Old 09-22-2013, 02:18 PM   #2281
Ravenslair
Oddometer: 497
Originally Posted by Hikertrash View Post
Yike! $60? The powerlet ones are cheaper than that. I thought they were about $30?
Blue Sea makes one for $20 (2.1 amps). The front panel portion is removable. They make good gear.
Ravenslair is offline   Reply With Quote
Old 09-22-2013, 02:39 PM   #2282
Hikertrash
Oddometer: 2,989
Thanks but that looks like the same diameter as a cigarette plug. I need the smaller BMW plug diameter for my fender.
Hikertrash is offline   Reply With Quote
Old 09-22-2013, 03:35 PM   #2283
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
Well I blame you and your GSA thread for many of my farkles so I must be nuts
It's addictive, isn't it...
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 09-22-2013, 04:35 PM   #2284
QCRider
Oddometer: 94
^^ what he says
... almost as much as your avatar! Can't take my eyes of it each time you post something. Damn you macademia!!
I've been lurking here for a while now, so I thought today would be my frst post to this thread. After 5 months waiting, my new Ohlins Mechatronics (TTX) finaly arrived, and scheduled to get installed on Tuesday. Pictures to follow later this week hopefully. Can't wait to see if they live up to the expectations!!
QCRider is online now   Reply With Quote
Old 09-22-2013, 06:07 PM   #2285
Gruesome
Alter Heizer
Gruesome's Avatar
Oddometer: 980
more brake line fun; Stebel air horn test mount
Replaced the standard length Spiegler rear brake line with the quarter inch longer one, found that even more unsatisfactory (touches drive shaft housing already with bike on center stand), and swapped the standard Spiegler line back. If I use a spacer against the built-in front connection banjo stop it fits. The original BMW lines must have a slightly larger diameter where they bump against the alignment stops; the Spiegler banjos point a bit sideways when fully against the stops, and that made the rear line a very stretchy fit.
I also mounted the Stebel horn off to the right just outside and under the beak, using an L bracket on an existing allen head screw, but haven't connected it yet. Is there a source for the original BMW horn connector on the 1150GS? The wire location is not great for a tap, so putting a short extension piece with a male and female connector would be nice.
Gruesome is offline   Reply With Quote
Old 09-22-2013, 07:09 PM   #2286
VietHorse
VietHorse's Avatar
Location: Recalculating... recalculating.... HCMC-Vietnam :)
Oddometer: 1,610
Where did you get the USB port? I looked on eBay and they all look the same size as a cigarette plug (too big for GSA beak) ?
I think i have put this link somewhere around ADV.
It's DMV USB socket, $28.
Existing wires are not long enough for a GS when you install the socket on handle bar or on the dashboard.
VIETNAM by Motorcycle | My Ride Reports on ADV
VietHorse is offline   Reply With Quote
Old 09-22-2013, 07:36 PM   #2287
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,448
But plenty long enough to reach the GPS power plug.
Thanks for the link!
Jim
Old 09-22-2013, 08:05 PM   #2288
teomannaskali
teomannaskali's Avatar
Oddometer: 824
Where is the gps plug on the std gs? (2005)
teomannaskali is offline   Reply With Quote
Old 09-22-2013, 08:09 PM   #2289
JimVonBaden
"Cool" Aid!
Oddometer: 54,448
Jim
Old 09-22-2013, 09:15 PM   #2290
VietHorse
VietHorse's Avatar
Oddometer: 1,610
Jim,
I'd like to do a mod to my headlight, and I am trying to find an outlet which is the same with the Pilot bulb.
Could you pls tell me where to get the power from? I don't want to use any Possi-tap.
The pilot bulb wire is covered and very difficult to find the disconnection point to connect.
(Photo from www.gunsmoke.com)
Old 09-23-2013, 05:24 AM   #2291
JimVonBaden
"Cool" Aid!
Oddometer: 54,448
Jim,
Look at the post above yours. You can get a plug from BMW (or Eastern Beaver IIRC) that can plug into that and use it for your power tap. You only get less than 5 amps from it, so it is good for small stuff.
Jim
Old 09-23-2013, 02:27 PM   #2292
teomannaskali
Oddometer: 824
Which connector is it? There seems to be quite a few options
Old 09-23-2013, 02:32 PM   #2293
JimVonBaden
"Cool" Aid!
Oddometer: 54,448
This one. It is strapped to the wiring harness near the upper trippletree and has a black cap on it.
You can see it strapped to the frame on the right just below the satinless loop that holds the throttle cable. It has a bit of red showing on the bottom.
Jim
Old 09-23-2013, 02:41 PM   #2294
teomannaskali
Oddometer: 824
Sorry, i meant, if i want to crate a wiring harness that connects to that, which connector do i need to buy.
Old 09-23-2013, 03:48 PM   #2295
UAS
Oddometer: 106
This is the BMW part number, 83300413585 about $20 US.
2012 GSA Triple Black
UAS is offline   Reply With Quote
Times are GMT -7.   It's 10:03 AM.
