Old 07-15-2013, 04:23 AM   #1681
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
[QUOTE=Musashi50;21867435]
Originally Posted by macadamia View Post
Yikes! I intend to get out and add to my tiny stack of IBA completed rides using my GSA. I never had to consider this possibility on my RT. Is there a "work-around?" Tailpipe extension? Mandatory muffler lowering? Please share & thanks in advance.
I replaced the stock signals on my GSA with the BMW LED turn signals when I purchased mine this past January... They are much skinnier and less in the exhaust stream. I completed a CC50 after I replaced mine and there are no heat scorch marks or melted plastic to be seen.
As an added bonus, they are very bright and conspicuous.
There is a company who makes an exhaust extension for the stock can. They say it is for heat reduction on the pannier, but I do not know if it redirects the heat from the back of the left signal... Maybe this will help too...
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 07-15-2013, 05:42 AM   #1682
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,256
99.9% of the time this is not an issue. I have had two R1200GS bikes, one with 55K miles and one with 120K miles, and never an issue. Most of the issues come from non-standard, or badly positioned exhaust or saddle bags that direct the heat in odd ways.
I've done 800 mile days in 100+ heat with no melting.
Jim
Old 07-15-2013, 05:54 AM   #1683
Spaggy
Spaggy's Avatar
Oddometer: 869
Originally Posted by Ravenslair View Post
I will get one shot tomorrow. Here is CousinDave's video which is where I got the inspiration from. I was amazed how heavy the muffler was. I will shoot a video tomorrow as well as take a few sound readings to see just how much the sound increased. Like I said though, the sound increase is minimal at most. There are a ton of baffles on eBay. I may buy one just to have on hand in case I need to add some back pressure. A few tanks of gas and I should know if anything changed on that front.
I've been running mine like that for a couple years. I think most of the back pressure and muffling is in the cat. I never considered putting the muffler back on.
The other day I was at the dealer and they had an Akropovic can on the wall. $500 ????? I told him my "can" was $10 and he looked at me like I had 2 heads.
Spaggy is offline   Reply With Quote
Old 07-15-2013, 06:23 AM   #1684
Hikertrash
Oddometer: 2,829
I don't know how the heat was able to melt it. It is an aftermarket exhaust, but it's positioned quite a bit further from the signal stock than the OEM exhaust was.
IBA #50489
Hikertrash is offline   Reply With Quote
Old 07-15-2013, 06:27 AM   #1685
JimVonBaden
"Cool" Aid!
Oddometer: 52,256
It isn't the distance, it is the angle of the exhaust. The heat from the exhaust isn't going to cool much from 6" to 8".
Jim
Old 07-15-2013, 08:20 AM   #1686
TuonoBiker
Oddometer: 781
I did my first 6K service on my '12 GSA. Thanks to a Jim for a great DVD which really helped to familiarize myself ahead of time.
I didn't swap gearbox oil yet or do the brake fluid yet, but oil change, valve check, engine synch, etc., all completed. Valves were within spec...next time I'll probably have to shim the Right side, top exhaust valve. The .38mm feeler guage fit, but was really really tight.
My engine synch was way off, too. Got that sorted as well as about 3 spokes up front. They were not ringing out all...quarter turn or so of the spoke and that put some tension on to make them ding nice.
Otherwise, everything else looks good - checked brake lines, looked for loose cables, etc. and I'm ready for another 6K.
I did find this on the right side spark plug gasket area: Any thoughts? Its like rusty residue with white aluminum corrosion...I cleaned it off best I could. Nothing down in the spark plug hole, just at the gasket area and behind the gasket.
'12 R1200GS Adventure
'06 Ducati 999S
'11 Harley Street Glide - gone and mostly forgotten
'07 Tuono Factory - gone but not forgotten
TuonoBiker is offline   Reply With Quote
Old 07-15-2013, 08:59 AM   #1687
Giggity
Giggity's Avatar
Oddometer: 753
Put on a new rear tire (yesterday) and did this 210 mile loop:
Giggity is offline   Reply With Quote
Old 07-15-2013, 01:58 PM   #1688
NoVa Rider
Oddometer: 2,847
NoVa Rider is offline   Reply With Quote
Old 07-15-2013, 03:04 PM   #1689
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
Originally Posted by selil View Post
I got home from riding the Iron Butt Rally.
Gratz!!! How did you do?
Old 07-15-2013, 04:28 PM   #1690
mirtna
Magrambalgue
mirtna's Avatar
Oddometer: 59
foto test
Givi Airflow screen
Altrider Highway Pegs
Altrider Stand Foot
Altrider Oil Cooler Guard
Givi Box top rack
https://www.dropbox.com/sc/mhsd7qw6vcqu1rc/iJ9BKzH-CB
Mirtna - ESA
"It takes a gentleman to suffer ignorance and smile." ....... so please be a gentleman and be patient with me.
mirtna is offline   Reply With Quote
Old 07-15-2013, 05:39 PM   #1691
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
Originally Posted by mirtna View Post
Givi Airflow screen
Altrider Stand Foot
Givi Box top rack
Let us know what you think of the placement of your highway pegs... I have mine there and they are way too high for me. I have not moved them as of yet, as I've been busy...
Old 07-15-2013, 06:22 PM   #1692
X5-
X5-'s Avatar
Oddometer: 59
Rode it to work today with the new Givi airflow that I installed this weekend!
X5- is offline   Reply With Quote
Old 07-15-2013, 07:46 PM   #1693
wswartzwel
Unsafe at any speed
wswartzwel's Avatar
Oddometer: 1,037
Replaced the driveshaft with a new one, (front splines have been greased waiting for the new final drive which should be here tomorrow Then I will grease the rear splines)
Also added the Beemer Boneyard clamp and metal disconnects
Bought the bike a month and a half ago from a dealer, and found all the common problems. Dealer is helping me out with big discount on the parts.
Getting it ready to head for Top of The Rockies in a couple weeks.
_________________________
2006 BMW R1200GS
2010 KTM 690 ENDURO R
1969 BSA STARFIRE
wswartzwel is offline   Reply With Quote
Old 07-15-2013, 09:02 PM   #1694
jd2577
The Boy Ruger
Oddometer: 93
Over the weekend I put the finishing touches on my auxiliary LED's, battery volt meter, and GPS power wiring installs. Today I had both tires replaced. And tomorrow I'm taking my first ride in almost a month!
jd2577 is offline   Reply With Quote
Old 07-16-2013, 01:54 AM   #1695
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,248
Congrats on the new [to you] GS! Which dealer Bill?
My first car was a bike. [1973 CB500F]
joenuclear is offline   Reply With Quote
Times are GMT -7.   It's 12:22 AM.
