Old 03-02-2013, 06:48 AM   #691
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,793
Originally Posted by ElMartillo View Post
Turned 100K on my ride back from Seat Concepts in San Jacinto. Cheers!
Man I miss Hemet...................
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 03-02-2013, 07:29 AM   #692
ghostrider.y2k
ride enything but HD
ghostrider.y2k's Avatar
Oddometer: 885
Originally Posted by Yellow Iron View Post
I see now
Im really digging the red spring
Is that an ESA unit?
No its not ESA, here is a better look.
Elibah Spring( rated for my 235# fat ass + gear) , what a difference in a ride quality.
And here a rebuild set of ohlins for 12lt and stock shock removed from same guys Yammy R1 that we upgrade the spring on it.
MOTORCYCLES-->created to keep us from choking the idiots around us
"w strone slonca..........."
ghostrider.y2k is offline   Reply With Quote
Old 03-02-2013, 07:45 AM   #693
milo
Oddometer: 391
Congratulations on the 100k milestone, and that's a nice looking seat! What position is it in high front/low rear?
milo is offline   Reply With Quote
Old 03-02-2013, 09:09 AM   #694
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,578
Lenden is a great guy, they actually made the foam and installed it and a new cover on my seat pan while I waited.
I've only put about 60 miles on the seat so far. The angle is better, the foam comfortable. The cover looks great.
Cheers!
Awesome!
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 03-02-2013, 09:43 AM   #695
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
Originally Posted by mikegc View Post
. . . and I thought I was good. I realize I'm in the presence of greatness!
Mike
thank you, but I'm just a man who knows what he likes...
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 03-02-2013, 11:26 AM   #696
seaswood
seaswood
seaswood's Avatar
Oddometer: 178
Replace front shock
Bought ohlins, the Good ones got the front end all apart gas tank moved along with the air intake. Top nut removed immediately lost found later & bottom bolt out after I twisted a 50 T torx socket & used a allen torx & bar some kind of strong locktite.
But the lower A bar will not lower to get shock out.
Assuming have to remove front wheel to lower front end for shock removal, service guy at Max agreed means I have to wait for proper Allen wrench from Max. next week, I should have one anyways.
Any other thoughts lowering front could remove rear wheel but doing this one person may be best stay to front for now
1200GSA /7/5
seaswood is offline   Reply With Quote
Old 03-02-2013, 11:55 AM   #697
Freerydejunky
Freerydejunky's Avatar
Oddometer: 161
Bought an old Oilhead
Then took her to a really classy establishment for our first dinner date.
Freerydejunky is offline   Reply With Quote
Old 03-02-2013, 12:51 PM   #698
spagthorpe
spagthorpe's Avatar
Oddometer: 14,693
The winglets I made. Nothing fancy, but they work great. In fact, I think when it gets hot here, and I pull off the windshield and handguards like I normally do, I'll probably leave these as I suspect it will still make the ride nicer.
Wasn't much to making the patterns or forming them. Biggest pain of the project was cutting the material. Took me a while to figure out a good way to do it, just the right speed, finesse, etc. I've seen some shorter ones that were just held on with 3M dual lock, and I think that would work, but since mine were a lot taller in the front, I decided a small bracket to secure them was the best way to go. They are rock solid.
spagthorpe is offline   Reply With Quote
Old 03-02-2013, 01:35 PM   #699
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,793
Look here..http://www.advrider.com/forums/showthread.php?t=808727&highlight=remove+front+shock#post19132873
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
Old 03-02-2013, 01:45 PM   #700
RocKrawler
I make wicker cry
RocKrawler's Avatar
Oddometer: 32
Rode it to work for the first time today - other than to the gas station to fill it up last week, my first experience on the GS. Absolutely love it.
Terry
1997 BMW R1100GS
Age doesn’t always bring wisdom. Sometimes age comes alone.
RocKrawler is offline   Reply With Quote
Old 03-02-2013, 03:31 PM   #701
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,578
Fork seals have had a small leak for a while. I ran down to Victory BMW in Chandler to see some KLIM gear, (They didn't have what I was looking for, but the trip answered one question). WHile I was there I asked if they might have fork seals for my bike.
They had two. I bought them.
Then off to a late lunch/early dinner and back to the hotel. I cleaned up the forks and tried a trick, it didn't seem to help too much, but we'll see how it goes. I can work on the seals next time I'm over at my dads where there is shade. Mid 80's here today.
Dirty,
and cleaned up a bit,
If my cold feels up to it I'll go do some exploring tomorrow.
...Dick
Smugmug
Old 03-02-2013, 04:31 PM   #702
Hikertrash
Oddometer: 2,850
Took my Globescout panniers for their first offroad excursion. Unfortunately I didn't drop the bike to test their durability. This was also my first ride in a long time without a tank bag. I just started using this Wunderlich handlebar bag which holds everything I used to carry in my tank bags. I also took the Adventure winglets off since the temps were supposed to reach the low 80's. thos e little suckers block a lot of wind. I think I'll keep them off all summer.
Hikertrash is offline   Reply With Quote
Old 03-02-2013, 06:48 PM   #703
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,389
Used up more gas..more tire..that is all...
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 03-02-2013, 08:25 PM   #704
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 392
Shown high front, high rear, same as I was riding with the stock foam. The new foam has added what feels to be approximately a half inch in height. The rear rack I built doesn't allow me to put the seat in the low position, after I modify it I'll experiment with seat positions, but I do like it as is.
Cheers!
ElMartillo is offline   Reply With Quote
Old 03-02-2013, 09:01 PM   #705
lukeinlondon
lukeinlondon's Avatar
Oddometer: 431
$25 yellow fog bulbs
lukeinlondon is offline   Reply With Quote
Times are GMT -7.   It's 05:14 PM.
