Old 10-18-2012, 11:13 AM   #1
JLeather OP
Bike Butcherer
JLeather's Avatar
Oddometer: 298
Physical differences of type 247 (airhead) engines?
Are the physical locations of the intake and exhaust ports different between the airheads (R50, R60, R65, R75, R80, etc)? I'm asking because I want to put a Luftmeister turbo kit on an R60/5. The kit was technically only offered for '74+ bikes and only listed for R75, R90, and R100 with most of them being installed on R100's. I read that the location of the ports are the same for all the airheads, is that true? I know the diameter of the ports changed some and I may need to turn some spacers/sleeves for the exhaust and intake.
I saw a Luftmeister kit on an R65 on eBay a few months back, and I know atleast one member here has one on an R100, which would lend some credence to the theory that the physical engines are no different. The durability and tuning issues I'll address later :)
JLeather is offline   Reply With Quote
Old 10-18-2012, 11:30 AM   #2
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,820
Wouldn't it just be easier to buy a 1000cc bike if you want more go?
or you could by a 1000cc bike and and then put the Turbo on it.
Rob Farmer is online now   Reply With Quote
Old 10-18-2012, 12:05 PM   #3
Padmei
enamoured
Oddometer: 3,737
my r65 has shorter barrels than the 80/100. If that's what you mean?
Padmei is offline   Reply With Quote
Old 10-18-2012, 12:09 PM   #4
JLeather OP
Bike Butcherer
JLeather's Avatar
Oddometer: 298
Where's the fun in that? Actually, though, I'm asking because I lucked into an un-used Luftmeister kit a while back and I have a kinda rough '72 R60/5 sitting here. Supposedly in some of the literature the kit fit "all type-247 engines". Just wanted to pick the brain of a few members before I dragged everything out of storage, tore the carbs/exhaust off of the R60/5, etc.
Yes, but are the intake and exhaust ports in different locations?
JLeather screwed with this post 10-18-2012 at 12:17 PM
Old 10-18-2012, 12:15 PM   #5
luxlogs
luxlogs's Avatar
Oddometer: 302
Sorry I have no answer only more confusion, the kit you saw on the R65 was for a 248 engine.
ABC # 11808
74 911S
87 TW200
82 R65LS
92 R100GS
luxlogs is offline   Reply With Quote
Old 10-18-2012, 06:38 PM   #6
bmwrench
Oddometer: 2,267
The only problem you'll have with fit is that the R60 intake stubs are a lot smaller than the R100s; you're going to have a step down from the turbos tubes to the heads.
If I was going to build such a thing, I would install (at least) R75 cylinders and heads, and since the R60 cam seems to be the culprit in the stock bikes tendency to ping, I'd probably install a 308 cam at the same time.
Turboed twins are interesting performers, but I have to warn you that riding them can be compared to straddling a wood stove-seriously hot.
bmwrench is offline   Reply With Quote
Old 10-18-2012, 07:26 PM   #7
JonnyCash
turd polisher
Oddometer: 1,631
How would cam profile contribute to pinging? I'm not asking thinking that to say that it wouldn't. I just don't know.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 10-18-2012, 09:27 PM   #8
_cy_
Oddometer: 6,386
some info on MOA
http://www.bmwmoa.org/forum/showthread.php?t=52498
_cy_ is online now   Reply With Quote
Old 10-19-2012, 05:20 AM   #9
JLeather OP
Bike Butcherer
JLeather's Avatar
Oddometer: 298
Thanks for the heads-up. The kit I picked up has the optional water injection hardware, which should help me some with the detonation and heat issues. I'm not building a tourer, it's just going to be a fun bike for short hops. If I blow the R60/5 motor I can always swap jugs/cam later. How big can I go on an R60/5 bottom end? R90 cylinders?
The intake stubs, are they removable? I've almost got my new lathe up and running (went to a 14x40 instead of the little 10" I was running). If they are removable I could make new ones, or I could also just make some adapters.
Old 10-19-2012, 08:03 AM   #10
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,056
Inmate MNSTY has/had a turbo water injected R90S that has something like 90K miles on it and I beleive he is the second owner and has had no issues.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 10-19-2012, 07:11 PM   #11
bmwrench
Oddometer: 2,267
The shorter duration increases "dynamic comprssion ratio" by closing the intake valve before the piston pushes some of the intake charge back out.
The Luftmeister turbo kits actually fairly well as long as you stayed with the "stock" 5 lbs of boost. Adding boost beyond that made carburetion difficult, required water injection, and caused severe detonation. The way the motor pulled was thrilling, and the sound of a boosted Airhead is rather intoxicating, although it always felt to me like the bike was being yanked along by the scruff of its neck. .
Old 11-11-2012, 07:31 PM   #12
JLeather OP
Bike Butcherer
JLeather's Avatar
Oddometer: 298
Well, for the most part the kit fits fine (in spite of being advertised only for later models). There are a few small nagging issues. The exhaust after the turbo interferes with the kickstarter. I like the kickstarter, so I'll be re-routing the exhaust. The intake spigots are way too small, so I'll be machining some larger ones with a nice taper inside to preserve some sort of flow characteristics. The turbo also hits the stock size/location of the battery, but that's getting moved. Honestly I'm pleased. I'll make a dedicated thread for this bike in the future when I get ready to do some serious work. At least now I know I don't need to change top ends or anything, atleast not until I blow one up
Old 11-11-2012, 11:10 PM   #13
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,619
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 11-12-2012, 05:49 AM   #14
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,701
It would be 25 years since RJ milled those injector bodies on a modified drill press.
He never fails to impress me.
I still get a buzz remembering blowing away a GPZ 900 down the Maudsland Rd.
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 11-13-2012, 04:59 PM   #15
Biebs
BMW Airhead
Biebs's Avatar
Oddometer: 553
Thumb Fuel injected and turbo charged
Originally Posted by GSD4ME View Post
That is interesting do you have any more info on this bike??
Airhead
1974 R75/6 for sale & 1989 R100GS & 1983 Honda CB1000
Biebs is offline   Reply With Quote
Times are GMT -7.   It's 08:26 PM.
