Old 10-23-2012, 02:40 PM   #1
headtube OP
headtube's Avatar
Oddometer: 135
Gluing the rubber fork boots to the fairing
Since I've had the fairing off the bike to do some minor repairs (a bit of fibreglass), I need to glue the fork boots back in place. What product does the forum use to keep those pesky boots (cups) from flopping about? When applying the glue do you place it on the boot, or the fairing? Or both? This could be messy.
headtube is offline   Reply With Quote
Old 10-23-2012, 03:05 PM   #2
Rob Farmer
Rob Farmer's Avatar
Oddometer: 3,733
Bathroom sealing silicone has always worked well for me. I use the clear stuff and squeeze it into the bead of the boot. Wipe off the excess with a wet finger, the rest will dry transparent, leave it overnight before you use the bike.
Rob Farmer is offline   Reply With Quote
Old 10-23-2012, 06:27 PM   #3
DaveBall
DaveBall's Avatar
Oddometer: 919
I have replaced lots of these. they can be a royal paint to get on properly. I heat the edges up a bit with a hair dryer so that they are a bit more pliable, get them in place in the fairing. Once I am certain that they are seated properly, I use a cotter pin removal tool to lift the edge on the inside of the fairing and put a few drops of the gel Gorilla Glue in there, then let it sit over night. Then using a very sharp razor blade I remove any excess glue that may have squeezed out. This usually will last till the next time I have to remove the fairing and boots.
Lots of people use Crazy Glue and many other types of all purpose glues. I find the real trick is getting the boot seated on the fairing. Sometimes they just don't want to line up correctly with the lip on the fairing into the groove in the boot. This is when a little directed heat can really help.
DaveBall is offline   Reply With Quote
Old 10-23-2012, 07:32 PM   #4
bmweuro
Mad Scientist
bmweuro's Avatar
Oddometer: 2,957
Clean everything very well and Crazy Glue every couple of inches.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
bmweuro is offline   Reply With Quote
Old 10-23-2012, 09:26 PM   #5
R100RT Mark
Oddometer: 208
Permatex 81850 Black Super Weatherstrip Adhesive
I find that Permatex 81850 Black Super Weatherstrip Adhesive works very well. Comes in a 5 oz. tube for about $6.00. It is a traditional contact adhesive type.
I have also used this adhesive with great success to hold together a favorite pair of BMW Sneaker 3 that were coming apart around the shift lever reinforcement – has lasted six months/3,000 miles so far.
Mark
Current Rides: 1974 TR5T : 1993 R100R : 1994 R100RT
Past Rides: 11# 1970s BSA/Triumph Singles & Twins : 2# 1970s CZ 125s : 1985 BMW R65 : 1976 Moby X7
R100RT Mark is offline   Reply With Quote
Old 10-23-2012, 09:28 PM   #6
jdiaz
Oddometer: 31,097
I used gorilla snot (3M something in orange) and it didn't work worth a damn. I never did figure it out before selling the bike.
jdiaz is online now   Reply With Quote
Old 10-23-2012, 11:22 PM   #7
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 1,601
If you use the gaitors on the forks, I'd leave 'em out.
boxerboy81 is online now   Reply With Quote
Old 10-24-2012, 12:33 AM   #8
ME 109
ME 109's Avatar
Oddometer: 605
If the boots are left out, the heater doesn't work as good.
Lord of the Bings
ME 109 is offline   Reply With Quote
Old 10-24-2012, 11:18 AM   #9
AK Bob
AKAM
AK Bob's Avatar
Oddometer: 162
Send a message via Yahoo to AK Bob
Been There
Best stuff I've used so far was " The Right Stuff " from NAPA. It is black too soit looks ok too.
Bob Coleman
AKAM
'84 R100rt
'88 R100gs
AK Bob is offline   Reply With Quote
Old 10-24-2012, 03:16 PM   #10
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,004
Must say that after cleaning all the old goop and glue off mine, then working carefully to roll the boot with very high thumb pressure to fully seat the groove all the way around, they stay in place just fine. Glue just isn't needed IF you get that goove fully seated AFTER you remove all residues of past glue/goop from both the boot and faring.
Very easy to think it is fully on when it is half engaged. Tenacity and technique are required for full engagement, which works just perfect when you get there. Push very hard with thumbs while rolling the edge to get full engagement all the way around the perimeter. No glue needed at all.
DoktorT is offline   Reply With Quote
Old 10-24-2012, 03:37 PM   #11
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 1,601
Maybe, but the aircon is a little more efficient!
Old 10-24-2012, 04:11 PM   #12
Ron Bernert
hiding in plain sight
Ron Bernert's Avatar
Oddometer: 58
3M trim adhesive. Works good for me. I've removed them for fork service, cleaned the grooves and re-applied. Never had saggy rubbers yet.
Got it! Got it! Got it! Don't got it.
Ron Bernert is offline   Reply With Quote
Old 10-24-2012, 05:54 PM   #13
bmweuro
Mad Scientist
bmweuro's Avatar
Oddometer: 2,957
If you only glue them in 6-8 spots they will stay in and you can remove them a lot easier.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Times are GMT -7.   It's 06:29 AM.
