Old 10-26-2012, 09:56 AM   #1
5 speed OP
Oddometer: 940
Off throttle backfire
Hi there. So It took my bike in for a valve adjustment. Generally do everything myself but havent adjusted the valves and figured I would have it done professionally. The bike was at the shop for 4 weeks as I had springs ordered for the front end and also sent my seat out to be redone. I figured the gas may have gone bad but I did have the Marine Stabilizer in it. I sprayed seafoam in the carbs and also ran some through the gas and then rode it about 500 miles. My conclusion because, it idles fine and performs well is that there is an airleak. It backfiring and spitting when the throttle is chopped. I remember putting the carbs in myself once and thought they seated but then took the tanks off and could see through the access panels that they weren't quite right.
So, before I pull the tanks, any ideas of how I might tell where the airleak is coming from (with suspect that it may have to do with the dis/reassembly from the valve job). your thoughts would be appreciated.
5 speed is offline   Reply With Quote
Old 10-26-2012, 11:01 AM   #2
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,122
Did the shop fiddle with your exhaust at all? Air leak there is a sure backfire.
snowhawk jockey is offline   Reply With Quote
Old 10-26-2012, 12:30 PM   #3
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,110
I'd make sure the carbs are seated in the boots, and then I'd be going over the exhausts for cracks/leaks.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 10-26-2012, 01:08 PM   #4
Spiritwalker2222
Oddometer: 112
Check you exhaust header. If the bolt and nut are loose it can cause your bike to bikefire whenever you let off the throttle.
Spiritwalker2222 is offline   Reply With Quote
Old 10-26-2012, 02:45 PM   #5
5 speed OP
Oddometer: 940
Cool I will try those suggestions before I jump on the carbs and report back. Thanks much
Old 10-27-2012, 04:38 AM   #6
DirtyADV
DirtyADV's Avatar
Oddometer: 2,324
Had bad backfiring when engine braking from like 4500 rpm and below.
Carbs were not touched when the bike developed this, found it to be an air leak on one of the hoses on the intake below the carbs that are used when syncing the carbs (smog stuff removed).
Poorly seated or torn intake rubber could probably cause it also.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 10-27-2012, 08:05 PM   #7
5 speed OP
Oddometer: 940
I guess I got ahead of myself. I fired it up in the driveway and it ran and idled fine, no backfiring. So I put it together last night (had not gone so far as pulling the tanks) and today it ran terrific, idled perfect, but still backfires when winding down from about 4,000 RPM. It seems to be the right pipe which is the front cylinder. I checked around the head and the pipe joint and did not find a leak. as far as the carbs i did as much inspection from topside I could and the carbs seem seated (although I have been fooled before on that one). I would say its definitely an airleak.
Old 10-27-2012, 11:12 PM   #8
MrEndo
MrEndo's Avatar
Oddometer: 421
U can spray a carb cleaner like Berryman B12 on the areas you suspect are leaking. If the idle goes up or down it is sucking the spray in through a leak. Be cautios not to spray so much that it is getting sucked in the carb intake. You might need to hold it at a fast idle for best results.
2015 Harley Ultra Limited
2013 350 EXC-F (Wife's)
2008 530 EXC-R/2008 Beta Rev4T
2006 950 Adv S/2002 640 Adv/1970 Yamaha RT1
MrEndo is offline   Reply With Quote
Old 10-27-2012, 11:18 PM   #9
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Intake not exhaust leak
WD40 works just as well & isn't caustic as carb cleaners are
air leak WAY more likely to be the cause than exhaust
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 10-27-2012, 11:31 PM   #10
MrEndo
MrEndo's Avatar
Oddometer: 421
I was suggesting it for an intake leak....
Old 10-28-2012, 05:53 AM   #11
5 speed OP
Oddometer: 940
Yes I will try that and see. I do have a question however, I have noticed that when looking at the slides in the carbs, when pulling the throttle cable one opens slightly sooner than the other, I think the rear carb is opening first. Is that correct?
Old 10-28-2012, 07:13 AM   #12
StmbtDave
AKA Invisible Dave
StmbtDave's Avatar
Location: Loveland, CO summer - Green Valley, AZ winter
Oddometer: 3,031
No, that is not correct. Both should open exactly at the same time and open the exact same amount. What you're seeing may be caused by one of the throttle cables not being seated correctly or as it was in my case, one of the carb diaphrams being torn. I would first check the cables as they may have been disturbed during the shop work.
Dave
Why are we stopping? We don't have time for that!
StmbtDave is offline   Reply With Quote
Old 10-28-2012, 07:34 AM   #13
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,396
Slides are vacuum controlled... butterflies are operated by the cables. All should work identical (for the most part) between carbs. If one of the slides are lagging, it could be hanging up or a vacuum leak or a pin hole in a diaphram or some other small issue could cause that.
Also carb sync could be at the root of the problem.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 10-28-2012, 08:29 AM   #14
geometrician
let's keep going...
Oddometer: 1,026
Air Cut Valve
that's what we're talking about... not trying to set the bike on fire!
on the many bikes that use this CVK carb the air-cut valve diaphragm is the known culprit for backfiring on closed throttle
it's item #34 on the carb parts diagram...
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
Old 10-28-2012, 08:45 PM   #15
K2m
....58....
K2m's Avatar
Oddometer: 2,239
I guess I got ahead of myself. I fired it up in the driveway and it ran and idled fine, no backfiring. So I put it together last night (had not gone so far as pulling the tanks) and today it ran terrific, idled perfect, but still backfires when winding down from about 4,000 RPM. .
When a LC8 is perfectly tuned they do this.
It may be possible to tune it out by changing the Air Leak jet on the ACV (air cut valve) it's on the pilot circuit.
If you wish to explore this option I can help further.
If I understand correctly :-
It came back from the shop popping on decel. ..... Spot on.
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Times are GMT -7.   It's 05:36 PM.
