Old 03-11-2013, 08:03 AM   #766
NoVa Rider
Oddometer: 2,931
Haven't had that test yet, but I expect it will be fine! Adding window tint to reduce glare was a great idea.
NoVa Rider is offline   Reply With Quote
Old 03-11-2013, 08:16 AM   #767
Codewheeney
Hoopy Frood
Codewheeney's Avatar
Oddometer: 2,690
Originally Posted by parkbum View Post
Shouldn't the snow plow be mounted on the front?
JC
Jim
Morgan Hill, CA - 2015 R1200GS, 2004 R1150GS.
Plays in traffic.
Codewheeney is offline   Reply With Quote
Old 03-11-2013, 09:32 AM   #768
Pongo
Oddometer: 312
Put reflective tape on the corners of my OEM Adventure panniers.
Pongo is offline   Reply With Quote
Old 03-11-2013, 10:18 AM   #769
El Gato
El Gato's Avatar
Oddometer: 777
Originally Posted by GP1200 View Post
Sorry to be negative, but I don't think those are well thought out at a wide load of 46 1/2" !!. That's dangerous and I made the same mistake myself (with the exact same bike and Shine Yellow color )and switched to Micatech at 38 ". Jesse bags are also well designed in that department. When you get your first close call, you may agree with me. If you think you're clear and your rear bags hit something, it's gonna hurt. Nice bags though.
I used to have Givi E41 side cases on my Wee Strom, which were nearly as wide (IIRC, they were around 43" or 44" wide). I certainly wouldn't be lane sharing with the side cases on, but let's keep things in perspective - this is only a couple of inches wider than the handlebars on each side. If you use even a small amount of common sense it shouldn't be a problem.
El Gato is offline   Reply With Quote
Old 03-11-2013, 11:05 AM   #770
wbrisett
hmmm....
wbrisett's Avatar
Oddometer: 320
Exactly. The bars are right around 42.5 -43" if memory serves me right. I did discover after my first pot hole this morning that I'm going to have to take the bars off tonight so I can check the left turn signals wiring connector under the tail section. I must not have had it pushed all the way in. It worked properly until the first major bump. Just pulled out the bulb to verify it was still good, so it's gotta be that I didn't push it all the way into the socket correctly when i moved the signal.
Wayne
2011 BMW R1200GS Adventure (back to one bike)
wbrisett is offline   Reply With Quote
Old 03-11-2013, 11:25 AM   #771
Goldburg
Goldburg's Avatar
Oddometer: 368
JC
Or he's got a GS with a reverse gear!
Trip Rodgers
Rocky Mount, NC
Goldburg is offline   Reply With Quote
Old 03-11-2013, 11:31 AM   #772
Goldburg
Goldburg's Avatar
Oddometer: 368
I got to ride to work today. Finally after a long winter in Michigan.
Those are some serious freaking brake lights you've added, also...
It's a good looking GS.
Trip Rodgers
Rocky Mount, NC
Old 03-11-2013, 11:34 AM   #773
parkbum
parkbum's Avatar
Oddometer: 19
JC
Good idea. Another good reason to own a GS. Snow plowing!!
parkbum is offline   Reply With Quote
Old 03-11-2013, 11:39 AM   #774
parkbum
parkbum's Avatar
Oddometer: 19
This works better for plowing
Old 03-12-2013, 03:44 AM   #775
kalleswe
Clown
kalleswe's Avatar
Oddometer: 13
Gps mount r150gs adv
Hi guys. just finished my gps-mount.. Must say Im pretty proud .. Made in stainless steel.
kalleswe is offline   Reply With Quote
Old 03-12-2013, 05:41 AM   #776
Spaggy
Spaggy's Avatar
Oddometer: 974
Pretty nifty, I like the plug in wiring. I spent all day yesterday building one for my bike and scrapped the whole shitteree because it looked like scrap metal. Do you think those 2 little screws are strong enough to support that setup?
Spaggy is offline   Reply With Quote
Old 03-12-2013, 05:50 AM   #777
jdbalt
Oddometer: 195
Stability
I was wondering the same thing. The whole mount is on what amounts to an arm mounted at one end. I would think that off road it will vibrate. But maybe it will be fine. The arms look pretty sturdy. I guess you could always put a rubber grommet or something half way up the arm to stop the vibration. Fantastic machine work. It looks like it was bought off the shelf!
jdbalt is offline   Reply With Quote
Old 03-12-2013, 08:22 AM   #778
kalleswe
Clown
kalleswe's Avatar
Oddometer: 13
Yes, you guys are right on spot, the setup is sturdy but for more offroad conditions I will put some rubber that attaches to ledge below to minimize vibration and to support the screws when landning from a 30 metres jump...
Old 03-12-2013, 10:51 AM   #779
lukeinlondon
lukeinlondon's Avatar
Oddometer: 431
when i get my next day off gonna fit some spoke wraps to my rear tyre ;) will post pics..
duh...what i am thinking..
I ordered a BestRest FitKit for my bike for a day trip on Saturday to the SCTA trials in Johnson Valley ( with the missus and the little pup )
Ordered Dainese Drake Air Pants for RevZilla..$10 back in Revzilla credit as well
lukeinlondon screwed with this post 03-12-2013 at 10:56 AM
lukeinlondon is offline   Reply With Quote
Old 03-12-2013, 11:27 AM   #780
Ravenslair
Oddometer: 484
Just tell me how to pay for one!
Ravenslair is offline   Reply With Quote
Times are GMT -7.   It's 03:31 AM.
