Old 02-03-2013, 11:57 AM   #451
lukeinlondon
lukeinlondon's Avatar
Oddometer: 431
does my bike not starting and the emergency engine light coming on count as doing something?
lukeinlondon is offline   Reply With Quote
Old 02-03-2013, 12:27 PM   #452
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 539
That qualifies under "swore at it"
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 02-03-2013, 03:53 PM   #453
parkbum
parkbum's Avatar
Oddometer: 19
One of the things I did to my Triple Black was paint the silver tank parts black.
parkbum is offline   Reply With Quote
Old 02-03-2013, 11:54 PM   #454
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 455
Finished the install on my aux LED lights. Both pair are wired with relays.
The pair under the headlights are wired to come on with the high beams. These are 10 watt, 750 lumen spots with a 20deg beam angle. The pair under the directionals (only one shown in photo) come on with the low beam, but are also controlled with a switch for manual on/off. These are my driving lights and have diffused 60deg beams. Otherwise specs are the same as the pair mentioned above.
This is the switch I decided on, found at my local electronics specialty store for about $5:
In deciding where to mount the switch, my first thought was to mount it to the right of the high beam switch (#1 first photo), so after opening up the housing I found I would need to make room for the switch by removing the material immediately under the area. Apparently this material is a casting intended to accommodate switch gear for a different model bike (#1 second photo).
After removing the material I found there wasn't enough room after all, so I decided to mount the switch above the high beam switch (#2 first photo), requiring me to remove the material directly under that area instead (#2 second photo).
This is what I was left with after removal of the material inside the switch housing.
Turns out the final mounting position is perfect. I can keep my hand on the grip and actuate the switch with my thumb:
The material that the BMW switch housing is made of is very easily cut with a sharp knife. I like the way the lights look on my bike, and I'm happy with the switch. It doesn't look out of place on the controls, in my opinion.
The switch has a light that comes on when the driving lights are on. I decided on orange, but it is also available in red and green.
Also, the LED lights work very well and throw a lot more light in front of the bike. Night time visibility is much better, and I'm more noticeable to other motorists during the day.
Cheers!
ElMartillo is offline   Reply With Quote
Old 02-04-2013, 02:32 AM   #455
mikegc
mikegc's Avatar
Oddometer: 1,662
Cheers!
Very clean job!
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Old 02-04-2013, 03:35 AM   #456
legasea
Ape on wheels
legasea's Avatar
Oddometer: 165
Kept mosquitos away from lenses and radiator protected.
Kept the Exide body, with a smaller heart.
Added an easy way to connect fused devices.
Powered it!!!
Breath baby, breath. With K&N,Y and open Remus Revolution.
Got all this room.
Progressive springs from Hyperpro.
The difference Viton and vazeline make.
http://www.youtube.com/watch?v=gvqk1...ature=youtu.be
I knew what a pain in the ass was, so, for my bum's sake called Bagster. Pillion appreciates it so much as well.
And so many other improvments...
ADV....SE
It's God's fault if atheism is growing
legasea screwed with this post 02-04-2013 at 10:19 AM
legasea is offline   Reply With Quote
Old 02-04-2013, 08:53 AM   #457
WindSailor
WindSailor's Avatar
Oddometer: 727
Nice posts - and great job to the both of you: legasea and ElMartillo
WindSailor is offline   Reply With Quote
Old 02-04-2013, 10:09 AM   #458
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,353
Cheers!
Very nice work there. Clean install!
Jim
Old 02-04-2013, 05:30 PM   #459
lukeinlondon
Oddometer: 431
took it to BMW Hollywood..1hr 30 they had the bike FIXED..VERY HAPPY to be riding her again..yeeehaaaaaaaaaa
Old 02-04-2013, 09:54 PM   #460
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 455
Originally Posted by mikegc View Post
Very clean job!
Mike
Jim
Thanks for the compliments, gentlemen!
Old 02-05-2013, 01:13 AM   #461
legasea
Ape on wheels
legasea's Avatar
Oddometer: 165
For those who go into ABSectomy and most having bikes between 2002/2006 will, or change the unit, it can be done saving all the parts for a possible future return to the original condition. That's what I've done considering I want to keep the SE.
From here, gathered all the information; http://www.bmbikes.org.uk/Forum/view...=10921&p=68322.
Just did the lights arrangements otherway.
With some wires did it simple, compact and without sacrifices.
Yes, it could have a pro look, and it will, with thinner wires.
ADV....SE
legasea screwed with this post 02-05-2013 at 01:25 AM
Old 02-05-2013, 04:53 AM   #462
JimVonBaden
"Cool" Aid!
Oddometer: 53,353
Slick! I wonder how much more difficult it would be for the R1200 series?
Jim
Old 02-05-2013, 06:59 AM   #463
legasea
Ape on wheels
legasea's Avatar
Oddometer: 165
Much more, for sure.
Complexity has it's price.
Hardly, will any MacGyver skilled mate, start a 1200 anywhere.
Got to believe in tech gods...
ADV....SE
Old 02-05-2013, 10:18 AM   #464
JimVonBaden
"Cool" Aid!
Oddometer: 53,353
fallingoff?
Jim
Old 02-05-2013, 10:57 AM   #465
legasea
Ape on wheels
legasea's Avatar
Oddometer: 165
Yes, yes.
It's god 's fault if ateism is growing...
ADV....SE
legasea screwed with this post 02-05-2013 at 11:14 AM
Times are GMT -7.   It's 12:01 AM.
