Old 04-07-2013, 07:55 AM   #976
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,895
Oil and filter on the '02 GS. Replaced the lower half of the Touratech Engine Bars that were left off after the last service..................
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is online now   Reply With Quote
Old 04-07-2013, 08:28 AM   #977
Giggity
Giggity's Avatar
Oddometer: 754
Originally Posted by abruzzi View Post
I had a 705 go bubbly on my Tiger, which has made me go a little gun-shy on using them again, though my understanding is they fixed that problem.
Geof
You mean like this?
I noticed this after a ride last Sunday so I ordered up a pair of 712s and installed the front Friday night.
That first pic is after about 5000 miles.
Giggity is offline   Reply With Quote
Old 04-07-2013, 10:08 AM   #978
roadtrip22
roadtrip22's Avatar
Oddometer: 336
Originally Posted by roadtrip22 View Post
No photo's yet but here what I got in the mail yesterday
Installed last night
-Brake Reservoir gaurd from Touratech
-Clutch Reservoir Guard from Touratech
-Aluminum Skid plate from Touratech
-Oiler cooler Gaurd from Wunderlich
-FD lever guard from wunderlich
-Fuel rail Gaurds from Touratech
-Potentiometer Guard from Alt Rider
-Pannier organizers from ADV design
-Front fork bump stop from Touratech
-Fixed mounting bracket on the fog lights because the plastic is cheap
Ran out of beer and will install tonight
-Touratech locking mount for Garman GPS zumo 660
-Also install the Garman Zumo 660 from Touratech
-Fuse block from Twisted Throttle
-Krista's LED lights from Clear water
-2 more aux ports up on front fender by cluster. (still waiting to come in the mail)
-cool stickers
then of course test drive and more road trips
All for a 08 GSA.
Still Awaiting the Fuse block in the mail. Once I have that I'll take the tank off and wire up the Krista's and the GPS so it is all nice and clean and Factory looking.
Follow me on Facebook--- http://www.facebook.com/2wheeladventures
100 things all GS owners should read---http://advrider.com/forums/showthread.php?t=836736
Repair and Maintenance DVD's--- http://www.jimvonbaden.com/
roadtrip22 is offline   Reply With Quote
Old 04-07-2013, 10:47 AM   #979
abruzzi
abruzzi's Avatar
Oddometer: 1,005
Originally Posted by Giggity View Post
You mean like this?
Yup. Exactly like that. When you get the tire off, and look at it from the inside, you should be able to tell that the tread is separating from the inner plus.
Geof
http://tigertriple.com/
abruzzi is offline   Reply With Quote
Old 04-07-2013, 12:08 PM   #980
WoodButcher
WoodButcher's Avatar
Oddometer: 2,113
30k mile service and new alternator belt. Learned you can get the cover off without removing the crash bars. Then learned that the JVB crescent wrench trick won't work with the crash bars on. oh well, now I know how to get the crossbar off.
Rusty
2009 BMW R1200GS Adventure
WoodButcher is offline   Reply With Quote
Old 04-07-2013, 03:35 PM   #981
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,052
I've done it, but it isn't easy!
Jim
Old 04-07-2013, 04:10 PM   #982
WoodButcher
Oddometer: 2,113
Jim
Well, if I modified my shorter crescent to open an extra eighth of an inch I could have done it with that one, but my 12" had clearance issues with the left exhaust. As I mentioned, I was just as happy learning how to get the crash bars off. Next time I'll try harder with the bars on.
I do appreciate that YouTube video of using the wrench.
Rusty
Old 04-07-2013, 04:22 PM   #983
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
Originally Posted by selil View Post
Added the Adventure designs engine guard extensions, the Touratech fuel injector protectors, large side stand foot, and z-technic windshield adjusters. Lots more to be done.
Are you zTechnik windscreen adjusters loose? No matter how I adjust them, the adjuster itself is not tight. It is secure and will not come apart or rattle off, but the windscreen shakes a lot on bumpy roads and off road.
I think I can fix it with a nylon washer on both sides... What do you think?
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 04-07-2013, 08:04 PM   #984
Giggity
Giggity's Avatar
Oddometer: 754
Geof
How nutty that we both have 614 posts? Anyway, I looked inside my tire and it was perfectly smooth. Oh....I had 7000 miles on it, not 5000.
Old 04-07-2013, 08:09 PM   #985
abruzzi
abruzzi's Avatar
Oddometer: 1,005
Now we both have 615... Mine had somewhere between 6500 and 7000 when the bubbles developed. On the inside of the tire, I could see bubbles bubbling inwards as well.
Geof
Old 04-07-2013, 08:13 PM   #986
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,064
I synced the carburetors on my 2001 and mocked up the Gobi bags I'm gonna put on. The tire change I had in mind reeked of effort so I drank some beer and cleaned the garage a bit instead.
larryboy is online now   Reply With Quote
Old 04-07-2013, 09:47 PM   #987
Ravenslair
Oddometer: 495
Geof
Were you guys running the radial 705's? Just curious as I had heard the radials did not have this issue. Would like to know if that is really the case or not.
Ravenslair is offline   Reply With Quote
Old 04-08-2013, 03:59 AM   #988
Boondox
Travels With Barley
Boondox's Avatar
Oddometer: 3,036
One of my original Shinko 705s delaminated like that, but I never had an issue with the radials. Switched to TKCs only because most of my riding was on dirt roads and I needed the traction in loose stuff.
I got a sidecar to travel with my dog. He never complains, is delighted to be with me, approves of my dietary choices, is a social butterfly who helps me meet folks, appreciates a good beer, snuggles better than my wife, and hangs on my every word as if it's the most profound thing he's ever heard. TravelsWithBarley.com
Boondox is offline   Reply With Quote
Old 04-08-2013, 10:28 AM   #989
abruzzi
abruzzi's Avatar
Oddometer: 1,005
I honestly don't know if it was a radial or not--it was a 140/80 if that helps. Like I said before I had heard that the problem was solved, and no longer an issue, but I'm still a bit gun shy.
Geof
Old 04-08-2013, 10:34 AM   #990
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,772
After MotoGP on Sunday Poolside and I inspected the bike a bit. He felt and heard the clutch making sounds like the master cylinder is shot. There is a lot of play and wobble in the lever. So much so the underside of the lever is worn. The bushing is junk. New master cylinder and lever run at a few cups of high test coffee over $600!
We don't find a good used one, I'll be forced to buy new, if available.
I realize they are covering their asses, but a non-rebuildable mastercylinder and a lever for $121.
That is piss-poor engineering. I don't mind wearing stuff out as I near 200,000 miles, but this bike costs so damned much per mile to keep on the road, you'd think it was up to my parts purchases to pay for all those free oil changes they do on the cars.
For now the thing is parked in the garage. I am more certain now than ever I am not going to keep it to try for 300,000 miles. We have hit the way too damned much to ride cost target right dead center. I'll roll through 200,000, then service and detail it and it'll go to the Fleamarket. Yes, in a lot of ways I'll hate to see it go, but it will have been a good run.
And I'll go bike shopping.
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Times are GMT -7.   It's 05:44 PM.
