10-19-2012, 03:02 PM
#1 |
Oddometer: 369
Ring antenna? (bike fails to start in the rain).
At least that's what I think it's called.
I had a problem starting the bike once a month or so ago in the rain. I turned the key on and nothing happened, nothing! Turned it off and on again, still nothing, I took the key out, put it back in, turned it on and all was fine, dash check lights, etc. and it started. I didn't give it another thought, until now. I got out of work today, raining like crazy so yes it was thoroughly soaked, went to start the bike and nothing. Tried the usual on and off, nothing. Took the key out, put it back and wa la it started and ran fine. Now my question is: Does this sound like a ring antenna I hear about all the time failing when it gets wet or something else. I'm a daily 12 month rider and this would be totally unacceptable, well it would be to anyone I guess. I also want to add that last winter the lock froze up and I thawed it by heating the key and it worked. I just hit 60,000 miles and I guess it would be expected for some thing to wear out though I hope not.
2007 R1200GS almost farkeled to perfection! |
10-19-2012, 03:46 PM
#2 |
Oddometer: 369
I just saw this thread: http://www.advrider.com/forums/showthread.php?t=245456
Good but it talks about the yellow triangle coming on. My bike was dead! SO I suspect it's not the ring antenna. Still don't know what it is?
10-19-2012, 06:01 PM
#3 |
Mod Squad
Oddometer: 53,454
Check the easy stuff.. I'd start at the battery, check that both terminals are nice and tight.. Check the battery voltage as you crank it, it might be dying or has a bad cell.
I'll change your thread title to attract more responses..
ADV decals, patches & flag? Here |
10-19-2012, 07:33 PM
#4 |
Dog Rancher
Oddometer: 4,181
Prevention! Why not cover it up when it sits in the rain once you figure out the problem?
Was there a recall for the key ring thing. My 08 had a recall for the key. You could make this into a cover. From Show us something that you MADE for your GS
10-21-2012, 11:06 AM
#5 | ||
Oddometer: 369
I did check the terminals and there tight. I didn't use a volt meter but I'm talking stone dead no response to the key and whe I pulled the key and put it back in it was fine. Quote:
Ah the cover thing. I do carry and use a cover most of the time. However when I ride to work in the rain and the bike is soaking wet I hate to cover it to hold the moisture in just in case it stops raining and it could dry out. But I'm always open to rethinking my decisions.
10-21-2012, 11:40 AM
#6 |
Unregistered
Oddometer: 4,443
Nope
You have a bad electrical connection somewhere, possibly at ignition switch itself. With the ring antenna you get a EWS fault. You screen lights up and will say EWS. You can not start your bike but you will have power to other systems, like lighting, ect. The below web page explains EWS and the antenna rings role in starting the engine. http://www.hexcode.co.za/techinfo/ews
I've got to be cool Relax Take a long long ride on my motor bike Untill I'm ready Mudcat screwed with this post 10-21-2012 at 12:35 PM |
10-21-2012, 01:49 PM
#7 |
Accredited Jackass
Oddometer: 42,790
Was having the same problem. Sometimes it'd work, sometimes not. No dash, no lights, nada. About the same mileage.
Replaced the switch on the bottom of the ignition cylinder, problem solved.
Life is not measured by the number of breaths we take, but by those moments that take our breath away. George Carlin |
10-21-2012, 03:34 PM
#8 | |
I'm a Seoul Man...
yes.
BMW GS and Yamaha WR250X/R (split personality) ![]() Save $5 on a Smugmug account, use this code: hVs9vtN9NsQRQ |
10-21-2012, 04:10 PM
#9 | ||
Oddometer: 369
Note: The hexcode link is a worthwhile read. Thanks Quote:
2007 R1200GS almost farkeled to perfection! bob393 screwed with this post 10-21-2012 at 04:18 PM Reason: note: |
12-04-2012, 04:11 PM
#10 |
Oddometer: 369
Just a note: it appears to be the connections to the ignition switch itself. The last time it wouldn't start out of desperation I started wiggling the wiring harness on the bottom of the switch and it came to life.
12-04-2012, 10:57 PM
#11 |
Unregistered
Oddometer: 4,443
Well, that maybe a broken wire. I believe you can just splice in a new piece of wire if that is the case.
I've got to be cool Relax Take a long long ride on my motor bike Untill I'm ready |
