Old 10-19-2012, 11:35 PM   #1
brocktoon OP
brocktoon's Avatar
Oddometer: 257
/5 Combination Switch Repair?
While chasing down electrical gremlins I noticed that my headlight switch only worked when the bars were turned at a certain angle. I pulled the switch and found this:
It's a little hard to tell, but the wires have pulled loose. They're contacting one another and shorting out when the cable is at certain angles. I need a way to push the wires back in secure them there.
Given that the replacement combination switches are a cool $100 apiece, is there any way to push the wires back in and secure them there? I found a combination switch repair article, but it only addresses cleaning the sweeper plate. I was able to follow the steps to pull the thumb button off, but didn't see any way to tighten all the wires up.
I'm guessing the answer is "suck it up cheapskate", but here's to hoping these things can be fixed.
brocktoon is offline   Reply With Quote
Old 10-19-2012, 11:57 PM   #2
spo123
Man About Town
spo123's Avatar
Oddometer: 826
Cool2 yes
Use a small soldering iron.
Be careful.
It should work.
BE CAREFUL. I was.
Good luck.
spo
1973 /5 LWB Toaster
spo123 is offline   Reply With Quote
Old 10-19-2012, 11:59 PM   #3
brocktoon OP
brocktoon's Avatar
Oddometer: 257
so they're just soldered in there?
Old 10-20-2012, 12:42 AM   #4
assquatch20
Hoss Cat
assquatch20's Avatar
Oddometer: 1,104
I refuse to believe a 3-position detented potentiometer with a push button isn't out there that drops right in. There has to be a number somewhere that corresponds to a pot code.
But yeah, solder it up.
Some things shouldn't be left like you found them.
assquatch20 is offline   Reply With Quote
Old 10-20-2012, 04:39 AM   #5
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,248
It's not "a 3-position detented potentiometer".
--Bill
'73 R60/5 Toaster
Old 10-20-2012, 12:48 PM   #6
assquatch20
Hoss Cat
Oddometer: 1,104
--Bill
My apologies. If not that, some rotary switch. It's just impossibly hard to believe BMW made it rather than bought it and build a housing around it.
Old 10-20-2012, 07:16 PM   #7
brocktoon OP
brocktoon's Avatar
Oddometer: 257
Soldering the wires in worked a treat.
For those attempting this down the road, a few thing I learned: I had to crank my soldering iron up a bit further than I was comfortable with initially to get the solder in the switch melted. Once I dialed it in, the wires just popped right out. Still, the whole thing was an exercise in balance between keeping things hot enough to prevent a cold solder joint, but cool enough to not melt the plastic housing. The plastic didn't come away unscathed, but it worked nonetheless and saved me a hundo. Thanks.
Old 10-20-2012, 11:04 PM   #8
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,621
Hella made them to BMW spec, a looong time ago in a furrin land.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Times are GMT -7.   It's 04:59 PM.
