Old 05-12-2014, 06:40 AM   #3661
MassiveLee
It's a small world
MassiveLee's Avatar
Oddometer: 1,174
Originally Posted by XICAQUE View Post
Lee, you have bigger balls than I. That puddle is bigger that the one I met when I only had the bike for 2 days 😳😳😳
Damn did I suffer ;-) I gave more than my body had in reserve. But I rode home, cleaned the bike, dried the connectors and the RID and today I will flush the oil with cheap one, run it for an hour, then flush again with proper oil. I had water in the exhaust (obviously) but also in the swing arm. To avoid driveshaft rust, I pulled the rubber boot at the final drive, dried with compressed air and let it open all night. Except for the "puddle incident" the rest of the ride was great. The GSA behaved very well in rocks and steep climbs. It was actually easy. Stand on the pegs, use your legs to absorb bumps, don't touch the brakes, keep second gear and modulate throttle.
Here are some clips from "Chemin Scotch" off Youtube. Sometimes it's dry. Sometimes it's very muddy.
https://www.youtube.com/watch?v=a1rf9aIUx_0
https://www.youtube.com/watch?v=vdfWdZ8-79I
1982 Honda 500 Ascot FT / 1986 Honda 750 Nighthawk S / 1988 Honda 1000 Hurricane / 1990 Honda CBR1000F
2001 BMW K1200RS aka Good Girl -- Current
2006 BMW R1150GSA aka Kim Kardashian -- Current
1988 Honda Africa Twin aka Queen of Sheeba -- Current
MassiveLee is online now   Reply With Quote
Old 05-12-2014, 06:53 AM   #3662
b-crow
b-crow's Avatar
Oddometer: 58
Added ALTrider bars and skid plate
this weekend
b-crow is offline   Reply With Quote
Old 05-12-2014, 07:11 AM   #3663
elnonio
shedding n00bness
Oddometer: 233
T'aurais du laisser les panniers, t'aurais floté!
Antonio
elnonio is offline   Reply With Quote
Old 05-12-2014, 08:20 AM   #3664
QCRider
Oddometer: 94
QCRider is offline   Reply With Quote
Old 05-12-2014, 03:21 PM   #3665
elnonio
shedding n00bness
Oddometer: 233
Originally Posted by JimVonBaden View Post
Nice! Where did you get it? Is it a simple on/off switch?
Radio shack part number 275-0646 SPST momentary pushbutton switch.
Antonio
Old 05-12-2014, 04:09 PM   #3666
JimVonBaden
"Cool" Aid!
Oddometer: 53,263
Old 05-12-2014, 06:39 PM   #3667
GapRunr
GapRunr's Avatar
Oddometer: 504
Nop. Those are cheap eBay HID knock-off of Hellas 4" Optilux. They are wide beam and give a lot of light.
Lee
I tried a set of those on my 1200GSA and had to take them off. They weren't very well shielded and the ballast would set off the ABS warning light. I wasn't sure if it was a wiring isolation issue so I actually connected them to a marine battery sitting next to the bike to trouble shoot and they still set off the ABS warning light.
Great lights, I wish they could have worked.
GapRunr
07 R1200GSA - 81 R80g/s - 95 KLR 250 - 06 TW200 SuperDuper Tenere - Gas Gas TXT280 Edition
88 Hawk GT-> for sale!
GapRunr is offline   Reply With Quote
Old 05-13-2014, 07:58 AM   #3668
mefly2
mefly2's Avatar
Oddometer: 1,211
Hmmm ... can you tell us why the PBs could not be just triggered from the high beam as well ... to save the addition of sw / wiring to the right assembly?
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 05-13-2014, 10:39 AM   #3669
elnonio
shedding n00bness
Oddometer: 233
Eh?
The sender signal from the high beam is strange, in that it is a constant on until you depress the high beam pass switch. I saw two issues:
first, I was unsure how the skene unit would react to the constant voltage
second, the skene unit relies on two pulses to trigger. On a normal system with high beam switch, the voltage would go: off-on-off-on-off. On the BMW, the high beam setup (constant on) ended up requiring 3 flashes to do the trick: on-off-on-off-on-off-on. Confused?
It's because the pattern is inverted, the off is actually the high beam activated on the bike, but what the skene needs are the two short pulses, on, in the middle. The ongoing on pulse can't be used to trigger.
So, to get those two short on pulses you need to flash three times. It's worse in my mind than flashing twice in a near emergency.
I'm not making this up, I actually tried with the "flash to pass" switch, it took three flashes to activate.
Antonio
Old 05-13-2014, 10:46 AM   #3670
MassiveLee
It's a small world
MassiveLee's Avatar
Oddometer: 1,174
The lighting is superb. But quality is pretty low. It's another low quality Chinese knock-off. When I submerged the bike, the left projector showed it wasn't waterproof ;-) There was muddy water behind the glass. So, back home, I opened it. Many useless screws just for the show. But hey, for $80, what should I expect?
You can see brown water behind the lens...
Old 05-13-2014, 08:37 PM   #3671
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,514
Added a steering damper to my '13 wethead.
http://www.advrider.com/forums/showthread.php?t=977996
marchyman is offline   Reply With Quote
Old 05-13-2014, 08:58 PM   #3672
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,409
Plasti Dip'd the inside of my Panniers..Using the new Rust Olem brand..
Easy enough..turned out nice..but that is some VOLATILE shit...I had a bloody nose by the time I was done...If you do it..wear a damn respirator...
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 05-13-2014, 09:19 PM   #3673
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,747
Originally Posted by VEGASGSA View Post
Plasti Dip'd the inside of my Panniers..Using the new Rust Olem brand...If you do it..wear a damn respirator...
couldn't agree more. Did plasti dip work last week and had it in the throat for hours. next time I'll use at least a scarve to protect me
Loutre is online now   Reply With Quote
Old 05-14-2014, 07:42 PM   #3674
Guitar1327
Oddometer: 47
Rox Risers
I just put on a set of Rox risers that I bought of a fellow on here. Now I've got another inch plus of pull-back... I'm pumped. Although I was nervous they weren't going to fit, the clearance between the risers and the triple if you can call it that, is quite small.
Guitar1327 is offline   Reply With Quote
Old 05-14-2014, 09:37 PM   #3675
XICAQUE
Q' pedo?
XICAQUE's Avatar
Oddometer: 613
Is there a specific purpose to doing this? Or is it for cool looks??
Rob
LRMC sucks ASS!
Can't stand HD bikes! Loud POSs and nothing but posers.
XICAQUE is offline   Reply With Quote
Times are GMT -7.   It's 02:10 PM.
