Old 07-11-2013, 07:20 PM   #1651
lowsid3r
lowsid3r's Avatar
Oddometer: 60
Found a 4mm hex on touratech skid plate frozen in place trying to do an oil change. Can't budge it for my life :(
lowsid3r is offline   Reply With Quote
Old 07-12-2013, 02:29 PM   #1652
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,929
I added new HIDs and a new horn to my GS:
Jim
Old 07-12-2013, 03:01 PM   #1653
Daz the Aussie
Dualsporting Actor
Daz the Aussie's Avatar
Oddometer: 957
Jim
Hey Jim, did you add the 35w or 55w HID's? I had a new set of 35's here in the garage ready to fit to my R1150GS but I also just ordered a pair of 55w units as I think they will be a bigger improvement. Also like yours, they are the ones with the inbuilt ignitors for less bulk of wiring etc on the bike.
Daz.
"We need a new thread for fuel tank capacity bitching." - Super Sneaky Steve
"Where do I go now that I've gone too far?"
My actor site: www.dazbyard.com
Daz the Aussie is offline   Reply With Quote
Old 07-12-2013, 03:21 PM   #1654
JimVonBaden
"Cool" Aid!
Oddometer: 52,929
Daz.
I have the 35 watt. On the Hexhead (canbus) the 35 watt are still much brighter than the stock bulbs, and usually will not cause a lampf (headlight fault). I like the newer kits with the built-in igniters, but still much slimmer.
Jim
Old 07-12-2013, 05:15 PM   #1655
Mastheadmike
Mastheadmike's Avatar
Oddometer: 68
After a little over 1 year since I last rode her...I finally returned to the USA long enough to register her, and gave a nice deep clean to get rid of the super fine desert dust collected under the panels from 6 months hanging out in Bahrain. Then I changed the oil, air filter, checked the tire pressure and went for a little jaunt around town! In the mean time I ordered some new tires, LED turn signals and made a service appointment at MaxBMW for next week.
Good to be back.
2007 Ducati GT1000
2011 R1200GS 30 Years edition
Everything else is secondary to manual transmissions, automatic watches and beautiful women showing off both
Mastheadmike is offline   Reply With Quote
Old 07-12-2013, 05:28 PM   #1656
JM
JM's Avatar
Oddometer: 783
Jim
Was the current draw on your new horn close enough to stock to use the same circuit or did you have to add a relay into the mix? How much louder is the horn? I always wanted to upgrade the horn on my 1150GSA but never did. I'd like to upgrade the 1200GSA's horn but don't want to do anything that may piss off the can bus brain.
John
Postponing retirement one farkle at a time!
JM is offline   Reply With Quote
Old 07-12-2013, 07:09 PM   #1657
lowsid3r
lowsid3r's Avatar
Oddometer: 60
Fixed those stripped bolts on my skid plate.
Old 07-13-2013, 07:10 AM   #1658
VietHorse
VietHorse's Avatar
Location: Recalculating... recalculating.... HCMC-Vietnam :)
Oddometer: 1,451
Installed the waterproof USB sockets bought from DMV. Its design is great, solid, durable and convenience.
However, the wire length is just 1.2m - Better if they give 1.5m.
Demo pics from web:
VIETNAM by Motorcycle | My Ride Reports on ADV
VietHorse is offline   Reply With Quote
Old 07-13-2013, 09:49 AM   #1659
krellheat
Pepsi Challenged
krellheat's Avatar
Oddometer: 2,116
Linky to DMV USB adapter please.
Just remember, once you're over the hill, you begin to pick up speed.
Devil's advocate. Hell conscientious and informed and downright argumentative dissenter.
krellheat is offline   Reply With Quote
Old 07-13-2013, 11:37 AM   #1660
I GS 1
I 90S I
I GS 1's Avatar
Oddometer: 638
I guess getting that restriction out of the exhaust header needs to be next.
I GS 1 is offline   Reply With Quote
Old 07-13-2013, 12:20 PM   #1661
lowsid3r
lowsid3r's Avatar
Oddometer: 60
Yea. Can't really fix that I don't think. Need a whole new header.
Old 07-13-2013, 12:33 PM   #1662
sea2summit
n00b and proud!
Oddometer: 40
Demo pics from web:
Custom color and lettering on your adventure I see. What made you write Kawasaki on it?
sea2summit is offline   Reply With Quote
Old 07-13-2013, 12:48 PM   #1663
JimVonBaden
"Cool" Aid!
Oddometer: 52,929
I only used the low tone side. The draw is close enough to stock that even a 20 second continuous blast does not cause the canbus to shut it down. If I were using both I would need the supplied relay to wire it up. As it is I just used posi-taps into the stock wiring. I can easily return it to stock if I like.
BTW I used the same horn on my R1200ST for 3 years with no issues. I also use a pair of them on my Saturn Sky:
$28 for the pair at Autozone, and even with just the low tone it is twice as loud as the stock tweeter!
Jim
Old 07-13-2013, 12:50 PM   #1664
JimVonBaden
"Cool" Aid!
Oddometer: 52,929
I have the same one on my GS, I didn't use the mounting bracket since I put it in my body panel.
$28 from E-bay.
Jim
Old 07-13-2013, 01:57 PM   #1665
Botch
Botch's Avatar
Oddometer: 395
Jim
Hmm, guess I don't need a $50 Stebel after all. Thanks Jim!
Botch is offline   Reply With Quote
Times are GMT -7.   It's 04:34 AM.
