Old 04-30-2013, 11:35 AM   #196
LandsVW OP
LandsVW's Avatar
Oddometer: 296
owners manuals for a bunch of Honda vehicles
I found an Australian site with owners manuals - including one for a 1985 XR600R!
here's the link:
http://www.hondampe.com.au/repositor...torcycles.aspx
It helped me quite a bit figuring out how to adjust the rear suspension. All the other info I found online was for the later bikes.
hope this helps someone...
(I ignite the engine)
(and ride into the sunlight)
(My dust-trail never quite catching me) -LFN 2008
http://advrider.com/forums/showthread.php?t=835547
LandsVW is offline   Reply With Quote
Old 05-15-2013, 08:13 AM   #197
Bmblbee
Dust Monkey
Oddometer: 27
Talking What a great thread this has been
I'm looking at a solid running '85 XR600, and reading this thread today made me want the bike even more.
Bmblbee is offline   Reply With Quote
Old 05-15-2013, 09:31 AM   #198
LandsVW OP
LandsVW's Avatar
Oddometer: 296
Thanks for the interest!
That is awesome! these old bikes are not perfect but certainly well worth the fixing up. I contrast a 10,000$ KTM to a 1000$ old Honda and find that the over all fun factor is pretty similar. Plus, the added excitement of 'is something gonna blow' (or start, LOL) gives it just that much more in the adventure category. I've put about 300 miles on mine, and a few issues have come up but I'm working through them as time allows.
Old 05-15-2013, 11:01 AM   #199
elsalvadorklr
southern xr rider
Oddometer: 4,154
good job bud! enjoy!
elsalvadorklr is offline   Reply With Quote
Old 09-17-2013, 09:54 AM   #200
LandsVW OP
LandsVW's Avatar
Oddometer: 296
Thumb recent events in the XR600 saga
I have noticed that the bike continues to burn oil pretty badly, seems to have rather low compression and has a lot of piston slap. Nothing has come apart and it runs good. I am worried it will self destruct so I quit riding it in June and started saving my money for an top end rebuild.
UPDATE as of September! my brother in law found a wrecked 87 ( a friend had hit another friend on a 4-wheeler - bent forks, and rear suspension has torn the frame at the attachment point) that has a rebuilt engine. I got it for 200$.
It has great compression. It was sitting for a while so I didn't even try to start it with its original carbs. I currently have the engine out of the frame. I'm swapping the electronics over and will reinstall in my bike later this week.
Can't wait to ride!
Old 09-22-2013, 02:36 PM   #201
LandsVW OP
LandsVW's Avatar
Oddometer: 296
'new' engine installed
I installed the better engine yesterday. Several issues. Drain plug was stripped. Helicoiled it. Removed side cover to flush the aluminum chips and found the small oring between the the case and cover was mangled. also, banjo bolts only had 1 copper gasket each. Adjusted valves. All were tight.
Anyway, started right up! Checked oil pressure to head, and took it on a 10 mile ride with no problems!
Doesnt have the thin metal gasket between valve cover and head. I hope that doesn't cause me grief. Prior owner rode it a lot so here's hoping.
Not super impressed with the rebuild, careless builder fwit. But she's alive and sounds very tight.
Old 09-22-2013, 03:42 PM   #202
mcma111
mcma111's Avatar
Oddometer: 11,876
There is a reason Honda made that gasket steel. It acts as a spacer for the cam center journal. This is from a XR600 I worked on recently.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 09-22-2013, 03:59 PM   #203
LandsVW OP
LandsVW's Avatar
Oddometer: 296
Clear message!
Gotcha I have one hanging on the wall. I will replace it before I start it again. And pray the journal isn't already doa. It changes valve clearance too, right?
Old 09-22-2013, 04:07 PM   #204
mcma111
mcma111's Avatar
Oddometer: 11,876
Yes it does. You will need to apply sealant to the gasket or it will leak like a pig.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 09-25-2013, 12:41 PM   #205
LandsVW OP
LandsVW's Avatar
Oddometer: 296
I will... most likely will get to it this weekend. The XR600 can have the valve cover removed w/o removing engine, correct?
Old 09-25-2013, 01:08 PM   #206
mcma111
mcma111's Avatar
Oddometer: 11,876
Yep
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 09-25-2013, 02:50 PM   #207
Mike the Yank
Oddometer: 389
Cool2
You have to take carb intake off first.
It's a lot easier to apologise than to ask permission
Mike the Yank is offline   Reply With Quote
Old 09-26-2013, 09:20 PM   #208
LandsVW OP
LandsVW's Avatar
Oddometer: 296
I did some google research and have also come to that conclusion. Argh.
Oh well, Saturday is 24 hours long...
Old 09-28-2013, 01:27 AM   #209
Mike the Yank
Oddometer: 389
I spent a couple of hours trying to get it off without removing carb and intake, thought I might save you some furstration.
Did get the cam out without removing the gear, not so hard when you don't care!
Old 09-29-2013, 04:06 PM   #210
LandsVW OP
LandsVW's Avatar
Oddometer: 296
removed the cover, and found this:
There WAS a gasket, SMH. However, this little plug had obviously been bouncing around in the galley/valves/ who knows where, for who knows how long... The plug is in the end of the Camshaft so unless this is an extra, that's not it. Could it have travelled up to the head from somewhere else?
Times are GMT -7.   It's 10:05 AM.
