Old 02-01-2014, 08:27 PM   #241
Big Tall Bastard
Voice of Reason
Oddometer: 339
Originally Posted by LandsVW View Post
It's in safety mode.
Nice!
Current rides: 07 Aprilia Tuono R, 87 XR600R (Hell Yeah!)
Some of bikes owned in the last few years: 2007 990 Adventure ,2001 Aprilia Mille RSV, 2000 XR 650 R, plated Sold (what a dumbass) 2001 CR500R, 2001 Cagiva Gran Canyon
Big Tall Bastard is offline   Reply With Quote
Old 02-01-2014, 08:28 PM   #242
Big Tall Bastard
Voice of Reason
Oddometer: 339
I just realized I didn't put this in the XR thread but in your thread! And I'm only on my second beer.....
Old 02-01-2014, 08:29 PM   #243
LandsVW OP
LandsVW's Avatar
Oddometer: 323
Probably a good thing tho. I jumped on it, forgetting that the front caliper isn't connected (steve is sending a brake line) and the back wasn't adjusted. Rolled down the driveway and gave it gas...
Really glad it quit running at that point... I was just starting to freak out realizing my slight miscalculation.
(I ignite the engine)
(and ride into the sunlight)
(My dust-trail never quite catching me) -LFN 2008
http://advrider.com/forums/showthread.php?t=835547
LandsVW is offline   Reply With Quote
Old 02-01-2014, 08:32 PM   #244
Big Tall Bastard
Voice of Reason
Oddometer: 339
Wheelie! No brakes! Neighbors yard excursion!
Old 02-01-2014, 08:32 PM   #245
LandsVW OP
LandsVW's Avatar
Oddometer: 323
Ha! And I just replied to it too...SMH. I think MY carb is a little wonky. Carry on everyone - Back to your regularly scheduled XR channel
Old 02-01-2014, 08:35 PM   #246
LandsVW OP
LandsVW's Avatar
Oddometer: 323
Brakes on an XR600 are overrated
Old 02-08-2014, 02:34 PM   #247
LandsVW OP
LandsVW's Avatar
Oddometer: 323
Question Brakes and a question
I got my front brakes (thanks Steve) installed and bled. Used a syringe and little hoses and finally got the air out.
Adjusted the back brakes too. Here's where I found an issue.
The rear sprocket is too big. Probably close to 55+ teeth. It has the chain going through the lower guide and coming out at an angle. It has worn through the guide to the point that the rear lower guide bolt is being hit by the chain.
Would it be ok to take the black plastic piece out of the guide and run it that way, or is the chain liable to jump if I do that? Any other recommendations?
Old 02-08-2014, 04:07 PM   #248
mcma111
mcma111's Avatar
Oddometer: 12,552
Buy a correct sprocket.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-08-2014, 05:04 PM   #249
LandsVW OP
LandsVW's Avatar
Oddometer: 323
"Buy a correct sprocket." What I figured...
On a positive note, cleaned main jets in both carbs. Left was dirty. Upon reinstall and 1 1/2 pilot jet set the bike runs well at any RPM! Got to ride around the block a couple of times. Then, brought it in, removed seat, installed new tank strap, and am in the process of shoe gooing the split seam on the seat.
Pretty much have it ready for short local rides. Still burns oil and has piston slap but better than a pile o parts and a bent frame.
Will be a good bike for casual knock around riding though still plan on piston upgrade later when money is not an issue.
Thank you Steve and Chris for parts and help.
Perfect saturday !
Old 02-16-2014, 09:07 PM   #250
LandsVW OP
LandsVW's Avatar
Oddometer: 323
Final product
tail light, a set of acerbis guards (used - 2 sets off Craigslist for 20$), decent front tire, tool bag (1$ from a thrift store).
Still need my fork boots.
Old 02-16-2014, 09:10 PM   #251
LandsVW OP
LandsVW's Avatar
Oddometer: 323
Old 02-16-2014, 11:22 PM   #252
LandsVW OP
LandsVW's Avatar
Oddometer: 323
Question Leftovers
My Leftovers XL600 and XR600. See something you need? PM me.
- as pictured. This is 1985-87 stuff..
headlight xr
cylinder head xl bad with 3 good valves
tripletree top xr
brake caliper and hose xl
choke lever and cable xl
cam sprocket xl/xr ?
engine mounting bolts xl and/or xr
brake (foot) lever xl ?
wrist pin xr - (scored)
manifold gasket xl/xr
triple tree top nuts probably xl but...
handlebar clamps xl/xr
timing chain guide xl
front axle clamp xl/xr
wire guide under tank xl ?
muffler to headpipe clamp xl/xr
front wheel speedometer hub xl/xr
weighted bar ends xl
oil line clamp to engine xl/xr
Some of this I don't even know why I have it.
I think maybe my parts XL had another donor box along with it?
Why, for example, do I have 2 extra sets of handle bar mounts? No idea...
LandsVW screwed with this post 03-09-2014 at 10:15 AM Reason: Updated list
Old 02-20-2014, 07:47 PM   #253
LandsVW OP
LandsVW's Avatar
Oddometer: 323
My two xr600r's, both 1986, are 908 units apart on serial numbers. Thought that was kind of interesting. Probably made the same week.
Old 03-04-2014, 09:00 PM   #254
LandsVW OP
LandsVW's Avatar
Oddometer: 323
Red bikes
Today I changed the front fork oil in the 2nd XR600. Then I mowed the lawn. It's spring!
I realized I have a bunch of red bikes in the garage so had to take a picture.
Old 03-08-2014, 04:56 PM   #255
LandsVW OP
LandsVW's Avatar
Oddometer: 323
Bike 1 ride today
Into an abandoned nickel mine - have to go back, couldn't find the right trail. Got to the tailing piles on the edge tho. 45 miles round trip.
LandsVW screwed with this post 03-09-2014 at 10:03 AM Reason: Misspelling
Times are GMT -7.   It's 05:08 PM.
