Old 10-27-2012, 09:44 AM   #16
Peanuts
Peanuts's Avatar
Oddometer: 1,032
Yeah, the spacer is thicker. The brake caliper bracket is thinner on the later bike.
Peanuts is offline   Reply With Quote
Old 11-13-2012, 03:22 PM   #17
the foolish fellow
UP FOR IT
the foolish fellow's Avatar
Oddometer: 127
Send a message via Skype™ to the foolish fellow
Change the spacer over when changing the wheels.
I use 950 discs on my 990 off road wheels . On the front I got the disc machined in order to take the abs ring flush. The back ring only requires bolting on. I ordered a full set of 990 disc bolts from Ktm .
990 adv
850 Le mans
Gl 1000
X5 3.0d
FE 450 BERG
the foolish fellow is offline   Reply With Quote
Old 11-14-2012, 08:38 AM   #18
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,162
Just a thought, if you disable the ABS when riding off road then just use the stock 950 wheels for your off road set, that way you wont have to worry about the ABS since there will be no tone ring on the wheels.
I used to be able to disable the ABS with a washer, finally just got a second set of wheels without the tone ring etc. Then ended up removing the abs completely.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
WWW.DSM8.whereamiriding.com
DSM8 is offline   Reply With Quote
Times are GMT -7.   It's 02:19 PM.
