Old 10-23-2012, 06:39 AM   #16
ebrabaek OP
Oddometer: 4,709
Originally Posted by runnin4melife View Post
Are the rings going to hold your brake cables? I am not quite sure how you routed yours but with mine they have a decent range of motion just on the street so make sure you provide as smooth of a guide as possible because they will be traversing it a lot.
That is the plan....... I did not want to route them MX style, but I want something that is going to keep the lines away from the wheel. We shall see after working them today....
Erling
Old 10-23-2012, 10:12 AM   #17
runnin4melife
Oddometer: 803
So since today was my first legitimate ride after feeling fairly certain nothing would break I popped a few wheelies. Everything held up fine but I did notice something. You might want to take this into account for your brake line guides. During full travel the lower part of the upper fork gets way down there. I got low enough that it torques my cable guides from a 90' angle to a vertical 45. This wasn't too bad but it needs to be fixed to remedy wear and tear.
runnin4melife is offline   Reply With Quote
Old 10-23-2012, 01:30 PM   #18
ebrabaek OP
Oddometer: 4,709
I will have a look. I have not even gotten there yet, but the rings will wrap around the fork, and the looooooong ovals, will house the cable....
Erling
Old 10-23-2012, 01:31 PM   #19
ebrabaek OP
Oddometer: 4,709
Viola....... dos Moulds, ready for their first cast...... Getting exciting now......
Erling
Old 10-23-2012, 07:14 PM   #20
ebrabaek OP
Oddometer: 4,709
He he.........
Erling
Old 10-23-2012, 07:26 PM   #21
runnin4melife
Oddometer: 803
Looks great, how rigid do they feel?
Old 10-23-2012, 07:37 PM   #22
ebrabaek OP
Oddometer: 4,709
Just for kicks, I used the HTE, which is by far stronger that any other epoxy. They are stiff, but if you kick them, they will hit the fork. but I mean kick..... Under any riding conditions, they will not bang up the fork. Remember CF is flexible, yet torsionally stiff, and strong....., but unless you honey comb it, it will flex, which is good. Every bit as stiff, as your ufo's. I might trim it a little, depending on what daylight brings. Cool thing about CF.....is that you can always add a layer or two, if you want.
Erling
Old 10-23-2012, 07:39 PM   #23
ebrabaek OP
Oddometer: 4,709
Ended up with 3 layers of 6 oz 2x2 twill, with 3 extra strips about 1.5 inches wide to strengthen the mounts. The fork hardware had to be remade, as it did not work as I thought.
Erling
Old 10-23-2012, 07:49 PM   #24
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,475
Laugh
Sweet... another great project!
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Old 10-23-2012, 07:51 PM   #25
ebrabaek OP
Oddometer: 4,709
Thank you sir.....
Erling
Old 10-23-2012, 08:12 PM   #26
greenthumb
b00b
Oddometer: 193
Are there the final product or just the moulds? It says moulds, but they are all mounted up. What's the purpose of making a cf set of moulds as opposed to using the steel mock ups as the mould?
greenthumb is offline   Reply With Quote
Old 10-23-2012, 08:27 PM   #27
ebrabaek OP
Oddometer: 4,709
The steel ones were to make the shape...... The moulds in the picture above, serves as a cast, so every time I want to make a copy, I just lay up a composite matrix in the mould above, and after curing.... I have another set. Sort of like how you bake a cake...... the mould is the steel pan you bake the cake in.....
Erling
Old 10-23-2012, 09:09 PM   #28
Natnewt
Natnewt's Avatar
Oddometer: 485
Very nicely done
1980 XR80s Deceased, first ever teardown.
1987 XL185s Deceased, at the bottom of the ocean.
1985 750 Interceptor Sold still alive somewhere.
2006 XR650L heavily farklefied Tendering in the garage.
2012 F800GS Triple Black Let the mods begin.
Natnewt is offline   Reply With Quote
Old 10-23-2012, 09:18 PM   #29
ebrabaek OP
Oddometer: 4,709
Originally Posted by Natnewt View Post
Very nicely done
Thank you sir.......
Erling
Old 10-24-2012, 04:22 AM   #30
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,600
your bike is becoming a sexbomb. Very nice work
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is offline   Reply With Quote
Times are GMT -7.   It's 06:20 AM.
