Old 06-02-2013, 09:32 AM   #1381
guitarin
Oddometer: 176
Originally Posted by Rockmuncher View Post
Added a set of grip puppies the other day. Rode with them for a while and thought they really took the feeling away from the throttle. Then after washing my bike, I noticed the performance was awful. Turns out the puppies were turning on the grips. Pulled over and ripped them off, way better. These things are shit.
I have used Johar radgrips and grip puppies on all my bikes since 1979. I install them using hairspray as a lube to get em on. When dry they do not move at all. very comfortable on long trips.
guitarin is offline   Reply With Quote
Old 06-02-2013, 09:38 AM   #1382
guitarin
Oddometer: 176
Originally Posted by tjt94 View Post
$18 per spark plug? Holy shit! I paid. $3 rack for autoliites at auto zone.
The camhead uses a different plug. Cannot find across ref to a cheaper one. And they are simple copper plugs. I called NGK and spoke to an engineer. Was told they are an odd size and no iridium offered. Kinda sucks.
Old 06-02-2013, 10:19 AM   #1383
terryckdbf
Oddometer: 1,103
WOW! $100 for a quart of gear oil. I see they used 140, is that what you use Jim?
Terry
terryckdbf is offline   Reply With Quote
Old 06-02-2013, 10:32 AM   #1384
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
Terry
I believe you misread the invoice... It's $24.54 / gal, therefore 0.25 gal = $6.14... Not even BMW rapes us that bad...
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 06-02-2013, 11:07 AM   #1385
terryckdbf
Oddometer: 1,103
Yeah, brain not working, thanks.
Terry
Old 06-02-2013, 11:59 AM   #1386
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
Terry
no worries...
Old 06-02-2013, 12:38 PM   #1387
rebake
rebake's Avatar
Oddometer: 1,063
New set of tourance next on this morning.Started on a test ride,headlight was out.....Ed
amish people think i dress funny
rebake is offline   Reply With Quote
Old 06-02-2013, 04:25 PM   #1388
Ravenslair
Oddometer: 497
Replaced the rear pivot bearings on my '04 GSA to fix the movement at 3, 6, 9 and 12. Movement appeared to be fixed when wheel was off and everything was torqued. Mounted wheel and movement still there. Maybe I have front pivot bearing issues as well. Will pull the rear swing arm when I get a chance to replace or check the front bearings as well as check the front u-joints of the driveline. Only 25k miles, but would be good to check .The rear u-joints were nice and tight. Rear driveline oil (with 5k miles on it) was very clean with no metal in it. Movement is still present with rear brake on. The clean oil and movement with brake applied tells me I do not have a big bearing issue.
I need to find a local inmate with more experience to confirm I have an issue with my bike or with my worry beads. One of them needs addressing.
Ravenslair is offline   Reply With Quote
Old 06-02-2013, 05:41 PM   #1389
Yellow Iron
Yellow Iron's Avatar
Oddometer: 3,103
I made a discovery today. I was getting ready for an upcoming trip and looking for my homemade axel tool. Then I figured this out.
The Hex end of a spark plug socket fits perfect
flip the socket and install a long extension and you got it
Bigger Better Faster More----4 non blondes
Feel the Power of the Wheel
Yellow Iron is offline   Reply With Quote
Old 06-02-2013, 06:11 PM   #1390
studad
studad's Avatar
Oddometer: 941
Going to the garage to check that! Love it.
studad is offline   Reply With Quote
Old 06-02-2013, 06:26 PM   #1391
'05Train
Mind is not for rent
'05Train's Avatar
Oddometer: 1,086
Traded it in. 16 quarts of oil added between services over the course of 19,000 miles is unacceptable, no matter what the Mothership says.
Thanks for the memories y'all.
Sent from my iPad, probably while I'm pooping.
2005 FXSTB/I
2014 K1600GTL
2014 KLR650 NE
'05Train is offline   Reply With Quote
Old 06-02-2013, 06:38 PM   #1392
STUFF2C
We Ain't Left Yet!!
STUFF2C's Avatar
Oddometer: 3,066
WOW! mine uses very little (1/2-3/4 qt maybe) between 5k mile changes. I use Castrol 20/50 gtx non-synthetic.
Thanks to the Interstate Highway System, it is now possible to travel from coast to coast without seeing anything.
-- Charles Kuralt
I never plan a ride, just the destination and that's always subject to change.
STUFF2C is offline   Reply With Quote
Old 06-02-2013, 06:55 PM   #1393
TuonoBiker
Oddometer: 813
Whoa!!! Slow the train down, Train!
Well, congrats I guess. Sorry to hear it turned out this way. I couldn't help but think about your situation as I was stopping by a gas station last weekend because my oil light came on. I should have topped off before the trip, but forgot. And as I was filling it, I couldn't help but think....over $20k for this bike and it burns oil like I've never seen a modern engine burn oil. Oh wait, only 5300 miles on her...another 20k miles before its "broke in". I'll say it before the choir boys chime in...
Well, good luck with the new scoot....whatdja get!?!?!
'12 R1200GS Adventure
'06 Ducati 999S
'11 Harley Street Glide - gone and mostly forgotten
'07 Tuono Factory - gone but not forgotten
TuonoBiker is offline   Reply With Quote
Old 06-02-2013, 07:07 PM   #1394
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,462
Old news.
Try cutting the end off of it and just carrying that.
From 2005 when I first posted it.
Jim
Old 06-02-2013, 07:13 PM   #1395
jd2577
The Boy Ruger
Oddometer: 119
Last week I put on the grip puppies. Today I installed the Rox Risers and took my SO on her first motorcycle ride. We didn't go far - only about 30 miles - but she absolutely loved it.
Bars before Rox Risers
Bars after Rox Risers
Fairly simple and straight forward install. Went with some ADVice from a former post and dropped the right fork tube in order to re-route the brake line.
Next on the list is the installation of the GPS power wiring, ADVMonster LEDs, and battery volt meter.
jd2577 is offline   Reply With Quote
Times are GMT -7.   It's 10:27 PM.
