Old 10-22-2012, 02:24 PM   #1
headtube OP
6 mesas de invierno!
headtube's Avatar
Oddometer: 322
Changing the oil filter
In the photo below is a new and old filter. When I removed the old one I noticed there was no metal ring. Previous owner hack! I'd like to know if the new filter pictured can be installed "without" o-rings? There were no o-rings when I dismantled the pieces. Also, just to be certain, what is the sequence of install on the parts... filter, metal ring, white o-ring, gasket?
Here is a so-so pic of the bike. A little over exposed on the bottom and under exposed on the top. The sun was streaming into my garage. Better pics to come. It's getting there.
headtube is offline   Reply With Quote
Old 10-22-2012, 02:31 PM   #2
craydds
craydds's Avatar
Oddometer: 1,167
I just did mine. Let me see if I have some pics that show any detail. Otherwise, it's:
1) oil filter goes in (I like to rub a little oil on the rubber gaskets and the o-ring)
2) metal "washer" goes onto the outer lip of the canister
3) white "o-ring" goes in
4) outer metal filter cover goes on
Look here: http://largiader.com/tech/filters/canister.html
Some of the newer bikes have a canister that does not require the metal "washer". See Anton's information
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 10-22-2012, 02:37 PM   #3
craydds
craydds's Avatar
Oddometer: 1,167
I have some pics starting with post #41 here: http://www.advrider.com/forums/showt...=818377&page=3 .
Don't know if that helps.
ABC #12947
'75 R90S
Old 10-22-2012, 02:39 PM   #4
mykill
odd
mykill's Avatar
Oddometer: 1,166
Really need to know the year bike from the OP before giving advice. earlier models with the sharp-lipped canister need the metal, later with the rolled edge do not.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 10-22-2012, 02:44 PM   #5
headtube OP
headtube's Avatar
Oddometer: 322
Year is 1979
Old 10-22-2012, 02:47 PM   #6
craydds
craydds's Avatar
Oddometer: 1,167
What year is your bike?
ABC #12947
'75 R90S
Old 10-22-2012, 02:48 PM   #7
craydds
craydds's Avatar
Oddometer: 1,167
beat me to it! anyway, does your canister have a rolled lip or a straight edge?
ABC #12947
'75 R90S
Old 10-22-2012, 02:52 PM   #8
headtube OP
headtube's Avatar
Oddometer: 322
Where do I look for this? Inside the filter cavity?
Old 10-22-2012, 02:55 PM   #9
craydds
craydds's Avatar
Oddometer: 1,167
Yes, it's the internal "can". Look at the pics, see if that makes it clear.
ABC #12947
'75 R90S
Old 10-22-2012, 03:06 PM   #10
headtube OP
headtube's Avatar
Oddometer: 322
Perhaps you can tell me? I bought a new ring to install. Seems logical that I would need one with a gap at the opening of the canister wall, but this is new to me. The white o-ring that I removed looked "pinched" from this gap.
Old 10-22-2012, 03:09 PM   #11
craydds
craydds's Avatar
Oddometer: 1,167
Yes! You need the metal "washer" placed onto the canister. This protects the white o-ring from being cut. Then place the o-ring onto the metal washer, followed by the outer cover.
ABC #12947
'75 R90S
Old 10-22-2012, 03:13 PM   #12
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,552
Not exactly the same as yours as it has an oil cooler, but it's not THAT different either.
Shamelessly stolen from Anton's excellent writeup on the subject. Go read it:
http://www.largiader.com/tech/filters/canister.html
and this...
When you're done reading those THEN go change your oil filter. RTFM, as they say.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler is online now   Reply With Quote
Old 10-22-2012, 03:43 PM   #13
Mike V.
Mike V.'s Avatar
Oddometer: 66
Be sure to measure the canister edge depth to engine block face accurately with a depth gauge or like tool. Anton has a nice easy-to-read table regarding the shimming process. I prefer using Oak's 10% to 25% O-Ring compression formula. i.e.;
O-Ring + Metal Shim - Cover Gasket (if used) - canister depth / O-Ring x 100 = % O-Ring Compression.
Constants:
O-Ring = 4.0mm
Metal Shim = 0.3mm
Cover Gasket = 0.5mm
Canister depth = To be measured
Any doubts regarding the dimensions of the above parts should be checked with a micrometer.
You should only have to measure the canister depth once every few years since it shouldn't move.
If less than 10% or more than 25% O-Ring compression; adjustments are needed.
Remember the cover gasket for the 77 and later models is not used to seal the canister for external leaks. The O-Ring does the sealing and depending on your cannister depth measurement the cover gasket may not be needed.
Mike V. / San Diego
1978 R100/7 (original owner)
1981 R65 (fully restored)
ABC-MOA-AMA-VBMWMO
http://tinyurl.com/4df7hgs
Mike V. is offline   Reply With Quote
Old 10-22-2012, 04:54 PM   #14
craydds
craydds's Avatar
Oddometer: 1,167
+ 1 on the above. See my pictures on the $2000 o-ring (referenced above).
ABC #12947
'75 R90S
Old 10-23-2012, 02:31 PM   #15
headtube OP
headtube's Avatar
Oddometer: 322
Thanks for your help guys. My canister depth requires a gasket. Off to the next task!
Times are GMT -7.   It's 11:13 AM.
