Go Back   ADVrider > Riding > Epic Ride Reports
Old 02-12-2013, 03:23 PM   #3706
goatroper
goatroper's Avatar
Oddometer: 620
Zen and now
from Colebatch:
you take the shallowest route ... you dont get to pick that, you just have to find it. Often by walking the crossing many times. If you cant walk across it due to the current, you have no chance of getting a bike across it.
you also have to bear in mind where you want to get out of the water. There will be one spot on the other side where you have to climb up the opposite bank ... whatever route you take, you need to end up there
goatroper screwed with this post 02-12-2013 at 03:37 PM
goatroper is offline   Reply With Quote
Old 02-12-2013, 04:53 PM   #3707
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,674
That won't work in the former Soviet Union, mate. There are guys there who would add peppers and horseradish to 151 to get up their standards. "Smooth" and "sippable" aren't in the Russian drinking lexicon. A very poplar type of Vodka is Horilka. Translated, the word means "a little burn."
It's a whole different league.
Originally Posted by O'B View Post
Here is a trick a buddy of mine invented that works wonders when in the vicinity of drunks or a party with locals. In all my travels outside the US it always seems the locals wants the Gringo to sample the local moonshine or spirits to get a good laugh at the funny expression on the Gringos face(its all in good fun). Well after we partake we pull out a pint of Bacardi 151 and tell them try ours they are usually feeling no pain at this point and proceed to take a big chugg of the sissy gringo booze. Kaboom rubber knees,tearing eyes a dazed stagger like they just got caught with an Ali straight left jab. Then the enevitable question. Uno Mas Amigo. The enevitable reply no mas,no mas. It also is good when confronted by drunks that won't go away. You just wip out the 151 and offer them a drink if they take a big enough hit it will mellow them out enough to get your shit together and get out of Dodge plus you will make instant friends with the local Hooligans by offering them a drink. Its really good for snake bite too!
The Rock 2013 RR
http://advrider.com/forums/showthread.php?t=915172
Dual Sport Luggage Racks: http://www.moto-racks.com
hONORARY mEMBER fIRST aMERICAN cHAPTER tEAM nONGA (pROVISIONAL wING)
Canuman screwed with this post 02-12-2013 at 05:01 PM
Canuman is offline   Reply With Quote
Old 02-12-2013, 06:10 PM   #3708
blues bob
Oddometer: 92
steve's raw original video
WOW, you have definitely captured the true spirit of the word ADVENTURE. No need to edit. It is AMAZING!!!!!!!
blues bob is offline   Reply With Quote
Old 02-12-2013, 06:18 PM   #3709
25jack
WhateversComfortable
Oddometer: 23
Shorai
Walter, any thoughts on the Shorai reliability? Will you continue to to tour with one?
Pricey but love the weight.
25jack is offline   Reply With Quote
Old 02-12-2013, 08:09 PM   #3710
Phreaky Phil
Oddometer: 1,922
Originally Posted by Colebatch View Post
It seems very stiff to me for ADV work. As I mentioned above, 4.8 is a standard spring rate on a 990 Adventure, which not only is a lot heavier, but has a less suspension travel. I weigh a similar amount to you for the record.
Even for rally racing, 5.0 - 5.2 seems very very stiff. I have a friend with a 450 rally bike, (also about the same weight as us) and he runs a 4.7 spring rate (4.6 in one fork and 4.8 in the other).
I would start at around 4.4 - 4.6 and change that if you bottom it out. If you are doing adventure travel, you need to protect both the bike and yourself as much as possible. The lighter the springs, the less the surface of the road is going to be passed on to you. Run the lowest spring rate you can that does not result in the forks bottoming out according to the way you ride.
Progressive springs are a way to run a lighter spring without the forks bottoming out, which as I mentioned above, is the aim of the game. for the first 100 odd mm of travel the forks have a lighter spring (for mine it was about 4.0) which helps the forks absorb everything from rocks, bumps in the road, gutters etc instead of transmitting them through to the handlebars and the chassis of the bike. I.e. less vibrations on the bike itself, and less coming thru your hands and body. Softer spring protects the bike and protects you better than a stiffer spring. As the fork compresses, the spring rate changes to a much stiffer one ... which is important as it helps the fork avoid bottoming out.
