Old 10-22-2012, 06:39 AM   #1
Mikey10000 OP
Oddometer: 29
The Cases are Split!
I finally got the cases split on my 1150 to replace the broken rails. The rails had broken and the timing chain had ground down the chain tensioner piston enough to make it start flying around the inside of the engine. What a mess!
I now have a couple of questions on reassembly.
1. what is used to seal the halves back together, and is it BMW specific.
2. Do i need new crankshaft rear seals ( I assume So )
3. How do I drive the new seals back in
I just need to order the parts now and reassembly can begin.
Mikey10000 is offline   Reply With Quote
Old 10-22-2012, 10:17 AM   #2
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,555
Check here
http://www.maxbmwmotorcycles.com/fic...9&rnd=08102012
Lists all the lubes and sealants BMW recommends. I bet Locktite has similar. Call a couple of dealerships and see what they recommend.
[SIZE="3"][/SIZE]
scooteraug02 is offline   Reply With Quote
Old 10-24-2012, 06:01 PM   #3
cardoctor1
cardoctor1's Avatar
Oddometer: 546
look thru the old threads i seem to remember another inmate doing the same .
IBA#35592
RIDE EVERY RIDE LIKE ITS YOUR LAST
00 R1150GS
cardoctor1 is offline   Reply With Quote
Old 10-25-2012, 04:00 AM   #4
krellheat
Pepsi Challenged
krellheat's Avatar
Oddometer: 2,120
I used two peiced of electrical pvc piping. its grey in color. cheaply available at lowes.
This is the rear of an 1100 case with two oil seals.
Front seal, same idea.
The BMW sealant is Hylomar rebranded. get it through Max or Amazon.
[SIZE=2] [FONT=Arial][SIZE=2][COLOR=red][B]Just remember, once you're over the hill, you begin to pick up speed.
[/B][/COLOR][/SIZE][/FONT][FONT=Arial] [/FONT][/SIZE] [FONT=Arial][SIZE=2][COLOR=Red][B]Devil's advocate. Hell conscientious and informed and downright argumentative dissenter.[/B][/COLOR][/SIZE][/FONT]
krellheat is offline   Reply With Quote
Old 10-25-2012, 04:03 AM   #5
krellheat
Pepsi Challenged
krellheat's Avatar
Oddometer: 2,120
Hylomar Universal Blue
http://www.hylomarsealant.com/
Also rebranded at Permatex
Old 10-25-2012, 04:04 AM   #6
krellheat
Pepsi Challenged
krellheat's Avatar
Oddometer: 2,120
I prefer this version in the yellow box direct from Germany.
http://www.hylomar.com/index.php?opt...d=62&Itemid=70
Old 10-25-2012, 05:49 AM   #7
JLeather
Bike Butcherer
JLeather's Avatar
Oddometer: 298
Looks like ThreeBond 1194. That's what I use on all my other engines. Haven't split apart a BMW yet, but any similar semi-drying case sealer ought to be fine.
JLeather is offline   Reply With Quote
Old 10-25-2012, 06:35 AM   #8
krellheat
Pepsi Challenged
krellheat's Avatar
Oddometer: 2,120
I used threebond in snowmobile engines with no issues. The hylomar is easier to clean off later as it always stays flexible.
Old 10-25-2012, 08:46 AM   #9
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,537
From my BMW REPROM;
Assembling engine block
Clean and degrease sealing faces (arrow)
and coat with 3-Bond 1209.
def is offline   Reply With Quote
Old 10-25-2012, 08:55 AM   #10
def
def's Avatar
Oddometer: 10,537
From your question regarding the sealant to use, I assume that you do not have the BMW factory repair manual and your deep into your boxer engine.
The factory repair manual has a lot of information, necessary for what I would deem the successful reassembly of a boxer engine.
Torques, clearances, assembly suggestions, fluids, sealants and other critical details are contained therein.
I would procure the manual before going further.
Old 10-25-2012, 10:51 AM   #11
mike54
You don't get me
mike54's Avatar
Oddometer: 13,308
You're no fun.
A genius is the one most like himself. - T. Monk via S. Lacy
[URL="http://www.advrider.com/forums/showthread.php?t=666576"]Do stand up guys lie?[/URL]
mike54 is offline   Reply With Quote
Old 10-25-2012, 11:38 AM   #12
Mikey10000 OP
Oddometer: 29
I have the manual and the haynes, I just find it better to get more realistic views from people that have done it on older bikes. there are also so many varieties of the sealant and just wanted to go to Napa or a local store and pick one up.
I appreciate all the replies, just the kind of stuff I was looking for, especially the poor mans seal driver from krellheat.
Old 10-25-2012, 12:27 PM   #13
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,666
Real destitute men use an empty coke can with the end cut off.
[URL="http://www.gsshop.biz"]www.gsshop.biz[/URL]
Steptoe is offline   Reply With Quote
Old 10-25-2012, 01:50 PM   #14
Mikey10000 OP
Oddometer: 29
i like it, is that for the inside seal?
Old 10-26-2012, 06:32 AM   #15
def
def's Avatar
Oddometer: 10,537
Mickey, are you documenting with photos and plans to post once you're done? Hope so.
I would be interested to see the old chain rails as well as hear to what extent the broken bits were distributed throughout the engine.
Times are GMT -7.   It's 04:51 AM.
