Old 01-18-2014, 11:20 PM   #226
Big Tall Bastard
Voice of Reason
Oddometer: 331
Lands
I'll let you know what I find after I talk Mike tomorrow. Thanks Steve, check arriving shortly
Current rides: 07 Aprilia Tuono R, 87 XR600R (Hell Yeah!)
Some of bikes owned in the last few years: 2007 990 Adventure ,2001 Aprilia Mille RSV, 2000 XR 650 R, plated Sold (what a dumbass) 2001 CR500R, 2001 Cagiva Gran Canyon
Big Tall Bastard is offline   Reply With Quote
Old 01-22-2014, 10:02 PM   #227
LandsVW OP
LandsVW's Avatar
Oddometer: 305
More pieces parts and handlebars.
(I ignite the engine)
(and ride into the sunlight)
(My dust-trail never quite catching me) -LFN 2008
http://advrider.com/forums/showthread.php?t=835547
LandsVW is offline   Reply With Quote
Old 01-25-2014, 05:19 PM   #228
LandsVW OP
LandsVW's Avatar
Oddometer: 305
Boiled carburetors
Boiled me some carburetors today. Seems like it did the job 1:1 ratio simple green to water. High heat for 1 hour. Outside on BBQ grill burner. The slide on the primary carb was stuck in. after this procedure was perfect.
Old 01-26-2014, 08:05 AM   #229
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,081
Got a set of carbs off ebay that both slides were stuck, and of course was not stated in the description. I tried the pine sole soak to no avail, but I didn't heat it up. Ended up re-selling them, but I actually listed then as stuck...
Carter Pewterschmidt is offline   Reply With Quote
Old 01-26-2014, 11:53 AM   #230
LandsVW OP
LandsVW's Avatar
Oddometer: 305
Laugh Carb recipe
Yeah I recommend boiling them. Even in hot water might do it, but I bought a gallon of simple green and have used it for 3 carbs so far. It might mess up the gaskets and rubber pieces so take as much of those off as possible before the treatment. I think there is 1 plastic piece at the top of the slide that I couldn't get out with the slide stuck. It didnt seem to damage that.
They come out looking pretty.
It made the neighborhood smell like simple green. I was worried the cops were gonna arrive thinking I was cooking up drugs on the back porch!
"no, officer, just boiling carburetors, honest"
Oh yeah if a wife/gf is in your life, don't boil indoors, lol.
Old 01-26-2014, 06:05 PM   #231
LandsVW OP
LandsVW's Avatar
Oddometer: 305
Together.
Old 01-26-2014, 07:12 PM   #232
Clif
GoEasyStepLightlyStayFree
Clif's Avatar
Oddometer: 355
The new bike looks good w/ the gold wheels.
Always liked that color scheme
Clif is offline   Reply With Quote
Old 01-26-2014, 08:48 PM   #233
LandsVW OP
LandsVW's Avatar
Oddometer: 305
Thanks! I had the gold rims from the first bike. The white framed bike had silver rims but a red tank and no fenders. The color scheme is accidental but becoming original! The front fender is actually an XL so slightly different. Side panels are white tho, so won't be quite the same as factory.
It's been very therapeutic to figure out what's next, go dig around in the parts drawers or boxes, fix or clean that item and bolt it on.
For what it's worth to all: I have available an original XL600 front brake caliper and hose/line set. I've got a XR600 one heading my way, cheaply, from another inmate so would just like to break (no pun intended) even. PM me for details.
Old 01-29-2014, 10:15 PM   #234
LandsVW OP
LandsVW's Avatar
Oddometer: 305
Getting there
Kicked it a few times and not much yet. Gas flowing to the carbs, but haven't explored spark yet. Took a picture and went in for the evening. :)
Old 02-01-2014, 02:18 PM   #235
LandsVW OP
LandsVW's Avatar
Oddometer: 305
Almost!
Been working on it today. No spark. Since I still have multiple electronic parts I started swapping things around. Finally had spark after a cdi swap!
Fire in the hole! Loud backfire so far and then I came inside to eat some curry...
Must. Make. Bike. Run. Today...
Actually the next project is to weld the kickstand so it can come off the bike lift and roll outside.
Old 02-01-2014, 04:42 PM   #236
LandsVW OP
LandsVW's Avatar
Oddometer: 305
Starts!
It Runs! It's only idling tho no throttle at all. When throttle is twisted bike dies. I let it idle for about 5 minutes with some seafoam in the gas tank and then turned it off... Obviously still has some carb issues. Starts and idles ok tho.
Never too many Hondas in the garage!
Old 02-01-2014, 09:17 PM   #237
LandsVW OP
LandsVW's Avatar
Oddometer: 305
Almost there
Now that i know i have all the pieces and a complete bike - My immediate goal is to get the brakes working, get the carbs recleaned or adjusted and maybe some front fork maintenance including boots.
Test and Ride.
Long term is piston and bore to stop the oil burning and piston slap (this was the original engine out of my good bike).
Ride some more.
It will be good to have around for friends and relatives to ride.
I did take the other BRP around the block just because, today.
Old 02-01-2014, 09:23 PM   #238
Big Tall Bastard
Voice of Reason
Oddometer: 331
Nice work even if it won't run above idle!
Old 02-01-2014, 09:26 PM   #239
LandsVW OP
LandsVW's Avatar
Oddometer: 305
It's in safety mode.
Old 02-01-2014, 09:26 PM   #240
Big Tall Bastard
Voice of Reason
Oddometer: 331
Some stuff I no longer need for the 87 XRR
I've got the stock forks, stock upper and lower triple, a set of bars and stock rear shock that I no longer need. I'm not looking to get much out of them. Send me a PM and we'll work something out.
Times are GMT -7.   It's 09:39 PM.
