Old 08-01-2013, 05:55 AM   #1801
Ravenslair
Oddometer: 483
Installed a set of Fastways, TT extended brake pad and TT adjustable shifter for my 1150GSA. Just purchased them from a fellow inmate. I paid on Sunday, he shipped on Monday and I received them last night. Of course I installed them after the family went to bed!
Ravenslair is offline   Reply With Quote
Old 08-01-2013, 08:50 PM   #1802
wswartzwel
Unsafe at any speed
wswartzwel's Avatar
Oddometer: 1,041
Added some footman tie down straps to the saddle bags and rear trunk to make it easier to tie down my tent and Kayak bags.
_________________________
2006 BMW R1200GS
2010 KTM 690 ENDURO R
1969 BSA STARFIRE
wswartzwel is offline   Reply With Quote
Old 08-01-2013, 08:58 PM   #1803
NoVa Rider
Oddometer: 2,931
JVB suggested adding the GS rubber inserts for highway comfort. Thousands of miles later, I can say he was correct!
Look in the flea market for used GS options. Here is maxbmw link and part number:
46717696748 FOOTREST RUBBER $21.57
NoVa Rider is offline   Reply With Quote
Old 08-01-2013, 09:59 PM   #1804
johnny80s
johnny80s's Avatar
Oddometer: 267
Pick up a used set of ohlins GSA shocks for the gs. At what point is my 07 gs actually a GSA? Tank check, alternator check, shocks check...
Guess I get to weld extension on the side and center stands too.
johnny80s is offline   Reply With Quote
Old 08-02-2013, 04:44 AM   #1805
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,512
Or, pick up a few hockey pucks and bolt them to your side and center stands. Trim as needed.
This makes the mod reversable.
Jim
Old 08-02-2013, 07:25 AM   #1806
ducnek
Satisfied customer
ducnek's Avatar
Oddometer: 1,018
[QUOTE=wswartzwel;22009193]Added some footman tie down straps to the saddle bags and rear trunk to make it easier to tie down my tent and Kayak bags.
PM inbound
Calmer than you are.
ducnek is offline   Reply With Quote
Old 08-02-2013, 07:28 AM   #1807
RichBMW
RichBMW's Avatar
Oddometer: 2,103
Fitted Touratech cylinder guards, and Wunderlich bar risers to the GS. Will test the risers tomorrow.
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Old 08-02-2013, 07:44 AM   #1808
wswartzwel
Unsafe at any speed
wswartzwel's Avatar
Oddometer: 1,041
Originally Posted by ducnek View Post
PM inbound
To answer your question and anyone else that might be interested... the place where I mounted the footman loops are outer covers for the saddle bags. those covers are removable. there is some gaps between the cover and the case where you can locate the bolts so nuts can fit without interference. I used 10/32 stainless machine bolts and nuts.
On the top case the two front loops location has no space... I drilled the holes smaller than the bolts and they self tapped, the nuts are visible inside the top of the trunk... those are the only two that did not have space to avoid drilling through the cases.
2006 BMW R1200GS
1969 BSA STARFIRE
wswartzwel screwed with this post 08-02-2013 at 06:31 PM
Old 08-02-2013, 07:57 AM   #1809
Ravenslair
Oddometer: 483
46717696748FOOTREST RUBBER$21.57
This part fits the Fastways? This is what I was going to try. Looks like it will cost about the same. (photo linked to same location as original post noted earlier)
Old 08-02-2013, 08:17 AM   #1810
NoVa Rider
Oddometer: 2,931
I went with those -- he had them laying around the shop. Work wonderfully. Perhaps jvb can clarify fitment for different aftermarket pegs?
Old 08-02-2013, 11:57 AM   #1811
JimVonBaden
"Cool" Aid!
Oddometer: 53,512
Yes, standard BMW rubber inserts. You can also use them on a couple other aftermarket peg sets.
Jim
Old 08-02-2013, 01:19 PM   #1812
Ravenslair
Oddometer: 483
Jim
The part number Nova listed was for the F800GS, F700GS and F650GS. That does not appear to fit as far as I can tell. I see based on the post I linked the rubber for the 1100/1150 footrest does work. Very good to know. Thanks!
Old 08-02-2013, 01:27 PM   #1813
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Turned my RT into a GS....
http://www.advrider.com/forums/showthread.php?t=889253
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 08-02-2013, 04:11 PM   #1814
DirtDagger
Oddometer: 88
most recently, okay in the last month on my 95 1100gs. Replaced the bearings in my gearbox (thanks Murkidi), replaced input and output shaft seals. Replaced throttle cable (found it was frayed when I started pulling the gear box), replaced the air filter, replaced the fuel pump and filter, lubed the splines just need to replace the weepy final drive pinion seal sync the carbs and I can close her up and ride her.
DirtDagger is offline   Reply With Quote
Old 08-02-2013, 04:25 PM   #1815
NoVa Rider
Oddometer: 2,931
Sorry. The rubber inserts as are JVB described:
http://www.beemerboneyard.com/46711242018.html
Times are GMT -7.   It's 02:24 PM.
