Old 04-13-2013, 07:38 PM   #1036
MoodyGS
Going round the bend
Location: Monte Nido, Santa Monica mountains, Californiay
Oddometer: 184
Help with wind
Originally Posted by MotoBoss View Post
Question;
I have a 2002 R1150GS with an Adventure tank on it. I have the stock windshield with a Wnuderlich wind deflector http://www.wunderlichamerica.com/motorcycle/R1150GS/8110024-025.html
but still have an uncomfortable amount of buffeting coming from the bottom of the screen around the tank.
How to fix it? Any suggestions?
Thanks-
I installed the Cee Bailey winglets on my 2012 r1200gs with stock shield and they made a considerable difference on the buffeting you mention. Only $45:00 if I recall?
MoodyGS is online now   Reply With Quote
Old 04-13-2013, 07:55 PM   #1037
TOTim
TOTim's Avatar
Oddometer: 183
Today was change the OEM front shock to a newer OEM shock, battery service and rear brake service.
Now I just need spring to get here.
TOTim is offline   Reply With Quote
Old 04-13-2013, 08:00 PM   #1038
bone13
bone13's Avatar
Oddometer: 281
well yesterday... Re-tuned my throttle bodies, and Installed a set of mrk3 Pivot Pegs on my R1150GS.
Liked Pivots for the ride to work today. Tomorrow they get the Dirt-n-Gravel test!
The Trouble with Trouble is it usually starts with Fun
www.ridgerunneradventures.com
bone13 is offline   Reply With Quote
Old 04-13-2013, 10:03 PM   #1039
rgb2cmyk
rgb2cmyk's Avatar
Oddometer: 255
Question;
Thanks-
I still love my MRA X-creen.
_
14 R1200 GSA (Hopefully lasts longer than 2yrs)
12 R1200 GSA ("Sandy") (Hit by DUI)
09 R1200 GSA (Totaled by SS Sandy)
06 Husky TE450, 04 R1100s BCR, 03 F650CS
rgb2cmyk is offline   Reply With Quote
Old 04-13-2013, 10:04 PM   #1040
rgb2cmyk
rgb2cmyk's Avatar
Oddometer: 255
Rolled over 1000 miles on the bike today. it took forever to get there too.
The next 1000 will come a lot quicker I promise
_
Old 04-13-2013, 11:35 PM   #1041
NorthernBoxer
Fükengrüven
NorthernBoxer's Avatar
Oddometer: 551
Wicked
Added an AltRider rear rack:
About 8 inches of extension out the back:
Perfectly flat level with my cases:
Just think of all the stuff I can stack on there now!
- Scott
Team Pterodactyl
Hooligan Padawan Learner
NorthernBoxer is offline   Reply With Quote
Old 04-14-2013, 02:27 AM   #1042
maxfnz
Oddometer: 59
New stainless lines all round (1100 ABS, so 4 at front). Venhill from UK via Motobins.
Full brake fluid flush incl calipers.
New tank drain lines.
Took out limit stop screw on rear brake pedal (one that hits the stop light switch) & adjusted piston offset so pedal sitting as high as possible
To do
- new brake pads (prev owner has Vesrah; work but not much feel IMHO. Probably go for MetalGear.)
- replace fuel lines (still original 96 so well due)
- oil cooler
- IAT offset resistor
- fix sticky tripmeter (grr)
- derust & respray Givi sidecase luggage frame
- fit LED stop & tail light
- check wiring loom for problem areas (seems all the protective plastic sheathing is either cracking or splitting! 1996 vintage; anyone else seeing this?)
maxfnz is offline   Reply With Quote
Old 04-14-2013, 07:19 AM   #1043
Tex76
Motersykle Advntyers
Tex76's Avatar
Oddometer: 870
5500 miles so far on my girl so I did an oil change and transmission flush. Will change the final drive oil next weekend, just being safe. I also finally got my BDCW skid plate mounted. I now feel like I'm riding a sherman tank...with another sherman tank mounted on its belly
"We act as though comfort and luxury are the chief requirements of life, when all that we need to make us happy is something to be enthusiastic about."
2007 BMW R1200 GSA, 2009 DL1000, 2005 DR650
30:Unemployed and Homeless (2 months and 10,000 miles)
The Lost Texan, Wanders East
Tex76 is offline   Reply With Quote
Old 04-14-2013, 11:33 AM   #1044
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
I replaced the external torx screw on the back of the shifter arm with a normal allen head screw, thus reducing the contents of my tool kit...
