03-26-2010, 12:12 AM
#1 |
ADV addict
Oddometer: 271
Happy with your Rekluse?
I'm new to my 990 Adv (Actually pick it up tomorrow...I hope) and am considering a Rekluse along with a 16T & throttle cam to help me get aquainted to our slippery NW trails. Lots of road and track time...not so much in the rocks. I've read good things about them but most of the posts are dated.
Care to share? |
03-26-2010, 01:03 AM
#2 | |
AWD please!!
Oddometer: 3,867
I like mine a lot. I think it's a huge help when the going gets tough. Slippery, muddy, root infested woods around here it really shines. Well worth it in my opinion. I never used one before I put one in the 950. It's like the bike lost 100lbs in the trails. Just concentrate on your line and balance. The LC8 version is the PRO model so you still have full override of your clutch if need be. If you've never ridden w/ one I find it takes about 50 miles to get use to it, then you're good to go. If I can be of anymore help let me know. PM me if you'd like a price, I keep the LC8 version in stock.
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! |
03-26-2010, 02:34 AM
#3 |
Oddometer: 1,574
Yes and No!
There's trade offs with a Rekluse. Parking a bike on an incline (facing uphill or down hill) and losing the ability to push start a bike are two. It will transform your whole off road riding experience. Being able to walk along side the bike as you slowly twist the throttle is a plus for loading it into a pickup. Riding without a functioning slave unit or a broken lever is another. Having one, also makes valve checking problematic, if your used to turning the rear wheel to set TDC. On my 640 I have to use the kick starter or bump the electric starter. daryl |
03-26-2010, 06:32 PM
#4 |
Oddometer: 390
I love my Rekluse.
If you take your Adv into UGLY terrain it's a must have modification. If you're a gravel road kind of guy, don't bother. (btw: nice talking to you on the phone cj, can't wait for the Akra inserts to arrive)
'07 Aprilia Tuono '07 Aprilia RXV 4.5 '07 KTM 990 Adventure '09 Aprilia Mana |
03-26-2010, 07:30 PM
#5 | |
Oddometer: 333
hope this helps. |
03-26-2010, 08:28 PM
#6 |
Roost
Oddometer: 560
Love it.....the 950 is a big bike and in tight woods you have to slow down alot, saves the left forearm
"They've done studies, you know. 60% of the time, it works every time." Brian Fantana My toys: 04 YZ250F 04 950 Adventure S--lost to fire ![]() 06 KLX 110 07 950 Super Enduro http://www.katoom.smugmug.com/ $5 Smugmug coupon: FDURkYt1pFdQw http://www.youtube.com/Katoom950 |
03-26-2010, 09:02 PM
#7 |
Miles are my mantra
Oddometer: 1,710
I haven't ridden with one but if I understand it's operation correctly, when you stall out on a steep hill, the bike will roll back whereas with a standard clutch and engine compression, you have another hand brake. Not a huge consideration but I've used mine a few times in hairy situations and was glad I had the option of using the clutch as a brake with the engine off.
JONZ KTM 950 SE, KTM640 ADV ( Hibachi, risen from the ashes) KTM520EXC (broken), KTM 400XC (the replacement) Honda ST1300 ABS (newest addition to the stable) STOC #326 IBA #217 |
03-26-2010, 09:17 PM
#8 | |
velvet hammer
Oddometer: 176
A non-issue. The bike will not stall if set up correctly. Try to imagine a car with a auto stopped on a hill. Do you need to do anything to stop from rolling backwards? As long as its running the only thing that you have to do is give it some throttle. As a side note it cranks up the probability of wheelies 10 fold. It will make almost any bike highly wheelie prone. That is a huge plus in my book.
All the big dogs plus a few 04' GO!!!!!!!, 9 CR500's, Husky 610, KTM550 MXC. |
03-26-2010, 11:51 PM
#9 |
ADV addict
Oddometer: 271
Thanks guys...it is now on the short list
03-27-2010, 03:40 AM
#10 | |
Oddometer: 1,574
Like someone said...theres no stalling at all, regarding the use of the clutch. However....stalling could occur if for some reason the bike isn't running correctly and dies at idle. This could be the result of bad gas or a fouled plug, etc. If descending a hill using a Rekluse, a slight burp of the throttle and engine breaking can be used with the engine running. If the bike is not running, all engine breaking is lost. Like I said...there are trade offs. daryl dlh62c screwed with this post 03-27-2010 at 04:04 AM |
03-27-2010, 06:20 AM
#11 | |
Oddometer: 1,045
03-27-2010, 07:03 AM
#12 |
Oddometer: 390
On steep slow descents I keep the rear brake covered with my foot and blip the throttle as needed to maintain compression braking. It's a skill you'll pick up quickly.
03-27-2010, 07:15 PM
#13 |
Oddometer: 635
I like mine. Especially in the tight stuff. So my bike is in the shop right now for a valve check. What is the correct procedure for finding TDC with a Rekluse???
2007 990 Adventure Suspension by Super Plush Rekluse Pro Auto Clutch WINGS N.O.S Exhaust Euro Headlight with PIAA bulbs KTM Hard Parts Radiator Cover CJ Racer Clear Spoke Clutch Cover Hilslamer Long Pegs GPR Stabilizer DH Racing tripleclamps '300' Throttle Cam 16t CS Sprocket Mefo "Super Explorers" Ram Mount Garmin 76c PABIKER sidestand relocaton kit. 2007 KTM 300XC (long live lightweight 2-strokes) Las Vegas, NV and the Great Mojave Desert |
03-27-2010, 09:33 PM
#14 | |
Oddometer: 333
03-28-2010, 05:18 AM
#15 | |
Oddometer: 1,574
A common way of setting TDC is to pull the plug or plugs, place the bike in gear and rotate the rear tire by hand. This is not the only way to do it, there are others. You can't use this technique with a Rekluse installed. With the bike not running, any gear its in will feel like neutral. Thats why you loose the ability to push start the bike and need to be careful parking on a steep incline facing either uphill or downhill. daryl dlh62c screwed with this post 03-28-2010 at 05:35 AM |
