Old 10-28-2012, 07:26 PM   #46
ebrabaek OP
Oddometer: 4,826
Originally Posted by runnin4melife View Post
Looks good! I will have my fork guards complete later this week. I just have to sand the last one down but am pretty busy so it may be delayed. It is not like I will have a chance to ride for the next week so it isn't too pressing. Will that tape unwrap after a while due to adhesive degradation? The spiegler lines I got have an extra thick coat to help with wear/tear but that may be something I look into.
I guess you could mount an umbrella on the bar..... The spiral wrap is actually nylon morphed as a .......uhhhmmmm... slinky........ No adhesive, but great friction. You just coil it around the line, and it stays in place......
http://www.homedepot.com/h_d1/N-5yc1...1#.UI3oGYaVz6U
I primarily put it on as a safety measure, until I know the function of routing...... and as a savior of the brake line. Mine is heavy SS braided with rubber outer as well, but I figure 3 bucks is good insurance, until I figure all is working well......
Erling
Old 10-29-2012, 05:54 PM   #47
ebrabaek OP
Oddometer: 4,826
Put 300 miles.... over half in the dirt, with several full stroke on the front, crazy climbs...... and all held up. I will post a link to the vids a bit later, but had to share the pink oak foliage.......
Erling
Old 10-30-2012, 01:34 PM   #48
runnin4melife
Oddometer: 806
Notice any wear/tear or excess rubbing on the lines?
runnin4melife is offline   Reply With Quote
Old 10-30-2012, 04:14 PM   #49
ebrabaek OP
Oddometer: 4,826
I literally parked it last night......went to take the RV in for a bulletin, so I have not dove in yet, But It looks like the right tape got some issues..... I will post up later tonight, or tomorrow.
Erling
Old 10-30-2012, 04:15 PM   #50
ebrabaek OP
Oddometer: 4,826
Got some serious beating yesterday...... This is one of many vid's from yesterdays ride. More can be found at my youtube channel link at the bottom.....
http://www.youtube.com/user/ebrabaek?feature=mhee
Erling
ebrabaek screwed with this post 10-31-2012 at 04:11 PM Reason: you tube link
Old 10-31-2012, 04:07 PM   #51
ebrabaek OP
Oddometer: 4,826
After close inspection, I have decided to take off the left 1/2 inch spiral wrap, as after mega dirt, and sand came in there, it started twisting, and had too much Resistance. I will admit to that it got some serious beating for over three hundred miles.... But never the less, it had to go. Also shortened the bottom clamp 8 mm to bring the line.... in uhhmmmmm line.. It does create a small bend at the banjo, but at full stroke, they were off ( top and bottom slider). Other than that even after a few hundred miles in the dirt, some at high speed, no rocks went higher than the skid plate.... Have me rethinking the half fender protecting the radiator...... Hmmmmmmm......
Erling
Old 10-31-2012, 04:16 PM   #52
runnin4melife
Oddometer: 806
You were thinking about doing a half MX style fender mounted to the triple?
Old 10-31-2012, 06:22 PM   #53
ebrabaek OP
Oddometer: 4,826
Yes...... And thus making it from scratch. Not really needed in my case, as the panzer case reaches up high...... Almost to the starter...... But just in case...... I'm thinking in that direction.
Erling
Old 11-02-2012, 02:40 PM   #54
ebrabaek OP
Oddometer: 4,826
Ended up re-making the lower brake line bracket. I did not like the cable pinch the straight bracket yielded. So a new quick cast was made....
And with the new 90 deg. bracket....all is again well..... New on the left... Old on the right.
Erling
Old 12-15-2013, 04:08 PM   #55
ebrabaek OP
Oddometer: 4,826
So this other build kind of ties into this build, so why not put the pictures in there...... ehhh... OK.... Front half fender....to catch the gunk.
Erling
Times are GMT -7.   It's 02:47 AM.
