Old 10-30-2012, 11:12 AM   #1
cantweallridealong OP
cantweallridealong's Avatar
Oddometer: 23
Ktm 690 enduro help needed pls
Hi all
i am currently traveling south america on a KTM 690 Enduro and have a problem..
engine noise ticking very rapidly turned into a full melt down from the bike
i am some what mechanically inclined so i set to work.. to try to see what the hell had happened..
I was quite sure that this was a valve issue. took off the head to reveal a super f**ked Valve Rocker Bearing that has stripped it’s self and seized.. also damaging the Valve Cams too..
As i can tell there dos not appear to be any other damage done to any other parts..
my questions for anyone who can help is would this have done any other damage to the motor... i.e. the piston, cylinder etc... this is not an easy thing too tear down to check..
and other than ordering a new Rocker Arm and Valve Cam what else does anybody recomend i should replace with these..
many thanks
James
cantweallridealong is offline   Reply With Quote
Old 10-30-2012, 11:25 AM   #2
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
A couple guys just had that issue on the 690.
Post up here: http://www.advrider.com/forums/showthread.php?t=722987 before the V-Twin OC Nazi's get on your ass.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 10-30-2012, 06:49 PM   #3
Groundhog
Groundhog's Avatar
Oddometer: 188
If it were me I would do as you say and change oil & filter to be on the safe side. Doesn't look like enough heat or enough metal removed to worry about anything else. Maybe someone else can point out something I missed though. Good luck!
Groundhog
Horsepower determines how fast you hit the wall. Torque determines the size of the hole you make.
Groundhog is offline   Reply With Quote
Old 10-30-2012, 09:22 PM   #4
milzispete
Conquistador
milzispete's Avatar
Oddometer: 327
This shouldn't affected the valve timing so the pistons and valves themselves should be fine. If you are worried about it you can do a compression test.
Since you have it in pieces already you should check the timing chain tension rail and chain guide for excess wear.
Don't forget you will need to redo the valve clearances
milzispete is offline   Reply With Quote
Old 11-01-2012, 01:27 AM   #5
sedd
Oddometer: 13
Originally Posted by cantweallridealong View Post
Hi all
cantweallridealong
Hi, could you specify please - which oil you have used in your 690 and how much you have rode with it?
thanks
sedd is offline   Reply With Quote
Old 11-01-2012, 09:13 AM   #6
yuu
yuu's Avatar
Oddometer: 122
Chances of other damage is remote - Don't fret too much about that.
Guessing this is an 08?
Throttle's on the right, so are the brakes. Good luck.
yuu is offline   Reply With Quote
Old 11-01-2012, 10:46 AM   #7
LukasM
Oddometer: 5,426
thanks
If this is the bike I think it is.... a lot! 100,000 km or thereabouts?
James,
As I wrote by email to our friend in common I also think that new rockers and cam should solve the problem.
Since they appear to wear out quicker than the rest of the engine on many 690s I'd start changing them out as preventative maintenance every 20-30k miles depending on how hard and often you rev the engine.
Cheers,
Lukas
Old 11-01-2012, 11:14 AM   #8
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
Cam Rollers
The 690 setup is very similar to the 640, I change out the smaller 640 intake roller out about every 40,000 KM {25,000 miles}... It looks like the 690 rollers may be a bit larger so the service life may be longer...
Here is a link:http://www.advrider.com/forums/showt...632893&page=13
gunnerbuck is offline   Reply With Quote
Times are GMT -7.   It's 02:56 AM.
