Old 10-22-2012, 08:33 AM   #1
txbear55 OP
Oddometer: 266
Mellow out the 990?
I guess a question for the engineers....CJ? Has anyone considered modifying to a heavier flywheel to mellow out this rip snorting beast? Back in my enduro days Moose Racing had a mod to a heavier flywheel for the motocross bikes. It smoothed out the power delivery, esp. when you came "on the pipe". Seems like it would sure make the 990 more controllable in technical sections. Thoughts?
txbear55 is offline   Reply With Quote
Old 10-22-2012, 08:43 AM   #2
Qwik
Adrenaline Addict
Oddometer: 6,834
Much easier to just go down one tooth up front. These are sedate machines at partial throttle
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 10-22-2012, 10:10 AM   #3
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Laugh It's Mellow Yellow, not Orange
You aren't going to be adding any weight to the 9x0 Lc8's flywheel/rotor w/o lots of work. And you're not adding anything to the crankshaft itself unless you're in the crankshaft business
2-strokes have a different arrangement that allow you to add a balanced disc to the outside of the ignition/charging flywheel. LC8's don't share this arrangement at all...
Perhaps a G2 throttle cam w/changeable profiles will help with throttle control.
If the bike is too peaky for your liking then go UP (not down) a tooth on the front sprocket- going down allows the engine to rev up faster while adding a tooth does the opposite.
Just put her in 3rd gear & lug it to keep from breaking the rear tire loose
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 10-22-2012, 10:17 AM   #4
Martynho
No more Chilegringo.
Oddometer: 408
The engine is not the issue in the technical stuff, its the weight of the damn thing . Like the man said, to tame the engine just lug the engine a bit.
Having said that the main solution to all your ills in the rough stuff is to do just the opposite, keep focused on where you`re going a long way out, keep her spinning up and point her in the right direction. She will take care of the rest
Martynho is offline   Reply With Quote
Old 10-22-2012, 10:35 AM   #5
geometrician
let's keep going...
Oddometer: 1,026
+1.
She's a beast to get used to in slow stuff, but have faith in the chassis & she'll amaze you what she can do. There were a few moments when I was new to her I thought I was in trouble but I just kept her pointed where I wanted to go and she had no problems... once you get used to the bikes performance envelope & abilities you'll understand why the Orange Koolaid is so tasty for us!
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
Old 10-22-2012, 10:53 AM   #6
txbear55 OP
Oddometer: 266
Just brain stormin'....Monday morning and all! Thanks for the thoughts!
Old 10-22-2012, 12:23 PM   #7
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,122
As mentioned earlier, old school Moto dudes (and those on a budget) ran taller gearing to keep the wheel from spinning up, in low traction conditions. Keeping the RPM down meant they didn't get on the pipe until they were well out of the hole in the corner, keeping the drive on the ground instead of spinning it into the air.
Your 950 will do the same thing, just with an upshift. Riding a gear high and staying smooth on the throttle, lets the momentum take over. This momentum is what will carry the weight of the bike through/over the obstacle.
snowhawk jockey screwed with this post 10-22-2012 at 12:43 PM
snowhawk jockey is offline   Reply With Quote
Old 10-22-2012, 12:40 PM   #8
zen rider
veteran rider
zen rider's Avatar
Oddometer: 207
I did put on a g2 throttle cam (400 SIZE) to soften the first 25% of the throttle opening as it was jerky at very low RPM. While this was really a fueling issue, the throttle cam softens the problem acceptably.
I added a Steahly flywheel weight to my two stroke KTM 300XC to mellow and add traction. As another person stated this is simple and cheap on a 2T. Not as common as it once was though.
Kevin
'12 DL650 Adventure black Russell seat; '05 TTR250; '13 Zuma 125
zen rider is offline   Reply With Quote
Old 10-22-2012, 01:02 PM   #9
Black Hills
Oddometer: 1,235
I was able to get decent results with the powervalve adjustment/springs on the 300, did iyou try that as well?
Black Hills is offline   Reply With Quote
Old 10-22-2012, 01:56 PM   #10
DuctTape
Oddometer: 351
Rekluse!
You spend more time riding and less time fighting her which adds a lot of miles to your ride since you're not nearly as tired at the end of the day.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 10-22-2012, 02:59 PM   #11
geometrician
let's keep going...
Oddometer: 1,026
Originally Posted by DuctTape View Post
Rekluse!
Once the Rekluse engages it's still the same engine you're dealing with.
Auto-clutches save your left forearm from abuse & offer better starts on hills if you stop- but it's still power/gear selection in the end. Plus you lose closed- throttle engine braking when the RPMs drop below engagement point, as well as the ability to bump-start the bike
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
Old 10-22-2012, 03:16 PM   #12
robdogg
turnip truck driver
robdogg's Avatar
Oddometer: 1,768
good point.. but I guess it really depends on what the OP is really after. An autoclutch does wonders in tight technical stuff as it makes your beast nearly stall proof. I find that most people have trouble maintaining good throttle/clutch control when the going gets rough.. like riding along a rocky section, up on the pegs, and your front wheel hits a boulder and instead of feathering the clutch a little and blipping the throttle, your reaction is to pull the clutch in all the way and you kill your momentum, and the motor stalls, and the next thing you know, your dropping your mammoth steed on the rock tops. So if that's the concern for the OP, an autoclutch, and maybe smaller CS would definitely help IMO.. I wouldn't waste money on a G2 throttle tube.. those are useful on an explosive small bore two stroke, but IMO, the big KTM twin spins up rather slowly already.. heh
Personally tho, I'd ride it like it is, and just give it a lot more seat time.. and something some folks rarely do, practice practice and practice.. even in flat space like a parking lot.. do some slow speed drills.. they will work wonders on your confidence in handling and throttle/clutch control
"ride hard, live righteously"
robdogg is offline   Reply With Quote
Old 10-22-2012, 04:03 PM   #13
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,818
This is not completely true.
I rarely lose engine braking- I have to be close to a standstill- really- like falling-over slow. And in anticipation of installing on a 990, I asked Rekluse about the no-bump-start idea.
While true on my 525, it won't be on a 990. The Rekluse 990 uses a replacement clutch slave that has the adjustment the Rekluse requires. On the 990, it's easy (like turning an allen screw easy) to return the clutch to manual performance, providing bump-start capability.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 10-22-2012, 04:10 PM   #14
DuctTape
Oddometer: 351
I disagree, you are able to go a lot slower then a stock 990 with greater control even in 2nd gear and as for the deceleration all you need to do is blip the throttle and she engages and slows you down. As for bump starting you are able to bump start the newer Rekluse.
I say this from experience and not from something I've read.
I too thought "I don't need no stinkin Auto Clutch" but now that I have one I can go places I couldn't before. Find someone that has the newer version and take it for a spin, you'll be impressed with the transformation.
2010 Ducati 1198S
Old 10-22-2012, 09:20 PM   #15
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
You could always unplug the octane wire and run 87 octane gas. Depends on the A/F map. Some say it makes things worse. On some bikes it just takes the edge off. It's free, so worth a try.
tahoeacr is offline   Reply With Quote
Times are GMT -7.   It's 08:02 PM.
