pair of vice grips" or "end of a wooden hammer" method to compress the o-rings enough to get the clip on. Racers used to safety wire clips, by the way.
You can either cut the old chain off, or use a chain breaker and then put on your new one, or you can buy the endless version and drop the swingarm and fit it on. You have to lube your swingarm some time, or at least check it, this is a good opportunity and you won't need a chain breaker or a chain press or a chain rivet staking tool so you will save yourself a fair sized bit of money. You will likely only change the chain maybe twice in the time you will own the bike if you are on top of the maintenance on the chain, see if you can borrow the chain tools from a friend unless you are serious about building up your tool kit.
You'll probably change your cam chain once and your drive chain twice if you decide to own the bike for more than 80,000kms.
Old 10-19-2012, 07:26 PM   #10
seasider
Just a rider
seasider's Avatar
Oddometer: 387
Thanks Mike mike. I have wondered since owning the bike but never had the applicable chance to ask. Clips on my dirt bikes and I do own a chain breaker but the swingarm lube issue makes a good argument.
Times are GMT -7.   It's 12:01 PM.