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 04-14-2013, 12:18 PM   #1045
parkbum
parkbum's Avatar
Oddometer: 19
Went for a ride in a spring snow storm. Roads where wet and I had a big grin on my face.
parkbum is offline   Reply With Quote
Old 04-15-2013, 08:39 AM   #1046
Spaggy
Spaggy's Avatar
Oddometer: 976
Got more of this.
So, instead of doing this.
I installed these.
Spaggy is offline   Reply With Quote
Old 04-15-2013, 09:24 AM   #1047
bighopper
Oddometer: 191
Originally Posted by Rockmuncher View Post
Got more of this.
I installed these.
Alberta were the weather changes every few minutes. But it's getting warmer so out to the garage & do some service work this week to have the 2 girls rady for when they can get out on the black top &/or gravel .
I Just Like To Ride
'03 BMW R1150GSA
'06 BMW K1200LT
bighopper is offline   Reply With Quote
Old 04-15-2013, 09:59 AM   #1048
cheetahman
Oddometer: 9
Clutch replacement
I just spent the last two weekends replacing the clutch on my 2002 R1150 GS for the second time. First time, 2006, paid a mechanic to do it. This time, I did it myself after researching all the articles on this forum. Very helpful.
Both clutch failures happened about 20,000 miles apart, because the slave cylinder leaked and the fluid went down the rod and soaked the clutch disc. First time I bought all stock BMW parts from AJ Cycles. This time I purchased a Seibenrock disc and the spring and pressure plate pieces from a BMW parts web site in England. Even with the shipping I saved over $75 from the best price anywhere in the USA. The only thing I didn't get overseas was the new clutch slave. I bought one from Max due to multiple recommendations on this web site, claiming that Max has the very best slave cylinders. Why they are different, I don't know but that's the word anyway.
I also drilled a weep hole in the transmission housing under the slave cylinder. Now if the thing fails again, hopefully the fluid will run out on the ground instead of travelling up the rod to it's final destination on my clutch disc. I don't do deep water crossings, but if you do regularly, I'd think twice about this solution. I also corrected quite a few things that the first guy messed up on.
Also I changed out the rear chunk for the lowest gear ratio I could find. I really like it as it makes taking off on a hill, much nicer on the clutch, and sixth gear is no longer usless on secondary roads.
Lastly I installed speed bleeders and did a complete bleed of the clutch and brake fluid. I paid a dealer last spring to do it, but judging by the dark brown muddy color, I am not sure he did what he charged me for.
This has been a very nice bike, but reliability issues do crop up, so I'm not drinking the "BMU ultra reliability" Kool-Aide anymore. I'll stick to the Guiness.
cheetahman is offline   Reply With Quote
Old 04-15-2013, 11:03 AM   #1049
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,717
Got the Master cylinder for the clutch from the eBay seller. Purchased on Monday and showed up at the house on Wednesday. Cool.
No time to mess with it other than look at it, (seems new, other than a tiny bit of dust here and there.)
Installed my Touratech risers
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 04-15-2013, 01:20 PM   #1050
Daz the Aussie
Dualsporting Actor
Daz the Aussie's Avatar
Oddometer: 960
Fitted ROX risers and added some winglets...
The reach on my bike has been a bit too much for me so I ordered some ROX 2" risers that I added to my 1" Touratech risers for a bit more height but more importantly for better reach. Its perfect now and I sit in a more neutral upright position.
Also for a while now I have been contemplating buying the Rugged Roads Winglets for bikes with Tobinators but the cost and the unknown factor of how much of a difference they would make was holding me back. Finally I thought "Stuff it, how hard can it be to make some?"
Turns out, not that hard.
These are my prototype set, I will make a few minor adjustments to the next pair but I can confirm that they work really well and arrest a lot of the air that rushes along the tank and sweeps up onto your body as many others have attested to with this bike. I'm pretty chuffed with the result as they only cost me about $10 to make which is a heck of a saving on the Rugged Roads units at around $120 delivered.
I also finally got around to painting my rear rack and Touratech rack.
"We need a new thread for fuel tank capacity bitching." - Super Sneaky Steve
"Where do I go now that I've gone too far?"
My actor site: www.dazbyard.com
Daz the Aussie screwed with this post 04-15-2013 at 04:30 PM
Daz the Aussie is offline   Reply With Quote
Times are GMT -7.   It's 02:43 PM.
