10-21-2012, 04:59 PM
#1 |
Oddometer: 43
Oil everywhere! HELP...
This is never a good ending to a ride...
![]() So i need some help to trouble shoot why the back half of my bike is covered in engine oil. As you can see my beemer is not exactly stock. There's no air box and the crank case breaths via a small K&N filter. Yesterday a mate borrowed the bike and called about 20 minutes later when he stopped and found oil all over the backend. It didn't take me long to find where the oil was coming from, yep, the crank case breather had excreted it. Thank god he stopped when he did because quite a lot of the oil ended up on the back wheel. Note to self: BUILD A CATCH CAN But why would this happen? How can i trouble shoot this? I've pulled the plugs thinking Rings but they look perfect. Any ideas?
'92 R100R |
10-21-2012, 05:03 PM
#2 |
In need of repair
Oddometer: 1,438
Does it smell like gearbox oil? There is a bolt at the top of the gearbox. I've had that loosen (forgotten to tighten it) a few times & the gearbox is good at spitting oil out of that - makes a hell of a mess.
10-21-2012, 05:38 PM
#3 |
Oddometer: 43
Na i don't think so. I had the crank case breather filter under the starter cover and that's where all oil has come out. I can see it's flowed out of that hole on the left side of the case that goes into the starter housing.
'92 R100R |
10-21-2012, 06:45 PM
#4 |
Oddometer: 84
I know it might sound like a stupid question, but has your mate overfilled it with engine oil?
On my bike, i never fill it up to the max fill line on the dipstick as it will always end up venting into the RH carb.. or in your case the back wheel. I always fill it to about 3/4 up the dipstick marker.. no further.. reading taken with the dipstick unscrewed and resting on the filler hole.
http://www.travelblog.org/Bloggers/A...he-flying-aga/ |
10-21-2012, 06:54 PM
#5 |
Oddometer: 43
not a stupid question at all, i asked him exactly that. But he didn't and it's been fine for the last 2K km's i've done on it so i don't think that's an issue. Thanks though...
'92 R100R |
10-21-2012, 07:23 PM
#6 |
More tacos than you
Oddometer: 5,128
Did you fill the oil up to the full mark on the dipstick? (or farther?) Also, there's a small drainback hole just under the breather valve in the bottom of the condensing tunnel on the top of the crankcase. If that tiny hole gets blocked the tunnel fills with oil. Pull your breather valve and verify that the drain is open.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
10-21-2012, 08:02 PM
#7 |
Oddometer: 43
thanks, i'll check that out tonight
'92 R100R |
10-21-2012, 08:04 PM
#8 |
because I can
Oddometer: 6,088
I fill my crank full to the full mark and rev my engine to 8k all the time and I never have more than just a little bit come out of my crank vents. I have still never noticed any airhead engine stop using oil or stop blowing a small bit out the crank vent at the half way mark or even at the add mark. I am keeping my eyes open since tons report just that.
10-21-2012, 10:04 PM
#9 |
Oddometer: 720
snap....
![]() we pulled the gearbox out and the flywheel off.....not the main seal... eventually found the culprit.... ![]() had a sort of bodged silicon gasket.... Interesting comment earlier about oil level.... What I think happened was at high revs ( its a race bike) the breather tube to catch bottle filled up and dripped out via the 'gasket' into the clutch......grrrr. |
10-22-2012, 12:41 AM
#10 | |
Oddometer: 43
'92 R100R |
10-22-2012, 01:03 AM
#11 |
Oddometer: 43
Got a feeling my clutch has copped some oil too. I wasn't riding but my mate that was said it felt like the clutch was slipping.... great!
'92 R100R |
10-22-2012, 02:01 AM
#12 | |
Oddometer: 43
'92 R100R |
10-22-2012, 02:24 AM
#13 |
Oddometer: 1,116
I've seen the oil spew out of the breather once ( not on my bike) but only when the rings were shot and pressurising the crankcase.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. Bertrand Russell |
10-22-2012, 03:45 AM
#14 |
Oddometer: 43
That's exactly what I hope it's not. I guess a compression test will tell all?
'92 R100R |
10-22-2012, 04:44 AM
#15 |
Oddometer: 1,116
I guess, but a leak down test would be better.
