Old 10-30-2012, 11:06 AM   #31
toslow
toslow's Avatar
Oddometer: 107
Here's another twist I then called San Jose BMW they told me my vin # didn't have enough didgets that it should be a 13 didget # located on the rail under the right carb well mine is a 7 didget # starting with 618 that is stamped into the rail up by the headstock and there is also the riveted plate with the same # and the mtr has the same # also but they say they can't look it up because they need a 13 didget # any ideas ?
toslow is offline   Reply With Quote
Old 10-30-2012, 12:36 PM   #32
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,195
Originally Posted by toslow View Post
...they told me my vin # didn't have enough digits that it should be a 13 digit # located on the rail under the right carb...
The guy obviously isn't familiar with the pre - 1980s bikes! Before the 13 digit thing was mandated, they were all 7 digits - on the head tube or gusset, and the engine by the dipstick.
Old 10-30-2012, 01:23 PM   #33
kadesean
eyesuck
kadesean's Avatar
Oddometer: 981
What is a 13 digit VIN? My pre 80's Beemers had 7 digits and post 80 have 17 digits.
steve-0
kadesean is offline   Reply With Quote
Old 10-30-2012, 01:35 PM   #34
toslow
toslow's Avatar
Oddometer: 107
Maybe he said 17 all I know it was alot more #'s than I had also I talked to BMW NA and they said they had no way of tracking what bikes were updated with a new tranny they said that recalls do not expire but it would be up to the dealer and them to decide weather to replace it they sounded like if it hasn't failed yet it's probably ok
Old 10-30-2012, 02:35 PM   #35
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,144
Originally Posted by Airhead Wrangler View Post
He's not looking for parts. It's a recall. He needs to see if his bike was inspected or repaired as part of the recall mentioned above. That info probably is NOT in the computer... anyone's computer. Anyone know if they marked the boxes in any way after inspection? A paint dot or a stamp in the case somewhere maybe?
Info is instantly available for all VIN's that have or have not yet had the recall front wheel. Expect same info on that tranny recall or any German factory or US DOT recall. All dealers can have that info if they want to just call it up on their system. If they don't want to, then they are just negligent or incompetant or LYING. Pick one.
DoktorT is offline   Reply With Quote
Old 10-30-2012, 02:44 PM   #36
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,549
So, whenever BMW computerized things, probably in the mid 80's I'd guess, they went back and manually digitized all their paper records of which bikes received a recall fix in the 70s? How far back did they go? I find this tough to believe, but if anyone would do it, it would be the germans.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 10-30-2012 at 03:17 PM
Airhead Wrangler is online now   Reply With Quote
Old 10-30-2012, 03:05 PM   #37
Biebs
BMW Airhead
Biebs's Avatar
Oddometer: 532
Laugh Buy it
I think you should "Buy this Bike" but always a butt - Don't pay $6200
Biebs is online now   Reply With Quote
Old 10-30-2012, 03:47 PM   #38
tearapin OP
Oddometer: 44
And you would pay?
tearapin is offline   Reply With Quote
Old 10-30-2012, 03:50 PM   #39
tearapin OP
Oddometer: 44
I called two different dealers and BMW of North America. All said the Vin was invalid. I have 7 numbers. They all said vins usually start with a letter for 1977.
They all said they could not look up the tranny recall and give me a serial number range of affected r100rs's.
Old 10-30-2012, 04:23 PM   #40
tearapin OP
Oddometer: 44
One dealer i called said this. As the bike has likely sat for may years you should expect to have to replace all the seals within 3000 miles. Trans seals, rear main, rear drive, etc. In summary he said this could cost several thousands of dollars. I am pretty handy with a wrench but he said that for many of the seals you need special tools.
I plead ignorance here but sounds like if I paid what he was asking I could be into the bike for $9000.
Truth or BS in your opinions? What would you offer or would you just walk away?
Old 10-30-2012, 04:26 PM   #41
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,980
Here is the serial number page for R100RS's.... seven digits
http://www.bmbikes.co.uk/chassispage...hassis1000.htm
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 10-30-2012, 04:32 PM   #42
tearapin OP
Oddometer: 44
Thanks. Sad that the people I called said it was not a valid number. Even BMW of North America said it.
Old 10-30-2012, 04:57 PM   #43
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,980
Most BMW shops don't know what an Airhead is, and would want one darkening their door... when you find a dealer who likes and supports Airheads, give them your $$ and keep them in business!
I'm lucky to have two in the state
R65LazaruS
Old 10-30-2012, 05:03 PM   #44
DJones
DJones's Avatar
Oddometer: 171
Anytime you are dealing with a 35 year old machine, be it a motorcycle, car, boat, ect, you need to expect higher operating costs. Especially on a vehicle you do not no the history on. Yes old seals are going to fail, bearings have rust spots, old electrical systems short, points fail, ect. It is a truth, not BS.
But it is also the apeal for me. Learning how to fix and adjust to keep her running is part of vintage ownership. Parts are also higher, so becoming self sufficent is important if you are worried about the cost.
All in all, having to spend several thousand dollars on an old motorcycle is not unheard of, and if that is going to break the budget, I might look for a newer model.
But then again, a 77 RS is friking sweeeeet.
DJones is offline   Reply With Quote
Old 10-30-2012, 05:12 PM   #45
tearapin OP
Oddometer: 44
It would not break the budget but how dumb should I be? By all my research it is about 2k over value with the potential to put another 2 to 3k in it. I mean I would like to ride it more than wrench it.
History is the carbs had to be totally redone so I suspect it sat. That is what I base the seal thing on.
I don't mind wrenching but the special tool thing might put it way out of reach. Just thinking out loud.....
And yes it is sweet. I test drove it. Couldn't help wondering if the engine oil had last been changed in 1980 or the rear end fluid in 1981.... Was I causing damage to this sweet ride? Was I mixing peanut butter in the crank case?
Times are GMT -7.   It's 07:11 PM.
