10-22-2012, 01:45 PM
#46 |
More tacos than you
Oddometer: 5,127
I'm not sure what SS's basis is, but I'd agree with the statement. The bore to stroke ratio is well over square (94:70) and that by nature makes it an engine that is happier reving higher than lugging at low RPMs. The more over square an engine is, the more it depends on revs to make HP than torque. For a given displacement, a longer stroke will give you greater torque as the piston has a longer moment arm to turn the crank. With the same displacement, a larger bore (and thus shorter stroke) allows larger valves for better breathing as well as more piston surface area for combustion pressure to push on, but less mechanical advantage to turn the crank and thus lower torque. Since it can have larger valves though, it can breath better and rev higher. Since HP is a function of torque and the number of combustion events per unit time, over square engines depend more on revs to make HP than large amounts of torque. Square and under square engines by comparison depend more on big torque to make their power because they can't rev as high due to increased piston and rod accelerations due to the longer stroke as well as less ability to breath due to smaller or fewer valves.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. Airhead Wrangler screwed with this post 10-22-2012 at 03:04 PM |
10-22-2012, 05:39 PM
#47 |
because I can
Oddometer: 6,082
Well, I started riding them in '75 when I was 14 but my dad put an end to that when he noticed I was grinding the rubber off the bottom of his brand new R75/6's foot pegs. I didn't ride them much but maybe around the shop after that until five years later when I bought my own. That was in '81. I have been riding the stink out of them every since. That and how they are made. Short stroke/relatively long rod. Pretty much everything about them says rev me except for their mile long pushrods. But most importantly, they just don't make good power until they are reved up a lot. Our shop was also a Moto Guzzi dealership. Overall, they are just the opposite. They are typically grunters. Other engines too. Not our airheads. I have pretty much never had any arguements on this subject or the other but there's always a first time.
10-22-2012, 05:58 PM
#48 | |
because I can
Oddometer: 6,082
10-22-2012, 06:47 PM
#49 | |
Oddometer: 1,116
I just had a look at a couple of Hampton Downs videos and I'm surprised that you'd need a 2.91 around there. It doesn't look as fast as Pukekohe. Just from a video, ( and I know it's a bit of guesswork, I'd fit a 3.0 . The vid I watched was a 600 jap bike but it never seemed to get rally going in top gear. If I ever get back to Pukekohe I'd have to pull my finger out. I can't remember the times but I think I was 1.11 or around there. Are the 2001 results online anywhere?
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. Bertrand Russell |
10-22-2012, 07:35 PM
#50 | |
Oddometer: 720
I bought a set of big valve 1977 heads after Puke....then it was mentioned that the D port R80 heads are the better ones to start with.....got a set of these too...... head work on BMW's seems to be cloaked in secrecy..... ![]() The BMW sidecar dropped a valve seat before even doing a lap..... and the ring lands were pushed together a bit.... Maxheadroom ( Nick) found a stock r100 head, swapped over the valves and rockers....carefully took the rings out...dressed the piston in the lathe.... and.... ![]() With this set up they managed a 3rd and a 4th...newish rider and different swinger. I suggested they put it on the Dyno, disconnect one lead at a time and see which has more power..... Apparently it ran the same but riders leg tended to blocked the carb
10-22-2012, 11:24 PM
#51 | |
Oddometer: 327
Having started with an R75 (/5) as well I would guess it was not the experience with that, as reving a stock R75 won't take you very far. It simply doesn't like it. So probably it's the experience with your engine. That confirms my experience with duration cams (not the 336, but e.g. Schleicher 330): you get an engine that likes to rev high, but, compared to it's power at high revs, is a bit weak at bottom revs. Overall you get a mild torque boost, but over a wide rev range. So far so good. From personal experience I know that with the right cam and, most important, exhaust setup you can reach a torque level at or near the magical 100Nm/litre level. Resulting in an engine that can be, that even likes to, but not necessarily needs to be reved to have fun. I know better engines than this one but it will give you an impression of what I'm talking about. http://www.advrider.com/forums/showp...1&postcount=41 What I want to say: IMO there isn't "the beemer". The variety of what you can get with different setups is that high, you simply can't lump them together. |
10-22-2012, 11:29 PM
#52 | |
Oddometer: 327
http://harley.wolfcrews.com/misc/BMWc.jpg |
10-22-2012, 11:36 PM
#53 | |
Oddometer: 327
10-22-2012, 11:37 PM
#54 |
Oddometer: 327
10-22-2012, 11:43 PM
#55 |
Oddometer: 16
power increase with steady ride
I wanted to go fast stop fast and go into the twisty bends at speed.
I had Roger Benett of Motoworks (bins?) build me a motor . He uses 97 mm J&N pistons big port big vale heads aka 77 rs, I use a 40 mm exhaust , 9.5:1 twin plug 336 cam the rest is stock. I can RAPIDLY ACCELERATE IN 4TH TO 100MPH SHIFT TO FITH AND IT KEEPS ON PULLING so far up to 135 mph and there is more to go. Frame r90S 1974 is fully braced ala HPN style with diagonal side braces, R100R forks reworked with Race Tech valves and springs for my weight , very light Magnesium Wheels single front brake 310-320 mm? with 4 pot Brembo, Ohlins rear with proper springs for me Ride like it is on a rail and superb handling. Stops on a dime . Of all my airheads I like this the best I can keep up with the guys on the sports bikes sort of but the bike is faster then me. It has dramatically improved my ability on the road and was worth the time and effort to build. |
10-22-2012, 11:46 PM
#56 |
Oddometer: 1,116
"Pulling your finger out" is an strange English phrase that means to do some hard work , to get on with something properly, to put in some effort. I've no idea where it comes from.
10-23-2012, 12:51 AM
#57 | |
Oddometer: 327
I tried to find an online version of a cartoon from the german cartoonist Holger Aue about that topic, unfortunately couldn't find one. |
10-23-2012, 07:32 AM
#58 |
Von Hochstaden's son
Oddometer: 44,985
I love this thread. Lots of experience pooled togheter.
mikuni vm32-33 both sides :\ 5000 feet altitude/ 140 main \ 159 02 needle jet\ 6F4 needle in the middle setting\ 0.5 air jet\ pilot 25/3.0 slide 35 mpg around town riding like a asno |
10-23-2012, 11:16 AM
#59 | |
because I can
Oddometer: 6,082
10-23-2012, 12:00 PM
#60 | |
Oddometer: 327
But for all I know it's a matter of setup, not a natural law. So at least for tuned beemers it's not a "must" but a "can". For stock beemers, after thinking about it, I believe you're right. They have to be reved to give power, having peak torque rather high. Last time I rode a stock 2V beemer was at least 3 years ago (the year of the GS anniversary). It was an R80GS Basic, right from BMW Classics, and it had literally no power at all. EDIT: really stupid, I ride a stock R100RT from time to time. Probably forgot it as I don't connect it with Power ... RGregor screwed with this post 10-23-2012 at 12:27 PM |
