Old 12-15-2012, 03:34 PM   #211
rotaryracer
rotaryracer's Avatar
Oddometer: 643
Hey Lance....bike looks great!
Originally Posted by lanceputnam View Post
New goods went on this week-
Holan Nomada Pro 45L system w/ jerry cans
Carbon Fiber winglets
2" Rox Risers
Jason Smith
www.advmotorrad.com
Check out the ADV Motorrad vendor thread for great deals on adventure gear!
rotaryracer is offline   Reply With Quote
Old 12-15-2012, 03:41 PM   #212
dsy
dsy's Avatar
Oddometer: 89
Originally Posted by picinisco View Post
Did you make this. Is it as simple as an LED connected to a mini jack?
Yep, thats all it takes. No restistors or anything. The intensity of the led is variable with the speaker volume knob. You just have to get the polarity correct. Hook it up and see if it lights. If not just switch the two wires and it will light up. Slide some 1/8" heat shink tube over the led leads right up to the base of the leds then some 1/4" heat shrink over top of those after its all soldered up. With the velcro you can dial it in to get the best visual angle. I think it maybe cost about a dollar to make,
2012 1200GSA
2007 JK Wrangler with diy hemi install
dsy screwed with this post 12-15-2012 at 09:12 PM
dsy is offline   Reply With Quote
Old 12-15-2012, 03:49 PM   #213
maxfnz
Oddometer: 59
Cam chain tensioner upgrade - VERY nice, no more clatter... NZ-new 96 1100GS so somehow it's never been shown that kind of love before; I've only had 2 months but even to my ear that seems to have helped drop & smooth the idle.
Valve clearances, braided rear brake line & BMW throttle screw next.
Max
Chch NZ
(Done: iridium plugs, TB balance, fork seals (& oil, one had engine oil in it by the looks!), SLA battery, new paralever bearings / spline lube, heated grips, all oils & filters... coming together now!)
maxfnz is offline   Reply With Quote
Old 12-15-2012, 11:41 PM   #214
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 374
Got a great deal on an unused Pelican 1550 for a top-box from Craigslist.
Gotta do a coupla mods to my custom rear rack to get the right fit. Will post photos when done!
Cheers all!
ElMartillo is offline   Reply With Quote
Old 12-18-2012, 01:09 AM   #215
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 374
I bought this sturdy, folding aluminum table at Walmart for about $23:
It's a good size, but the idea was to modify it to fit nicely on top of my Pelican 1550 top box:
Although after the mods it's low, the height will be good for use with a camp chair, and certainly better than placing the kitchen on the ground:
Mission accomplished:
I should add that I included the Pelican case in the photos to show scale, not because I plan on using the table as a suitcase stand.
Cheers, all!
ElMartillo screwed with this post 12-19-2012 at 07:18 PM
Old 12-18-2012, 12:12 PM   #216
picinisco
Scottish Transplant
picinisco's Avatar
Oddometer: 475
Oh yes. I like this very much
Cheers...John - 2004 BMW R1150GS, 1978 R100 (G/S Frankenbike)
Bikes That have Moved On:
1978 Suzuki GS550E, 1978 Kawasaki KZ1000P, 1982 Honda XL500R, 1995 BMW R1100RSL
picinisco is offline   Reply With Quote
Old 12-18-2012, 07:57 PM   #217
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 374
Thanks. It took a liittle thought and time, but I got what I wanted.
Final dimensions are 18.5"w x 14.5"d x 12"h open, 18.5" x 16.25" x 2" folded.
Old 12-18-2012, 08:06 PM   #218
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
I purchased my plane ticket for my fly-n-ride to North Carolina to pick up my 2012 Triple Black GSA. I fly out on New Year's Eve, first class of course...
I'm so excited to finally make the last of the plans to head out. Now, it is just a waiting game until the 31st!
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 12-18-2012, 08:38 PM   #219
BigDave75
Will Work for Food!
BigDave75's Avatar
Oddometer: 1,747
Congrats, ride safe!
Rangers Lead the Way, Hooah!
BigDave75 is offline   Reply With Quote
Old 12-18-2012, 09:06 PM   #220
BaddAndy
BaddAndy's Avatar
Oddometer: 116
Did you mean "ride south"!
2012 Triumph XC-800
2001 Susuki DRZ-400S
BaddAndy is offline   Reply With Quote
Old 12-18-2012, 09:35 PM   #221
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
Thanks dude!
yasir!!
Here is my plan for the return trip...
I will be staying in Raleigh for a couple of days to prep the bike for the trip. I have to add my farkles and heated gear pigtails. Then, I plan to ride down to Jacksonville, FL and stay overnight. Then, get up the next day and set out on an iron butt ride, the CC50, coast to coast in less than 50 hours. I plan to ride from Jacksonville, FL to San Diego, CA in less than 50 hours. I have completed a SS1K earlier this year and am ready to try the next long distance ride.
I'll have photos and a ride report to post for this ride soon.
Also, I have set aside 20 days late this spring for a round trip ride to the arctic circle in Alaska, from San Clemente. I'm planning to do this solo, but if there are any other So Cal riders who want to make this ride, let me know...
Old 12-18-2012, 09:44 PM   #222
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
I also ordered the necessary ram mounts needed to mount the farkles I plan to install - Garmin Zumo 665, XM Radio antenna for the 665, Spot Messenger 2, Valentine One radar receiver, 2 GoPro HD cameras, and the Dispatch 1 farkle controller.
I am still deciding which tank bag I want to get, although, for the ride back from NC, I will not need it. I'll probably prep a circuit for tank bag electrification as well.
Old 12-18-2012, 10:53 PM   #223
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
Originally Posted by LaurelPerryOnLand View Post
While the SPOT MESSENGER 2 would LOOK great mounted with their RAM mount...I've decided to NEVER do this.
After reading about a rider who mounted his SPOT, broke his leg 50 feet from his bike and almost DIED dragging himself back to the bike to get to the SPOT to use the SOS feature.
Nope...I'll be carrying mine IN MY JACKET...along with CELL PHONE...in case I REALLY need them...they'll be immediately accessible.
Do what you want. Just sayin'.
Macadamia..I think you'd be NUTS to mount it. (Sorry, it was just too obvious to avoid)
well, nuts I am... Thanks for the concern... When I ride on the road exclusively, I keep it mounted on the bike. When I'm going to ride off road, it is in my camel bak pack. I know it is safer if I keep it on my person all the time, but I tend to forget to turn it on for my tracking feature when it is not visible all the time.
I'll keep what you said in mind when I am doing my mounting chores.
Old 12-18-2012, 11:06 PM   #224
GoinPostal
GoinPostal's Avatar
Oddometer: 384
Thanks dude!
Well even though I am not in So Cal, I am in Nor Cal. and I plan on riding up to Alaska this late spring also. Maybe we can chat about that when you get back from the east coast. Have a safe and fun ride back
Oh, by the way......great choice on your bike
Charter Member 'Group of Fools'
Group Of Fools Mexico Adventure 2012
Dust 2 Dawson 2012
Group of Fools Central America Adventure 2013
GoinPostal is offline   Reply With Quote
Old 12-18-2012, 11:19 PM   #225
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
Sounds great! and nice choice of bike for you too...
Times are GMT -7.   It's 08:46 PM.
