Old 10-30-2012, 08:56 AM   #16
chasbmw
Oddometer: 2,352
Follow ME109's advice. I did the same on my 82 and it is better, but I depend on the Surefoot side stand when carrying luggage.
Charles
1971 Commando Fastback
Old 10-30-2012, 08:58 AM   #17
chasbmw
Oddometer: 2,352
Follow ME109's advice. I did the same on my 82 and it is better, but I depend on the Surefoot side stand when carrying luggage. It's a pity that BMW got it so wrong after the good stand on my 75.
Charles
Old 10-30-2012, 01:29 PM   #18
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,220
I did the weld nad grind, also.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 10-30-2012, 07:36 PM   #19
bmwrench
Oddometer: 2,359
Along with a host of other changes made in 1981, the center stand was redesigned. It raised the bikes wheels far more than neccesary, increasing the effort required dramatically. They finally fixed it in 1983. The improved stand can be identified by a patterned pad to press your foot against. I have welded the stops on the '81-'82 stands and shortened the legs of the '81-'82 stands. It's a tedious job.
bmwrench is offline   Reply With Quote
Old 10-31-2012, 12:16 AM   #20
bushyb OP
bushyb's Avatar
Oddometer: 74
Thanks for the advice and photos. I will have to look at it soon.
bushyb is offline   Reply With Quote
Old 10-31-2012, 12:40 AM   #21
ME 109
ME 109's Avatar
Oddometer: 3,142
Start with
finish with
Lord of the Bings, kangaroo farmer
ME 109 is online now   Reply With Quote
Old 10-31-2012, 06:09 AM   #22
jackd
Oddometer: 3,071
+1 on the weld build up method. Someone did it to my GS somewhere back in its life - it worked very well.
Old 11-05-2012, 12:38 PM   #23
bushyb OP
bushyb's Avatar
Oddometer: 74
Originally Posted by ME 109 View Post
Start with
finish with
Thanks for the comments and the great photos. I have taken some photos that can be seen here: https://picasaweb.google.com/109840758061372490709/BMWMainStand# of the current condition of the stand. Some are not so good but use the zoom tool to see them better. Please feel free to copy and edit them and post them here so that we may all benefit from the shared experience.
Not sure how the stand come off but it seems that I will have to remove the sump to get the stand off or am I missing a trick here?
Remember now I am new to Airheads I am use to pre unit Triumphs, and those stands were great especially the '58- ‘62 stand, you just put your foot on the side lever connected to the stand, not the stand and it starts to raise the bike.
Surely there must be a way to modify the stand that by placing your foot on a new modified side lever, using your body weight and with the help of the law of the leaver to make putting the bike on the main stand easier.
Just a final thought is it necessary the front wheal stand so high of the ground? Could one cut a piece out the main stand and get a easier lifting effect.
Old 11-05-2012, 12:55 PM   #24
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,349
Probably technique. I am short, about 5'7" and could get my R100RS (heavy bitch she was, lovely though) and R80RT on the CS easy. BUT I did it by pulling it a few inches further forward than I wanted it actually parked, then pushed the stand down with the foot, and rolled it BACK whilst pulling up on the handle all whilst pushing down with the foot. It'll pop right on that way. Don't try to lift it straight up onto the centre stand.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 11-05-2012, 01:05 PM   #25
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,220
Just did this again today, because i finally got around to it, and now i finally have a stand again. Didnt paint it yet, still mid oil change :)
Old 11-05-2012, 03:24 PM   #26
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
bushy,
Personally I think, unless there is a specific bushing issue as has been mentioned, the G/S is a pita to get on the stand compared to alot of bikes.
I have a '96 R1100RT that weighs well over 600 lbs and it is easier to get it on and off of the stand than my G/S.
I think the intent of off-road use and trail repairs made BMW set the stand up to be more stable, but harder to lift on and off.
As far as getting off the stand, on both of my bikes I just put it in gear, tilt back, and let out the clutch, they drop right off. Pull the clutch in quickly after though....lol
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 11-06-2012, 05:06 PM   #27
_cy_
Oddometer: 6,439
81 G/S is not too bad if one has enough room to pull/lift at same time. a pita get on stand in tight quarters for me.
still not getting how weld mod works ... anyone has any better links to pics?
Old 11-06-2012, 05:21 PM   #28
bikerfish
flyfishandride
Oddometer: 1,706
the area built up with weld moves the stop for the stand, which is the part that contacts the frame, so it doesn't go past center as far. ALL these stands wear, I've welded most of mine over the years. the weld fix, along with new bolts and bushings will make a noticable improvement.
i don't think your gonna get better pics than bushyb's.
also, worn suspension or too much sag will make it much harder to lift the bike onto the stand. if your bike has 35 year old clapped out suspension and the thing pretty much sits on the ground, it's gonna be a bear to get on the stand, regardless of how good the stand is functioning.
bikerfish is offline   Reply With Quote
Old 11-07-2012, 12:01 AM   #29
_cy_
Oddometer: 6,439
no problem with where to add metal. what I was not getting was .. how does adding metal help in getting your bike in the air onto the stand.
all adding metal could do is change where stand stops against frame. this would help with getting bike off center stand which is no biggie.
pivot point has to changed to reduce height bike has to be raised before tip-over. height of stand needs to be reduced or pivot point raised.
currently 81 G/S front wheel is 2in in the air. to deploy center stand, rear end raises 2.5-3in before passing tipping point then hitting stop.
what am I missing?
_cy_ screwed with this post 11-07-2012 at 12:11 AM
Old 11-07-2012, 01:06 AM   #30
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,674
Good points cy. If you go to the effort to remove and weld the stand, then making the oval holes round, buying new bushes and bolts and adding some grease will transform the stand into something very usable. Don't just stop at welding the tip of the stand.
boxerboy81 is offline   Reply With Quote
Times are GMT -7.   It's 12:25 AM.
