Old 10-25-2012, 01:44 PM   #1
Dessert Storm OP
Dances With Drunks
Dessert Storm's Avatar
Oddometer: 803
lubricating switchgear
Indicator button on my XL600 was getting stickier and stickier to operate. Took the switchgear apart, and found that a couple of the white plastic switch parts that contain spring loaded ball bearings which engage with detents in other parts in order to switch left/right/off as required, were filled with crud.
Cleared the crud, but am not sure what to lube the parts with. Thought maybe vaseline, but would that be too sticky?
'You like motorcycles, beer, and ladies. I'm afraid I have the same illness' - Thierry.
Dessert Storm is offline   Reply With Quote
Old 10-25-2012, 02:18 PM   #2
buickid
Lets ride!
Oddometer: 310
I feel like white lithium grease would work well here
2005 Yamaha Zuma YW50, 2009 Kawasaki Super Sherpa KL250
buickid is offline   Reply With Quote
Old 10-25-2012, 02:25 PM   #3
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,759
White Lithium might be too heavy, but it would resist washout real well. I'd try dielectric grease.
Twilight Error is offline   Reply With Quote
Old 10-25-2012, 02:29 PM   #4
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,937
silicone spray to clean with, silicone grease (plumber's grease) to lube.
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 10-25-2012, 02:32 PM   #5
SloMo228
World Class Cheapass
Oddometer: 1,827
I've used dielectric grease for switches before with no problems. It works well. Silicone or white lithium grease as mentioned above would be good too.
--------------------------- Steve----------------------------------------
'96 DR350SE
SloMo228 is offline   Reply With Quote
Old 10-25-2012, 04:03 PM   #6
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 4,020
You can also try the dry lube but the silicon works very very well.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 10-25-2012, 04:54 PM   #7
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,727
My switches are full of Teflon Dry lube, sure nice and smooth. Easy to re-apply as it comes out very thin and seeps in, then dries out leaving the Teflon behind. Does not retain dirt & crud like greases.....I like that very much.
Have tools, will travel!
Old 10-26-2012, 06:02 AM   #8
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,166
The best I have found for switches and pots.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 10-26-2012, 06:36 AM   #9
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,096
I've used the light-weight white grease for bicycle bearings (which might be white lithium as previously mentioned). That said, some sort of dry lubricant might be a better way to go.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 10-26-2012, 07:53 AM   #10
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,767
Dielectric grease
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
sailah is online now   Reply With Quote
Old 10-26-2012, 11:03 AM   #11
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,727
Originally Posted by sailah View Post
Dielectric grease
I wished that BMW would learn to apply that properly in their switches. The way they do it, leaves big clumps that eventually congeal with moisture and grits. Not easy to get into them switches and clean up the mess, lotsa little parts that may just fly off.
Not pretty what some of us have found in them switches after a few hours of surgery. All lubed now with Teflon Dry Lube.....the one I am using is Dielectric. Much easier and faster to reapply through the little holes behind the switch covers.
Old 10-26-2012, 10:13 PM   #12
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,713
Vaseline would work fine, it isn't to far for dielectric grease. I use it on battery posts to stop them from corroding and it works great.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 10-27-2012, 09:18 AM   #13
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,727
Originally Posted by keswind View Post
Not sure if it's the same stuff he's using, but I squirt some Dupont Teflon Chain Lube on my handlebar switches when they seem to be getting sticky. Smoothes them right up.
Lloyds "Non-flammable electrical contact cleaner" first then Lloyds Teflon Dry Lube.Specs are pretty close to the Dupont stuff, I already checked the MSDSs and Technical Application Sheets. Sure loosens up the plastic actuation parts that Teflon. And sometimes them Conformal Coatings for further protection/weatherproofing of electrical parts but them can be pricey, as in over $20.00 a can. Will last me 20 years or so like the last one.
Old 10-27-2012, 10:01 AM   #14
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,648
dielectric grease
+3
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 11-14-2012, 02:23 AM   #15
Billtr96sn
Flange Furtler
Oddometer: 393
Castrol LM, just a finger full.
If you see me coming, better step aside. A lot of men didn't, a lot of men died, all because of my shit brakes.
Billtr96sn is offline   Reply With Quote
Times are GMT -7.   It's 02:53 AM.
