Old 10-22-2012, 11:30 AM   #31
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,143
Originally Posted by boxerboy81 View Post
I get about 15kpl which is 57kpg or 35.5 mpg.
Needles and needle jet changes?
How much has renewing these improved anyones mpg?
How often should they be changed? Mine have done 80K kms.
Bet they are plenty worn in 80k km's. I replace mine every 30 to 40k miles. At the same time I do normal carb dissassembly and maintenance. I tend to see a 3mpg jump when retuned with new jets and needles. Cleaner running plugs as well.
DoktorT is offline   Reply With Quote
Old 10-22-2012, 12:03 PM   #32
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 47,598
I get better mileage riding two up. Pollobabe will hurt me if i am noot smooth.
Uncle Pollo is offline   Reply With Quote
Old 10-22-2012, 12:31 PM   #33
supershaft
Oddometer: 9,110
Jet needles and needle jets? I renew them when I can see/feel a wear ridge on the needle. How many miles? There should not be a mileage figure set in stone since it all depends on what model carbs you have. The jets in carbs that have the spring clip last at least three times longer than the jets that have the C-clip. I suspect because the spring clip keeps them from vibrating as much. I buy these tiny little wavy washers to put on top ot the C-clips. They fit right in between the clip and the hold down and keep the needle much more secure. I am not sure but I think they last about as long as the needles held in place with the clips.
Most I have fixed report back a couple to 5mpg better.
Old 10-23-2012, 11:58 AM   #34
More_Miles
über-n00b
More_Miles's Avatar
Oddometer: 312
All over the map
Being the data hound that I am, I keep a running log on all my fuel purchases. Also, since building report engines for the data analysts at work is my bread and butter, I make pretty pictures of it as well. Here's a graph showing the fuel consumption over a five day trip I took in the end of September from NB to PA.
Here's the high and low lights of the trip:
  • Best fuel consumption: 5.21 l/100 km (45.1 Miles/US Gal)
  • Worst fuel consumption: 6.75 l/100 km (34.8 Miles/US Gal)
  • Average fuel consumption: 5.76 l/100 km (40.8 Miles/US Gal)
  • Number of fills: 10
  • Max distance on a tank: 375 km (234 miles)
This was a combination of Interstate (110-140 km/h actual) country road (50-90 km/h actual) and suburban (0-50 km/h actual) riding. My bike is a 1983 R100RT that is bone stock. The interesting thing is the nearly 10 MPG swing based strictly on riding style.
Once the snow flies, and I'm bored at work sometime this winter, I plan on plotting out the whole riding season's fuel consumption. I suspect that the plot for that will look a lot like the one for this trip. Just smoother.
Can you tell I don't want to be working?
Larger than life and twice as ugly!
My photos: stewie.smugmug.com
More_Miles is offline   Reply With Quote
Old 10-23-2012, 02:13 PM   #35
squish
Out of the office.
Oddometer: 6,161
'83 R80ST Low to mid 30s or ~120 miles to reserve (Single petcock)
'86 R80 Mid to high 30s ~140 miles to reserve (Both petcocks on both switched to R)
'92 R100GS Mid 30s ~140 miles to reserve (Both petcocks on both switched to R)
I weigh around 210 with my kit on, I normally don't have side bags on any of the bikes and the GS has a stock screen, top box and BMW brush guards. I run the windscreen in the most raked back toward the rider postion.
Bike are single plugged and otherwise stock in the induction and exhaust departments.
I use the lowest grade gas ~89 and I get my gas from either a Chevron station or a 7-11 station.
Tire pressure is 32 fr 34 rr check pretty often.
On vacation for a spell
squish is offline   Reply With Quote
Old 10-23-2012, 04:38 PM   #36
chasbmw
Oddometer: 2,117
Twin plugged R90/6. Best is 60 mpg (imperial)
1070 bike. Best is 50mpg imperial
Charles
1971 Commando Fastback
Old 10-23-2012, 06:28 PM   #37
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,188
I don't keep records so I don't know. It's not great I think, I do mostly short trips.
I did replace the carburetors on my R90/6 just this week with another pair I've had for many years. I don't know why but I never could get this set of carbs to work very well and never left them on. I found a couple of problems, mainly the jet needles were on the first notch, and figure this might be why they never worked right. Have been adjusting them the last coupe of days and think I almost got it.
---Albert Einstein
Old 10-26-2012, 09:03 PM   #38
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,324
25 on a bad good day....35 on a good good day....
Of course that's on three wheels and a ton of crap aboard
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 10-26-2012, 09:12 PM   #39
Tripletreat
Oddometer: 566
My 1983 R100RS consistently returns around 45 mpg (US). I suppose that's partially due to my conservation riding style and the dual plugged heads. As far as I know, the needles and related jets are original to the bike. I'm the 2nd owner, having bought it from a friend. I have new needles but I can't find a reason to install them.
I love my 1983 R100RS! I believe it's one of the best BMWs to ever roll out of the factory.
For all we know, this may all be just a dream; we come, we go like the ripples in a stream.
Tripletreat is offline   Reply With Quote
Old 10-27-2012, 12:08 AM   #40
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,523
i did a long trip in june, just over 6,000 miles all in. My 100GS PD averaged 51mpg over the whole trip. I believe that's around 42 mpg US. Not too bad considering it was fully loaded.
Rob Farmer is offline   Reply With Quote
Old 10-27-2012, 12:37 AM   #41
darklight79
scaffold builder
Oddometer: 418
So now that they stopped making the pd tank for upgrades ....I seem to be in the low 30s most of the time .... usually wfo ...5k and beyond on a 94 gs
darklight79 is offline   Reply With Quote
Old 10-27-2012, 02:08 PM   #42
supershaft
Oddometer: 9,110
For the most part is all about how you ride. It's funny but economy never even enters my mind when it comes to motorcycles. If it did much at all, I would switch to four wheels or a scooter.
Well . . . that or slow WAY down but why waste a perfectly good motorcycle? IMO, that's what four wheels and scooters are for.
supershaft screwed with this post 10-27-2012 at 03:15 PM
Old 10-27-2012, 02:12 PM   #43
mfp4073
mfp4073's Avatar
Oddometer: 2,368
74 R90/6 with 105k miles, pretty aggressive on the throttles and will pick up 80 regularly during my commutes. Pretty consistantly 39-40mpg.
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline   Reply With Quote
Old 08-14-2014, 07:35 PM   #44
bikecat
bikecat's Avatar
Oddometer: 1,115
Hiya,
My R100R is showing a poor mileage of about 29.5 mpg(US) or 35.3 mpg(UK).
My riding pattern is a daily commute of about 10 miles each way, I usually rev at about 3500 to 4000 rpm and change gear at about 3000. There is a rough spot at about 3000 but it smoothens after that.
The carbs are balanced, and the jets cleaned. Doe any one have a clue as to what I can do to make the consumption better? To me it seems that there is something wrong if my mileage is so poor.
Thanks.
bikecat is offline   Reply With Quote
Old 08-14-2014, 07:42 PM   #45
danedg
Horizontally Opposed
Oddometer: 6,537
Originally Posted by bikecat View Post
Hiya,
Thanks.
Replace your jet needles and your needle jets. Your mileage will improve.
Just a reminder, ride every chance you get. You just don't know how soon it can be taken from you. T.Low
danedg is online now   Reply With Quote
Times are GMT -7.   It's 08:05 AM.
