Old 03-22-2013, 01:15 PM   #841
Ken Fritz
Oddometer: 1,024
1150GS Rocket Sprockets installed - almost
Almost done - stopped for lunch. Will also adj valves and rockers, synch throttles, change oil & filter, change trans. and final drive, clean a/filter, install TKcs front and rear, lube rear brake pad pin, chk final drive and swing arm pivot. Gettin' ready for Baja.... Can't wait!
Ken Fritz is offline   Reply With Quote
Old 03-23-2013, 06:08 PM   #842
UAS
Oddometer: 106
Well not actually "...to your GS..." but for the GS...ordered the Sport Muffler, BMW Akrapovic, from MaxBMW at 30% off list...just couldn't help myself...installation will be "to your GS..."
2012 GSA Triple Black
UAS is offline   Reply With Quote
Old 03-23-2013, 07:37 PM   #843
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,748
Between Christmas and New Year's day, I dug into my 1150 to replace the clutch and clean up the combustion chambers. The bike had 101k miles on the clock, and I had a week off work to do the job, so the timing worked out well. During that job, I found the upper exhaust valve in the left head was burned. Not having the time or resources to do a full valve job on the head, I took some careful measurements and determined that a simple valve replacement *might* work. A call to Max got a set of valve seals and a new exhaust valve on the way. When they arrived, I put it all together, crossed my fingers and hoped for the best. Using the right cylinder as a reference, the left was near exactly identical for hot and cold compression.
Today marked the 5k mile anniversary, I rechecked compression. Both cylinders were equal with each other AND the readings taken just after reassembly.
I'm not ready to say I got away with massively bending the rules of head work, but I think I bought myself a good bit of time to find another set of heads and get them properly redone.
Twilight Error is offline   Reply With Quote
Old 03-23-2013, 08:10 PM   #844
abruzzi
abruzzi's Avatar
Oddometer: 1,000
Bought it! Well, more than that. I flew from El Paso to Orange County. Met the seller. Did the deed. Then rode 250 miles to Yuma AZ. 500 more miles tomorrow.
Me likey.
Geof
http://tigertriple.com/
abruzzi is offline   Reply With Quote
Old 03-23-2013, 08:15 PM   #845
jwt67
Oddometer: 67
Put 176 miles on the new R1200GSA in temps of 35-38 degrees! Dam this has been a long miserable winter! I just had to get out and ride!
jwt67 is offline   Reply With Quote
Old 03-23-2013, 10:15 PM   #846
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
Me likey.
Geof
Gratz on the new bike... What year is that? It looks like a 2004...
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 03-24-2013, 07:54 AM   #847
abruzzi
abruzzi's Avatar
Oddometer: 1,000
Yup. 2004. 24024 miles when I picked it up. Though this is my first BMW bike, it is not my first BMW boxer twin. Years ago I had a BMW 700 coupe. But parts were hard to find for it, so I sold it (sadly.)
If you're in San Clemente, you may know the bike--the seller was in Laguna Beach. He recently bought a 1200gs, so this was for sale.
Geof
Old 03-24-2013, 11:02 AM   #848
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 2,018
54k service...
Exhaust valves were tight, really tight
Never been tight before. I'll check again in 2k and see.
March 2014 is end of extended warranty... it better fail before then
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 03-24-2013, 12:55 PM   #849
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,511
Originally Posted by trc.rhubarb View Post
54k service...
All of them? Are you sure you properly found TDC?
Jim
JimVonBaden is online now   Reply With Quote
Old 03-24-2013, 03:44 PM   #850
canuck76
canuck76's Avatar
Oddometer: 162
Me likey.
Geof
Very nice low mileage esp for the year. Already decked out with the expensive stuff too!
Canuck76
2006 BMW R1150GSA
Eventually, socialists run out of other peoples' money
canuck76 is offline   Reply With Quote
Old 03-24-2013, 04:48 PM   #851
Import
Import's Avatar
Oddometer: 335
Just fitted my new adv stickers today.... Then took off on a 150km test run to make sure they stay put......... +2 was a little chilly, but full sun and almost no traffic was awesome.....just had to ride. Only saw 1 other motorcycle!! Weather can't get much better, where is everyone hiding?
Import is offline   Reply With Quote
Old 03-24-2013, 06:37 PM   #852
TurkeyRun
TurkeyRun's Avatar
Oddometer: 112
- Tires f&r
- Rear rotor (PO let it get metal-metal)
- brake shoes all around
- Touratech lowered pegs
- Touratech 1" handlebar risers
- new Moose Racing windshield
- 2012 XL1200C (Hers)
- 2002 R1150GSA (Mine)
- 2014 FLHTK (Ours)
- 2000 Ural Patrol (ummm... project?)
TurkeyRun is offline   Reply With Quote
Old 03-24-2013, 09:05 PM   #853
staudio
Time for a ride...
staudio's Avatar
Oddometer: 206
Me likey.
Geof
Great looking bike...congratulations
enjoy every sandwich....
staudio is offline   Reply With Quote
Old 03-24-2013, 09:21 PM   #854
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
Went for a tank-full ride today. Got to test out my new helmet, a Shoei Hornet DS. I'm pretty happy with the new lid...
Old 03-25-2013, 01:59 PM   #855
Hikertrash
Oddometer: 2,914
Installed Touratech fuel bottle holders to my pannier. I purchased the double bottle rack and cut it in half for easier access to the pannier lock. It was cheaper than buying two single bottle racks, too.
Hikertrash is offline   Reply With Quote
Times are GMT -7.   It's 09:40 AM.
