Old 10-23-2012, 10:39 AM   #16
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,200
Originally Posted by photorider
Next, the mixture screw. Our carbs are different than the CV Bings most other BMW's have.
And remember, the mixture screw is actually an air screw in that it regulates the air into the idle mixture with the fuel being set by the idle jet, and it works oppositely compared to a fuel mixture screw-- turn-in= richer turn-out=leaner
Originally Posted by motocyco
I don't run premium but all the pinging has been at low rpm and big throttle.
That is where pinging is supposed to occur--low rpm/big throttle.
You need to run Premium-- the bike was designed for that grade of gas. If you want/need to run regular, you need to install low-tes base gaskets to lower the compression ratio.
--Bill
'73 R60/5 Toaster
Old 10-23-2012, 11:33 AM   #17
motocyco OP
nOOb
Oddometer: 555
I need to fill up on the way home. Guess I it's a good time to switch to premium.
'12 Kawasaki Voyager 1700
motocyco is offline   Reply With Quote
Old 11-08-2012, 04:01 PM   #18
motocyco OP
nOOb
Oddometer: 555
Parts finally arrived today. Hopefully I can get some time over the holiday weekend to wrench on the R60.
Old 11-12-2012, 01:20 PM   #19
motocyco OP
nOOb
Oddometer: 555
Today I got a chance to work on the bike. Changed and adjusted the floats, changed the needles, re-balanced the carbs, and played with the idle mixture screw again. I think the floats were too low. Not sure the mixture is right, I should probably re-read the procedure and try again.
I only got out for a short test ride, so I won't get a better idea how much it has changed until I can get in a longer ride. Maybe on the ride to work tomorrow. However, my seat-of-the-pants dyno says it runs better. I ran 75 for about half a mile without any trouble, but it still seems like it's screaming it's heart out. Acceleration felt a little better; faster than an XT225 but definitely slower than an 883.
Old 11-12-2012, 02:07 PM   #20
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,970
I didn't know the Mix Screw on an R60/6 was actually an Air Screw. I have no experience with the smaller motors but I have a Bing manual. I thought I would give you some of the info in their manual. You may at some future date wish to change things but it is helpful to know what Bing says.
The carb numbers on an R60/6 are......1/26/123 & 124
They are type... 53 carbs
Main Jet is...140
Needle Jet is...2.68
Idle Jet is...40
Jet Needle is...234
Clip position is...2
Idle Mix Setting is...1
Good Luck with it.
---Albert Einstein
disston is online now   Reply With Quote
Times are GMT -7.   It's 12:08 AM.
