Old 10-29-2012, 12:50 AM   #1
bushyb OP
bushyb's Avatar
Oddometer: 74
Difficult to get on and off main stand.
Bike is difficult to get on and off main stand.
I have notice the bike is pretty difficult to get onto and off the main centre stand. What could the cause of this be? The bikes front wheel is about 2 inches off the ground when on the main stand. Is the something specific that I should be looking for?
bushyb is offline   Reply With Quote
Old 10-29-2012, 01:06 AM   #2
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,471
Is this something new or a continuing problem? There is a certain technique for raising it on the stand. Stand on the foot, not the tang, and pull up and back with both hands. That said, it doesn't hurt to lubricate the pivot pins on occasion and if the rear is even slightly uphill it can be a real bitch.
Big Bamboo is online now   Reply With Quote
Old 10-29-2012, 01:30 AM   #3
orangebear
orangebear's Avatar
Oddometer: 1,253
i am only 5.8 and 9stone and can get my r100gs on to the centerstand ok .
i stand on the food of the stand and then have my left hand on the bars and my right hand on to the lift handle and then just pop it on to the stand.
what bike is it ????
does it have the right center stand?
have you used the lift handel? it be on the left side of the bike just under the seat.
suzuki gsxr 600 srad sound fun bike
bmw r100gs i sold as it be came to unreliable.
road legal stomp pitbike sold
Klr 650 the worst ever made
Honda xl125rc powered by a cg125 block fun wee bike
orangebear is offline   Reply With Quote
Old 10-29-2012, 04:01 AM   #4
chasbmw
Oddometer: 2,121
What bike?
Charles
1971 Commando Fastback
Old 10-29-2012, 04:29 AM   #5
ME 109
ME 109's Avatar
Oddometer: 2,580
Originally Posted by chasbmw View Post
What bike?
82 RS, Chas.
At best, they are not a user friendly stand. At worst, they are a piece of shit.
Front wheel @ 2'' off the ground is not toooooo bad.
Take it off and check the bushes etc for wear.
While it is on the bike, check for binding/scraping marks and rectify if needed.
Lord of the Bings, kangaroo farmer
ME 109 is online now   Reply With Quote
Old 10-29-2012, 04:38 AM   #6
bikerfish
flyfishandride
Oddometer: 1,558
with use, the stand will wear where it contacts the stops on the frame, allowing it to go too far past center. I've taken them off and had built the area back up with welding, then ground it down to get the proper fit again. takes some trial and error, but once done, the stand will work very nicely. doing that and getting new pivot bolts and bushings, AND maintaining them, will go a long ways in keeping the stand easy to use.
bikerfish is online now   Reply With Quote
Old 10-29-2012, 04:41 AM   #7
orangebear
orangebear's Avatar
Oddometer: 1,253
if the bike is the same size ish as a /7 then check you have the right center stand? as if the stand is to big then it be a pain to get it on.
plus i found my /7 to be easyer then my gs to pop on to the stand.
Old 10-29-2012, 01:10 PM   #8
More_Miles
über-n00b
More_Miles's Avatar
Oddometer: 312
Originally Posted by ME 109 View Post
82 RS, Chas.
I concur, I have an 83 that is a royal pain. Mine is better, for values of better, since I replaced the worn out stand and bushings with new. I even fiddled with a Reynolds "Ride Off." With all it's problems, I still prefer the stock stand. As far as looking for problems, like ME109 said check to see if the bushings are worn out, and the holes in the stand haven't gone egg-shaped. Both those will make a difficult stand damned near impossible.
Larger than life and twice as ugly!
My photos: stewie.smugmug.com
More_Miles screwed with this post 10-29-2012 at 01:39 PM
More_Miles is offline   Reply With Quote
Old 10-29-2012, 01:37 PM   #9
Biebs
BMW Airhead
Biebs's Avatar
Oddometer: 497
Laugh Stand Tip
Do not get on you bike while on the Center Stand. Better to get the bike off of Center Stand and then mount - Center Stands are not made for the weight of rider -
Tip to keep Center Stand working better longer!!!!
Biebs is offline   Reply With Quote
Old 10-29-2012, 01:58 PM   #10
ME 109
ME 109's Avatar
Oddometer: 2,580
Welding the stand to rebuild metal where it is needed is a task that needs to be done with care, so that both sides of the stand are contacting the 'stopper' on the frame.
I put my bike wheels up on 3" high blocks, as well as the side stand. This allowed me to remove and refit the centre stand with ease as I ground the weld metal to exactly where I wanted it.
I increased the width of the welded 'contact pad' to better contact the stopper on the frame.
My stand is now an excellent bmw 'ride-off' stand. Great for when The bike is fully loaded for touring.
I don't care if it wears the bushes etc. I'll fix it again.
Old 10-29-2012, 02:39 PM   #11
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,537
whack the vin into realoem and find out the build date. the 80/81 machines had a unique mainstand. if you fit a later sta nd you end up with the problem you're describing.
Rob Farmer is online now   Reply With Quote
Old 10-29-2012, 03:01 PM   #12
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,003
On an '82 RS it's likely the stand is worn.
They never were particularly easy, for sure not as easy as current BMWs.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 10-29-2012, 03:02 PM   #13
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,462
I agree.The 83-84 stand was a big improvement. While your at it replace your sidestand bushing with the 83-84 style so the bike doesn't lean over so far.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 10-29-2012, 03:16 PM   #14
ME 109
ME 109's Avatar
Oddometer: 2,580
A friend with an 83 RS has just finished doing the weld build up thingy. Seems none are immune.
Old 10-29-2012, 03:26 PM   #15
Boxer Metal
Mad Scientist
Oddometer: 3,462
Remember this bikes are almost 30 years old. They do wear down over time.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Times are GMT -7.   It's 04:25 PM.
