Old 11-28-2012, 04:08 PM   #1
jonz OP
Miles are my mantra
jonz's Avatar
Oddometer: 1,698
How do I remove the 950SE front brake pads
Howdy gang,
I'm pretty sure I did this before but this time, I can't get the lower brake pad retaining pin out. Unlike the ADV, the SE has a single spring clip and is not shown in the KTM repair manual. I've pulled the single spring clip out of the retaining pin (rod?). The pin wiggles a bit back and forth, and turns but won't come out. I'm pushing the pin towards the spokes.
What am I doing wrong?
Do I just need a bigger hammer?
JONZ
KTM 950 SE, KTM640 ADV ( Hibachi, risen from the ashes)
KTM520EXC (broken), KTM 400XC (the replacement)
Honda ST1300 ABS (newest addition to the stable)
STOC #326 IBA #217
jonz is online now   Reply With Quote
Old 11-28-2012, 04:15 PM   #2
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 571
Bigger hammer
The pin has a spring clip around it that holds it place besides the pin thats thru it. You just need to tap a little harder
dogsslober screwed with this post 11-28-2012 at 04:36 PM Reason: added photo
dogsslober is online now   Reply With Quote
Old 11-28-2012, 05:29 PM   #3
jonz OP
Miles are my mantra
jonz's Avatar
Oddometer: 1,698
Thanks. The bigger hammer theory worked.
Sent from my DROID X2 using Tapatalk 2
JONZ
STOC #326 IBA #217
Old 11-28-2012, 05:46 PM   #4
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 828
A little high temp silicone grease on the pin when reinstalling helps
the pads slide. I also brush a light coating on the piston where it contacts the back of the pads.
Max
Da oggi la strada
é senza limiti
MAXVERT is online now   Reply With Quote
Times are GMT -7.   It's 05:48 PM.
