10-27-2012, 05:33 AM
#1 |
Oddometer: 822
Oil tank screen
Serviced bike yesterday,my oil tank screen had small bits of rubber on it. Is this the water pump seal coming apart? None on the lower screen. No water in the oil.
10-27-2012, 11:41 AM
#2 |
let's keep going...
Oddometer: 987
Gray or Black?
What color is the rubber you found? The OEM water pump seal is battleship-gray, and it's the shaft that wears grooves into it which allows the coolant/oil exchange past the seal lips- the lips take a beating & wear so it needs replaced at the same time to maintain a tight seal
If the bits are black more likely cam chain guides...
Britt '06 KTM 950 Adv 'S' '03 KTM 250 EXC '88 KLR650 - +170K miles "looks like you've had a lot of fun on that bike..." |
10-28-2012, 08:13 AM
#3 |
Oddometer: 822
Bits
They are definitely black.
10-28-2012, 04:05 PM
#4 |
Oddometer: 2,323
Inside layer of one of the rubber hoses between the scavenge pump and the oil tank?
I've had them delaminate in other applications, but don't know for sure the LC8 has rubber hose in this location. |
