Old 10-24-2012, 06:13 PM   #1
LanceR75 OP
LanceR75's Avatar
Oddometer: 44
New R75/5 Tuneup: Stange Bing Plug
Starting the resurrection process on the newly acquired 71 /5 and began with rebuilding the carbs when I found a stick, yes, a stick stuck in one of the ports. I know it didn't get there by itself so, I'm wondering why someone would plug it and should it be plugged?
https://www.dropbox.com/s/f8i8y74vzwv72o1/BingStick.jpg
Cheers,
Lance
LanceR75 is offline   Reply With Quote
Old 10-24-2012, 06:26 PM   #2
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,552
Yes, it should be plugged. That's a vacuum takeoff port which comes in handy for carb syncing, but otherwise it should remain plugged. It should be threaded on the inside, so find the right size screw and loctite it in there so it doesn't back out. That's probably why there's a stick in it. Someone noticed in the middle of a ride that their bike wasn't running quite right and on further inspection heard it sucking air because the screw backed itself out with vibration. They probably just plugged it then and there with whatever they could find on the side of the road and forgot about it. Also, the little rubber vacuum caps work nicely there as well.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 10-24-2012, 06:35 PM   #3
LanceR75 OP
LanceR75's Avatar
Oddometer: 44
Ah, thanks for the quick info! I should have it ready to start in a week or so, still waiting for bits.
Cheers!
-Lance
Old 10-24-2012, 09:31 PM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,791
The screw is part # 13 11 1 259 869
The red fiber washer is part # 13 11 1 259 870
You may want to balance the carbs because a stick seldom will stay tight in the vacuum port. (yes, I know this from personal experience) They leak. The OEM set up is great. It works with out Locktight.
---Albert Einstein
disston is online now   Reply With Quote
Times are GMT -7.   It's 04:50 PM.
