Old 11-02-2012, 11:28 AM   #1
keener OP
Speed changes you.
keener's Avatar
Oddometer: 928
design/build opensource products for KTM, starting with sidestand foot expander
I had a home made side stand foot that basically makes the foot print a bit larger so it won't sink in sad, grass,....you know what I mean. It fell off somewhere....Im sick of forgetting the ones I carry with myself, so...
I have a CNC machine. I'm going to make one for myself. Not for $56 like this one, better with rubbery bottom plate may be?
image source: http://www.motosupply.com/specialty-...77ac605e92f68f
I though I share it here to see if you advriders have any input. I will keep the designs open-source, I will post the drawings here for everyone to use.
I know this project is very simple thing but it could potentially become a good starting point for more open-source community driven products for 950/990,... so all manufactures can produce them cheaper for us while we can make them better.
I'll be happy to make a few more while Im making one for myself and send it over to whom ever helps out with the design.
let me know what you look for in a side stand expander. do you want to be able to take it on and off,...?
Im curious to see how this evolves.
04 ADV 950
keener is offline   Reply With Quote
Old 11-02-2012, 11:36 AM   #2
Peanuts
Peanuts's Avatar
Oddometer: 1,607
I just welded a bigger steel foot onto mine.....
Peanuts is offline   Reply With Quote
Old 11-02-2012, 11:41 AM   #3
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,642
For simplicity I've been considering welding a large freeze-plug from an auto engine to the side stand.
Talk about cheap!
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 11-02-2012, 01:04 PM   #4
SS in Vzla.
Totally Normal? I'm not!
Oddometer: 1,193
Same on mine. Cheapest solution there is, works well and it won't ever fall off.
SS. '98 BMW F650 / '06 WR250F / '07 KTM 990 Adv
Caracas, Venezuela
SS in Vzla. is offline   Reply With Quote
Old 11-02-2012, 01:25 PM   #5
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
Welded a big ass washer to it. Took 5 minutes, cost was trivial.
However, I do have a template for making an air filter baseplate for mounting a JC30 airfilter like the CPR one uses. You're welcome to it. Makes the filter mod more of an approx. $150 deal versus $300.
Sporting Wood screwed with this post 11-02-2012 at 01:31 PM
Sporting Wood is offline   Reply With Quote
Old 11-02-2012, 01:30 PM   #6
Hipster
Hipster's Avatar
Oddometer: 1,798
+1
Originally Posted by sporting wood View Post
welded a big ass washer to it. Took 5 minutes, cost was trivial.
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 11-02-2012, 03:57 PM   #7
keener OP
Speed changes you.
keener's Avatar
Oddometer: 928
Welding a washer sounds simple and cheap... We have a solution here.
Washer I think has to be thick so you can weld it. Painting it later is a good idea to prevent rust.
I have shortened my sidestand, I went through cutting welding,...I should have used a big ass washer then.
Now I like to have an aluminum piece as foot expander.
The air filter base should be easy to make. Send me your template.
04 ADV 950
Times are GMT -7.   It's 06:07 PM.