So for me, a progressive spring is a natural extension of the front suspension philosphy of having the lightest possible springing that still avoids bottoming out the forks.
I have DRZ forks in my DR650 with 0.48 springs but I am 2up with a tank that can hold 38litres of fuel.They are good at that rate but i would like to try a bit less high speed compression damping. For a lighter bike and solo the standard springs, 0.43 should be fine, i would think there isnt much weight difference between the DRZ and an XC
Phreaky Phil is offline   Reply With Quote
Old 02-12-2013, 11:02 PM   #3711
Colebatch OP
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,991
Originally Posted by Seth S View Post
Is this the kind of trip where a couple of small cheap bikes like the TW200 would be a good choice....cheap..little worry about them getting damaged or stolen and easy to haul out of a bog if needed....vs say my KTM 690 which would be a bummer to lose.
its three and a half months of your life ... you need to ride a bike that is going to be fun. If a TW200 does that for you then thats fine. But I enjoy the speed out on the steppe tracks and trails hugely ... and a 200cc bike isnt going to give me that.
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 02-12-2013, 11:08 PM   #3712
Colebatch OP
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,991
Yes I will,
but I will also always take the charger / reconditioner with me on long trips
Old 02-13-2013, 12:17 AM   #3713
Franck B
Oddometer: 115
In the mean time some of these LiFePo batteries are much less expensive.
My KTM dealer lists the Shido battery for the EXC, so it should resist the beating of offroad riding. I bought one for my EXC only 70€.
http://www.shido-batteries.com
Franck B is offline   Reply With Quote
Old 02-13-2013, 02:28 AM   #3714
rryd
Oddometer: 22
A equipment question. Tank bags, what do you use?
What do you prefer?
Approximately size?
Rune, Norway
BMW X-Challenge, X-Tank, X-Rack, Hyperpro suspension.
rryd is offline   Reply With Quote
Old 02-13-2013, 05:35 AM   #3715
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,793
It was only a thought. I'd take a 950
Seth S
Seth S is online now   Reply With Quote
Old 02-13-2013, 07:02 AM   #3716
Colebatch OP
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,991
What do you prefer?
Approximately size?
I prefer small ... you can use whatever size you like, but if you are standing up all day then it shouldnt get in the way of your standing position when riding.
Note standing position when riding at 100 km/h is more forward than standing still, due to balancing against wind ... so you need to test that position dynamically rather than statically.
I have been using a GL fandango for a while, and think the size is about right. I can keep a few key things in there including a video camera and a DSLR.
Old 02-13-2013, 08:32 AM   #3717
Twinmike
Grandpa
Twinmike's Avatar
Oddometer: 146
Thumb
Please, more from the RR
where are the Norwegians? maybe on snowmobile in the norwegian tundra
Twinmike is offline   Reply With Quote
Old 02-13-2013, 10:28 AM   #3718
far
ADVreader
far's Avatar
Oddometer: 136
Mr. Colebatch
standing up all day .
Colebatch you look big how you do to stand up for that many days I have troubles in just one day with my back for hard off road ride in a 450 MX.
How about if you start the RR and let the viking catch up you later
far is offline   Reply With Quote
Old 02-13-2013, 10:37 AM   #3719
jeickerman
Full of it.
jeickerman's Avatar
Oddometer: 229
I would say it is the plush suspension he keeps talking about. Seems quite logical to me. Float over the nasty stuff, and let the springs do their job, instead of transmitting the jarring action to your body.
John
jeickerman is offline   Reply With Quote
Old 02-13-2013, 10:38 AM   #3720
Colebatch OP
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,991
I think getting the risers right is critical for that. Risers that go forward as well as up is imho vital to getting the ergonomics right. Normal risers actually bring the bars closer in to your body due to the angle of the forks. That can make standing tiring and more work. Different bikes have different peg to seat heights. I am lucky to be on a bike with very good spacing between the feet, seat and bars - but I still like the bars both 50 mm higher and more fwd.
Plush front suspension helps too
Times are GMT -7.   It's 05:01 PM.
