Old 10-22-2012, 02:29 PM   #1
BykBoy OP
Meshuganeh
BykBoy's Avatar
Oddometer: 561
KTM 990 Transmission modification
Prognosis: The ADV has lot's of power but the current gearing is a compromise. With stock sprockets (16 front - 42 rear), 1st gear is not low enough for off road, and 6th gear does not get great fuel mileage.
Of course, I know changing the front and rear sprockets can give more low end torque or high end fuel economy. But this impacts all gears, so it doesn't really solve the problem.
A few years ago, there was a mod kit for the 1100/1150 GS that lowered the 1st gear ratio to provide more low speed torque. Is something like that possible on the 990 transmission? Has anyone considered or heard about modifying the transmission ratios on the 990/950 on the main and counter shafts to make 1st gear is lower and/or 6th gear is higher?
We have many talented and creative individuals and fabricators here (I'm looking at you CJRacer, Sakurama, BDCW, Touratech, and others...). So come on, there must be a way to do this...
Save $5 when you open a SmugMug account. Use the following coupon: 4l1hicJzWvYNE
BykBoy is offline   Reply With Quote
Old 10-22-2012, 09:09 PM   #2
mousitsas
mousitsas's Avatar
Oddometer: 2,993
SMT gear ratios....
Old 10-23-2012, 07:32 AM   #3
BykBoy OP
Meshuganeh
BykBoy's Avatar
Oddometer: 561
Well, it looks like the ADV and SMT have the same ratios. The Super Duke's ratios look to be higher throughout the range and would probably not fit in the ADV.
.................ADV.......... SMT.........Super Duke
1st.............12:35........12:35........14:36
2nd.............15:32........15:32........16:30
3rd.............18:30........18:30........20:30
4th.............20:27........20:27........21:27
5th.............24:27........24:27........23:26
6th.............27:26........27:26........25:26
Primary.......35:67........35:67........35:67
Secondary..16:42........17:41........16:38
I wonder if the 6th gear sprockets can be swapped so that instead of 27:26, 6th gear would become 26:27. Anyone have a spare gear box laying around?
BykBoy screwed with this post 10-23-2012 at 07:49 AM
Old 10-23-2012, 08:25 AM   #4
mousitsas
mousitsas's Avatar
Oddometer: 2,993
They don't according to this:
gearingcommander.com
Old 10-23-2012, 09:16 AM   #5
howl
990 Adventure
howl's Avatar
Oddometer: 98
http://advrider.com/forums/showthread.php?t=835224 Looks like the SM gears do fit but higher ratios
howl is offline   Reply With Quote
Old 10-23-2012, 09:16 AM   #6
BykBoy OP
Meshuganeh
BykBoy's Avatar
Oddometer: 561
You're right. According to gearningcommander.com, the 2007 950 SM (R) has 26:27.
Question is: will they fit the 2011 990 ADV?
Old 10-23-2012, 10:12 AM   #7
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,034
As The Gears Turn...
We have many talented and creative individuals and fabricators here (I'm looking at you ...Touratech...)
Touratech? You mean the German manufacturer & distributor of (overpriced, questionable) accessories with 135 total posts as a Vendor? Don't think they do much transmission work!
Go faster in 6th or drop her into 5th... as for 1st not being low enough offroad, I'm not sure what you're talking about...
Spend some time looking into the (final drive) gearing threads OC has with lots of info & experience on this issue
As for the making gears, it's a very complicated & precise set of operations that requires proper machining & grinding of the shaft bore, teeth & gear dogs/mating holes followed by proper hardening & heat-treating. Contact REISHAUER or similar if you're interested but it's gonna cost you big bucks- plus you'd have to supply an entire transmission for mating. Considering they set up assembly lines for GM, Toyota, etc I don't think they're gonna be interested. You could try smaller custom gear manufacturers but most of them are geared (excuse the pun) towards auto transmissions for drag/road-racing applications and are set up w/tooling for a market with 100's of sales a year, not just your two gears. You're looking at the far side of a thousand dollars, easy.
In the end "poor fuel economy" in top gear vs. the cost of the all the seals & gaskets, donor gearbox/custom gears, etc over the life/miles of the bike isn't cost-effective.
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 10-23-2012, 11:57 AM   #8
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,326
I understand what you are trying to do.
A change to 26:27 would give you less gear than your current Adventure 6th?
The major reason why I took the Super Duke gearing out was that its 1st is higher and 6th lower than the Adventure gearbox. If I sprocketed for low speed stuff, the higher speed cruise was compromised and visa versa.
Your Adventure gearing is currently the widest spread of gearing on any of the LC8 engines. In other words you'll not get a lower low or a higher highest gear in any other model LC8 Engine unless you get custom made gears made$$$$.
You seem to be looking to gearing to solve a consumption issue. Sadly these engines are not known for their efficiency so do what I did....
Get bigger tanks!
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya is offline   Reply With Quote
Old 10-23-2012, 01:25 PM   #9
BykBoy OP
Meshuganeh
BykBoy's Avatar
Oddometer: 561
You are correct. Going with a 26:27 would give me a .962 ratio, while the current 27:26 setup has a 1.038 ratio. Not sure what I was thinking...
To get the desired improvement, I would need a 28:25 and it would cost $$$$!
Get bigger tanks!
I've been thinking about these... I would love to get a set, but they are so expensive! On the flip side, they do provide lot's of surface area for stickers...
Old 10-23-2012, 02:03 PM   #10
tahoeacr
tahoeacr's Avatar
Oddometer: 2,212
First go here,
http://www.efi101.com/efi101.html $500.00 plus hotel(two day class)
then buy this,
http://www.summitracing.com/parts/INN-3806/ $479.00 plus tax
And this,
http://www.cjdesignsllc.com/products...r-ktm-engines/ $63.00
There you go. The tools to get 50+ mpg and it's cheaper than even standard gears.
tahoeacr is offline   Reply With Quote
Old 10-23-2012, 02:10 PM   #11
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,126
Originally Posted by tahoeacr View Post
First go here,
then buy this,
And this,
Nice package you identify there, Tahoeacr! Have you changed any injectors or added secondary injectors to your own setup?
snowhawk jockey is online now   Reply With Quote
Old 10-23-2012, 02:11 PM   #12
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 10,316
I hope you sell it dirt cheap when you are done screwing it up.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 10-23-2012, 02:32 PM   #13
tahoeacr
tahoeacr's Avatar
Oddometer: 2,212
Still stock injectors. Don't have em maxed out yet. Heck, their probably at less pulse wideth than an Akra map.
Old 10-25-2012, 07:11 PM   #14
sakurama
on an endless build
sakurama's Avatar
Oddometer: 1,493
While I appreciate the faith gear cutting is some serious stuff and way over my head. Expensive too. As was mentioned your best bet is to see about swapping ratios around but the mileage thing - that's trying to put lipstick on a pig. This bike can pass anything on the road but a gas station.
Gregor
sakurama is offline   Reply With Quote
Old 10-25-2012, 08:23 PM   #15
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,329
First go here,
then buy this,
And this,
That is so cheap compared to some of the classes I have to attend. All that together is cheaper than a quarter of college.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns is offline   Reply With Quote
Times are GMT -7.   It's 10:33 PM.
