Old 10-24-2012, 09:59 PM   #1
Steve G. OP
Steve G.'s Avatar
Oddometer: 7,249
Airhead new valve options
My 91 R100gs, now with 115,000kms, showing no signs of problem, is now showing signs of age,,,,the pushrod seals are leaking fairly regular now. So it's off with the heads and barrel to renew everything. The local airhead guy [Shail's] has all the parts in stock, and I'll do everything no problem. He mentioned that I might want to have a look at the valve guides at the very least. Probably a good idea. So I had a look around at the possibility of a set of new valves. Holy Crap!!! The OEM ones are friggin' expensive, $151 exhaust, and $90 intake, each. This $60 renew of seals could very well grow to well over $750 if machining is needed on the heads.
Are there any other valve suppliers out there besides Kibblewhite's Black Diamond line? What's the feedback on these?
Steve
Steve G. is offline   Reply With Quote
Old 10-24-2012, 10:25 PM   #2
Mark Manley
On my way
Mark Manley's Avatar
Oddometer: 772
When I renewed my valves on my R80GS a few years ago at 100,000 miles I bit the bullet and bought genuine BMW but a friend with a mega high mileage R100, 425,000 miles when he sold it, always used Intervalve from Motorworks and said they were good for 100,000 miles.
If it's in the Touratech catalogue then you don't need it
"You've got to think for yourselves! You're all individuals!"-Brian of Nazareth
Mark Manley is offline   Reply With Quote
Old 10-24-2012, 10:33 PM   #3
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,960
Another interesting thread on the subject. Good Luck.
http://www.advrider.com/forums/showthread.php?t=825135
---Albert Einstein
Old 10-25-2012, 01:36 AM   #4
chasbmw
Oddometer: 2,349
When my 90/6 engine was rebuilt, Jim Cray's recommendation was to bite the bullet and use BMW valves.
Overevving on my other bike did result in a dropped valve, not nice, but I'm fairly sure that it was due to operator error!
At your mileage I would replace the exhaust valves
Charles
1971 Commando Fastback
Old 10-25-2012, 04:07 AM   #5
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,188
Drop the cash and get the OEM valves. Quality valve brands are the Swiss Intervalve and German Elco.
Ya pays your movey, ya takes your chances with economy aftermarket parts...
--Bill
'73 R60/5 Toaster
Old 10-25-2012, 06:30 AM   #6
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,572
--Bill
I agree with you as far as the exhaust valves are concerned as that's a pretty tough punishing application and the welded two piece valve that BMW sells really is the "right" one for that application despite its hefty price. The intake valves have a much easier time and I don't think it's worth paying BMW's big price for those when plenty of aftermarket options are suitable in that application.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 10-25-2012, 08:38 AM   #7
Cordless
Two Wheel Addict
Cordless's Avatar
Oddometer: 2,046
This is almost exactly what Snowbum and some other experts say on the subject. Buy the BMW exhaust valves and then buy other brands such as SI for the intakes.
Cordless is offline   Reply With Quote
Old 10-25-2012, 09:07 AM   #8
Bill Harris
Oddometer: 8,188
Very Good Point. Exhaust, yes. Intake, maybe. Almost 40 years and a couple of top ends and I'm still able to re-use the original intakes.
--Bill
'73 R60/5 Toaster
Old 10-25-2012, 10:13 AM   #9
jimbee
Airhead Intermediate
jimbee's Avatar
Oddometer: 334
Ted Porter uses a different German supplier that he says are good and cheaper than OEM. If you call, they will sell you what they use. Just another option.
R100GS for going far, FZ1 for going fast, TE250 for getting dirty, and DR650 for when one of the others needs work
jimbee is offline   Reply With Quote
Old 10-25-2012, 10:18 AM   #10
Airhead Wrangler
Adios Mexico
Oddometer: 6,572
I think Ted actually buys them from the same factory that makes BMW's valves. I can't remember for sure, but his exhaust valves are a welded two piece design like BMW's. There are remarkably few valve manufacturers out there. Most brands are just rebranded and resold from one of the few companies that actually MAKE valves.
Airhead Wrangler screwed with this post 10-25-2012 at 10:25 AM
Old 10-25-2012, 10:19 PM   #11
Carl
Carl's Avatar
Oddometer: 770
where do you posters get your info!?
A 'few' can be defined as less than four. That leaves three or less suppliers of BMW valves, if discussing airhead cylinder head parts. Where in fact, there is at least five or more manufacturing facilities for airhead engine valves. That is actually a decent amount of suppliers for engine valves to fit an out-of-production engine.
To further, and in a more accurate way, discuss valves they should be reviewed also by material type and not only by 'one piece' vs 'two-piece'. German OEM supplier BMW exhaust valves are made in more than one material combination. For example, in some applications the exhaust valves have one combo for the 30 degree valve design and another for the 45 degree valve design.
Carl
http://www.flyingtpot.com/
Carl is offline   Reply With Quote
Old 10-26-2012, 03:14 PM   #12
bereahorn
Oddometer: 1,071
bereahorn is offline   Reply With Quote
Old 10-26-2012, 04:26 PM   #13
Airhead Wrangler
Adios Mexico
Oddometer: 6,572
I'm not really into splitting hairs here, but since you seem to want to, I said there are "remarkably few." I did not say there are "a few." Also, I'd love to know where "a few" is defined as "less than four." If a few is defined as less than four lets see here: 3: sure that could pass for a few, 2: no that's "a couple", 1: well that's just one. So, really you're saying "a few" means 3. If you have something to add about valves, feel free to add it, if you just want to mince words, then save it.
Also, I wasn't just referring to airhead valves, I was referring to ALL valves. There are not that many companies in the world that make valves, let alone companies IN EUROPE that make valves. Yes, Carl, more than 4, so not "a few" I guess, but fewER than most people would think. Yes, you can find many many brands of valves for sale on the internet, but when it comes down to it, a LOT of those brands are made in the same few factories.
Airhead Wrangler screwed with this post 10-26-2012 at 04:43 PM
Old 10-27-2012, 07:38 AM   #14
Steve G. OP
Steve G.'s Avatar
Oddometer: 7,249
Thanks for the info on valves. Sounds like the OEM valve is the one to go with, should it be worn out. I'm still waiting to get time off work to go and buy an exhaust nut wrench,,,,never been off,,,and yes I've read the exhaust nut threads and have my torch ready. Have the rockers off, really happy at the clean-ness of the top end, you sure can tell the exhaust side has to deal with way more heat, there's a light brown hue up front. Hope to get the right side off tonite if I can get to the shop in time for the wrench.
Old 10-27-2012, 07:46 AM   #15
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,960
I'm not sure I read what you mean to say or you say what you mean? You have the rockers off? And now are going to take the stuck exhaust nuts off? The nuts holding the rockers on are also holding the heads on the cylinders and the cylinders on the block. If you try to take the exhaust nuts off with those nuts off it is very likely you are going to break something. Put the rocker nuts on before you loosen the exhaust nuts. Torque to 25 ft/lbs.
Maybe I miss read what you said?
---Albert Einstein
Times are GMT -7.   It's 02:15 AM.
