Old 02-26-2013, 04:22 PM   #631
BTL
WINTER!! UGH!
BTL's Avatar
Oddometer: 414
Originally Posted by Ayrshire Bull View Post
that looks easy. I like it. Another farkle, incoming... thanks for the tip UAS
+1 on that..I will assume no interference with steering or suspension??
BTL is offline   Reply With Quote
Old 02-26-2013, 05:44 PM   #632
lukeinlondon
lukeinlondon's Avatar
Oddometer: 434
tried just using the rear brake earlier...and nothing happened?
lukeinlondon is offline   Reply With Quote
Old 02-26-2013, 06:05 PM   #633
UAS
Oddometer: 106
None noted but only 80 miles of paved 40 degree riding since the install. I bought my kit from Sierra BMW after stumbling across this, http://www.motorcycleparts-hornig.co...ebel-Horn.html
Notice it will only fit ESA equipped models where the ESA module is on the side. It was kind of bitch to install, but I did not remove the tank. I put a diode between the coil of a weatherproof relay and mounted the relay on a left silver bracket at the front of the Adventure trim panel, which is also a great ground point! Arg camera battery just died...pic to follow...
The location of the relay:
View of the horn. The bracket is attached to the nut on the horn and goes back to the original horn mount. (Working blind it is a T-30 bolt on the original horn).
I hope this is not too much for the original intent of this thread.
2012 GSA Triple Black
UAS screwed with this post 02-26-2013 at 09:56 PM Reason: Add Pics
UAS is offline   Reply With Quote
Old 02-26-2013, 08:35 PM   #634
BTL
WINTER!! UGH!
BTL's Avatar
Oddometer: 414
Hey thank UAS..I have same horn on 109R but it goes with bike( just sold it) Really want to install on new to me 2012 GSA Triple black with ESA.
Old 02-27-2013, 06:19 AM   #635
dch
Rock Chalk
dch's Avatar
Oddometer: 369
Originally Posted by Das Boot View Post
I like that you give Mallory a little advertising over at awarddecals she is the bomb, she has made a ton of custom decals over the years for me. They wear like iron
That is quite a compliment. Mallory is my best employee........and also wife for 37 yrs. I will show her this, thanks.
dch is online now   Reply With Quote
Old 02-27-2013, 06:23 AM   #636
Eyore
Eyore's Avatar
Oddometer: 127
Did the fuel filler neck mod,drilled a few holes ,so looking forward to an extra few litres and some useful additional range.Such an easy fix.
Eyore is offline   Reply With Quote
Old 02-27-2013, 03:02 PM   #637
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
How did you keep the plastic shavings out of the tank?
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 02-27-2013, 07:51 PM   #638
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,262
36K service, which is all fluids including brakes, valves, alternator belt and throttle body sync.
A little corrosion repair as well.
Jim
PS I will be posting a pictorial on the servo-ABS flush soon!
JimVonBaden is online now   Reply With Quote
Old 02-27-2013, 10:33 PM   #639
Johnny4x4
Hope 2 B Cool Sumday
Johnny4x4's Avatar
Oddometer: 71
I got my new Kahedo X-low seat today- installed and went for a ride.
Woo Hoo
Johnny4x4 is offline   Reply With Quote
Old 02-27-2013, 11:27 PM   #640
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
Woo Hoo
Photos, dude... gratz on the new seat!
Old 02-28-2013, 01:59 AM   #641
Eyore
Eyore's Avatar
Oddometer: 127
Dunno if yours is different in the States, but mine is metal. By taking off the filler cap and tank plastic you can pull up the neck piece still attached to the pipework, wrap the whole lot in a towel before drilling. I also used a magnet to catch bits. Blow it off with air and remove the towel. Very straightforward 20 minute job.
Old 02-28-2013, 04:14 AM   #642
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
Can you post a photo of where you drilled? Maybe I'm looking at the wrong place. The plastic part I'm referring to is the orange part under the fuel cap, the filler neck. Thanks...
Old 02-28-2013, 06:31 AM   #643
JimVonBaden
"Cool" Aid!
Oddometer: 52,262
The newer bike has a different filler opening and neck. I have not seen the mod done on it, but it is doable from what I have heard.
Jim
Old 02-28-2013, 06:10 PM   #644
lukeinlondon
Oddometer: 434
600 mile service done at 667
Got them to order the part because my Rear Brake does not work at all
Fitted the 'Accelerator'
So far with 667 miles on, the bike has been in the shop..3 times now?
Luckily my warranty ends in September
Old 02-28-2013, 06:59 PM   #645
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,384
I rode home, er back to the hotel from work again,
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Times are GMT -7.   It's 05:48 PM.
