Old 10-25-2012, 04:08 PM   #1
bloc OP
Oddometer: 158
Odd headlight issue
I apologize if this has been brought up before.. I've spent hours looking at wiring diagrams and searching the forums.. not really sure what phrases to use though.
2004 950 Adventure S, euro headlight, no euro light switch.
Intermittently for a while, and now permanently, the headlamp will not come on (regular or high-beam), but the blue high-beam indicator on the dash is staying lit. Doesn't matter what combination of settings you use for the high/low-beam, or high-beam flasher.. condition persists. All fuses good, both the switches seem to be operating correctly. (EDIT: I took the switches apart and no burned contacts, no dirt.. everything seemed fine)
Other than that, the bike starts and runs flawlessly.
Has anyone seen this before? Any ideas for things to check before I start ripping apart the fairings and attack it with a DMM?
Thanks,
-Justin
bloc screwed with this post 10-25-2012 at 04:17 PM
bloc is offline   Reply With Quote
Old 10-25-2012, 04:23 PM   #2
baloneyskin daddy
bikaholic
Oddometer: 2,141
Is it a single bulb set up? If it is the filements are touching each other.
baloneyskin daddy is offline   Reply With Quote
Old 10-25-2012, 04:30 PM   #3
bloc OP
Oddometer: 158
Euro light assembly, separate H3 & H7 bulbs.
Old 10-25-2012, 06:46 PM   #4
AdvRonski
They call me......Ronski
Location: Wishing I was back in Grand Junction, now in MN
Oddometer: 700
Sounds like a problem with the ground circuit.
Ronski
Enduro Racer & Big Bike Adventurer
AdvRonski is offline   Reply With Quote
Old 10-25-2012, 07:30 PM   #5
bloc OP
Oddometer: 158
With the high-beam indicator lighting up, and seemingly independently of the high/low beam settings, it made me wonder if this was some kind of diagnostic or warning light. From looking at the wiring diagrams I can't work out how it would turn on with from a wiring fault unless the dash was doing it for some other reason..
I wish I could find a schematic of the dash.. that would help a ton.
Old 10-25-2012, 08:12 PM   #6
AdvRonski
Oddometer: 700
The reason the high-beam indicator is on regardless of high/low setting, is that without a good ground, the low-beam setting will feed through the high-beam filament, and light the indicator. In high-beam, the indicator is powered directly.
Check that ground circuit!
Ronski
Old 10-25-2012, 08:13 PM   #7
bloc OP
Oddometer: 158
Thanks for the explanation.. I'll check into it tomorrow.
Old 10-26-2012, 08:31 AM   #8
bloc OP
Oddometer: 158
AdvRonski, you called it. The female ground wire pin in the main headlight connector was slightly loose and showed signs of getting a little hot as a result.
Thanks for the help.
Times are GMT -7.   It's 07:40 AM.
