Old 10-23-2012, 05:50 PM   #1
ElRod OP
4<2
ElRod's Avatar
Oddometer: 282
So, I was wondering...
...why my 990 was idling like shit and the fuel mileage was in the toilet too.
The injector nozzles look clean but probably wouldn't be a bad idea to send them out for cleaning / balancing. Anyone know where I can have this done?
Fucking ethanol. Am I pissed? The light from pissed would take two years to reach me I'm so far from that.
ElRod is online now   Reply With Quote
Old 10-23-2012, 06:15 PM   #2
JTXT
Oddometer: 83
Pro Flow has the tools and knowledge to clean your injectors right and they have serviced KTM injectors before.
http://www.proflowtech.com/
JTXT is offline   Reply With Quote
Old 10-23-2012, 06:37 PM   #3
bloc
Oddometer: 158
I'm starting to get concerned about the effects of ethanol on my carbed bike as well.. and keep seeing mention of Sta-bil marine formula.. does this stuff actually do anything?
bloc is offline   Reply With Quote
Old 10-23-2012, 06:53 PM   #4
ElRod OP
4<2
ElRod's Avatar
Oddometer: 282
In my case, no. This is twice now. After the first time I've been running Exxon premium AND Lucas ethanol fuel treatment. I just don't know what to do. Guess I'll try Shell and Star-Tron this time to combat this problem.
Anyone else been using a conditioner that works?
Old 10-23-2012, 07:19 PM   #5
AdvGa
AdvGa's Avatar
Oddometer: 1,320
http://www.advrider.com/forums/showthread.php?t=741228
Here's how to deal with this:
1- I use 93 or 89 Octane "Top Tier" Fuels for they have great Fuel additvies like Techron from Chevron, etc. (more of a chance to little or no Ethanol.)
http://www.seafoamsales.com/gasoline-engine-faqs.html
http://www.toptiergas.com/retailers.html
2- Periodically use SeaFoam or StarTron Fuel Additive (perhaps about 1x month or if Bike is left to sit for more than 2 weeks.
This should mitigate or eliminate your ethanol problems.
http://www.advrider.com/forums/showp...13&postcount=7 -No Treatment -Any Gas
My Carbs at 12k miles with Top Tier Gas & Periodic Gas Treatment/SeaFoam and NOT Cleaned.
AdvGa is offline   Reply With Quote
Old 10-23-2012, 07:23 PM   #6
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,709
Do you think this would qualify as top tier gas?
traveltoad is offline   Reply With Quote
Old 10-23-2012, 07:26 PM   #7
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
ROTFL
tahoeacr is offline   Reply With Quote
Old 10-23-2012, 07:47 PM   #8
ElRod OP
4<2
ElRod's Avatar
Oddometer: 282
No shit !!! That would probably be better than what I've been getting.
Old 10-23-2012, 07:53 PM   #9
#00
#00's Avatar
Oddometer: 29
magna
you should have opted for the MAGNA...
related... I had a 01 Chevy Astro Van with the 4.3 V6 and the throttle body would look like that after about 10k miles. The butterfly valve would get hung up on the crap that built up and you'd have to stomp on the accelerator to brake it free which caused the vehicle to lunge from a stand still. So when I felt that occuring, I'd spray Gumout carb cleaner down the throttle body to clean out the varnish that collected there. Very similar to what you are seeing...
'13 KTM 450 XCW
'11 KTM 990 SMT
'08 Yamaha FJR1300
'01 Yamaha YZ250
#00 screwed with this post 10-23-2012 at 08:23 PM Reason: typo
#00 is offline   Reply With Quote
Old 10-23-2012, 08:03 PM   #10
kingofZroad
kingofZroad's Avatar
Oddometer: 342
Sea foam is AWESOME, I have used it or several years now in bikes. Carbs are clean like the above pictured.
Never used it in one of my bikes, looked like the first picture the other day when I tore into it...
I am even more of a believer now!!
Sent from my iPad using Tapatalk HD
kingofZroad is offline   Reply With Quote
Old 10-24-2012, 02:09 PM   #11
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,197
BG 44K.
It has always worked really for me in whatever vehicle, gas or diesel.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 10-24-2012, 03:48 PM   #12
ElRod OP
4<2
ElRod's Avatar
Oddometer: 282
The map sensor hole on #1 was nearly completely covered, #2 about half. What a mess. I was having trouble balancing the the manifold air pressure in Tune ECU and looking at the throttle plates now that it is apart the #1 plate was having to be opened quite a bit more than #2 to even get it close. To balance I was seeing around 400 - 410 hPa. What kind of numbers are the rest of you getting that have adjusted this?
It'll be a while before I get it buttoned up again as I have to travel to Colorado for my job. I'll let you know how it turns out.
On another note. I did the canisterectomy / SAS a while back and now that I have easy access what is the collectives thought on either running the "S" hose or blocking at each intake runner? I have the S hose arrangement now.
ElRod screwed with this post 11-27-2012 at 03:38 AM Reason: hPa
Old 10-24-2012, 04:47 PM   #13
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Ktm na
KTM North America invested in a sweet injector tester system. Your dealer can send in your injectors for cleaning/testing & provide you pricing (shipping, etc)
it has a fuel rail with back-lit clear precision-graduated columns that allow you to both observe the spray patterns and the exact amount sprayed over time (useful for matching on multi-cylinder bikes) and uses different parameters/pulse durations to see if any have a "weak" spot of operation.
It's a pretty neat piece of kit, we checked it out at KTM Tech class. It's pretty damn expensive
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician screwed with this post 10-24-2012 at 05:05 PM Reason: clarity
geometrician is offline   Reply With Quote
Old 11-02-2012, 05:00 PM   #14
ElRod OP
4<2
ElRod's Avatar
Oddometer: 282
Back from Colorado for a few days then returning again tomorrow. I removed the MAP sensor orifices today and the photo below shows what they looked like. I've found yet another use for the .010 piece of guitar string some of us use for cleaning the clutch oil jet. I dont know exactly what size the hole is but it's little larger than that. They are currently sitting in a can of carb cleaner at the moment.
Thanks for the tips so far, I appreciate that. I have found someone to clean the injectors plus check the flow and pattern.
No one has yet chimed in on whether or not to plug the ports or run the "S" hose after doing the SAS/Canisterectomy. Anyone?
Old 11-16-2012, 05:11 PM   #15
ElRod OP
4<2
ElRod's Avatar
Oddometer: 282
Back together and it's like having a new bike. I was able to balance the throttle bodies to within a few hPa and set the TPS. It now idles like it should and runs great. One thing I noticed immediately was that on balancing it was down to around 375 whereas before it was 400+. BTW, I removed the "S" hose and simply plugged the SAS ports. All good.
Before this, Nels at 2wheeldynoworks had been helping me sort through some fueling issues. He has been able to remove the off idle snatch and get rid of the hesitation at around 4,500 RPM. Thanks Nels!!! May have a little more to do as it seems lean on top after installing the CPR air filter.
I'm in love with this bike all over again.
ElRod screwed with this post 11-27-2012 at 03:39 AM Reason: hPa
Times are GMT -7.   It's 04:54 AM.
